Dell E5570 - Bios / Clean ME ADM80 LA-C642P R1.0
  • madjid911
    • 404
    • France
    #81
    Originally posted by madjid911
    I tried post 77, it starts several times without display then ends up turning off, so does not work for me, only post 2 works but impossible to make the wifi work, I updated the bios and the wifi card drivers nothing works
    I tried post 12 everything works thank you very much for sharing
    • madjid911
      • 404
      • France
      #82
      on the other hand it takes a long time to display on first startup could someone clean the intel region?
        • 21606
        That is because it has the same dell OEM configuration as your bios. If you go to the dell support site and view your product spec it has vPro with AMT enabled.
        Because the ME firmware isn`t clean, it needs cleaning, if you havn`t already learnt how read the guides https://www.badcaps.net/forum/troubl...post1622422โ€‹
        • madjid911
          • 404
          • France
          #84
          Originally posted by SMDFlea
          Try an older version, post #5 https://www.badcaps.net/forum/troubl...st#post1752856 ,and try via HDMI as well
          Yes, it's fine, I managed to clean the region, it starts up much faster now. However, I had the choice between two region files (see photo). I didn't know what NPDM and YPDM corresponded to. I took the first one, it works perfectly. I'll upload the clean dump to see.
          Thanks.โ€‹
            • 21606
            Thanks.
            The bios at post 12 had NPDM ,check it with MEAnalyzer. If you`re working on a bios that has YPDM choose the YPDM firmware .
            https://winraid.level1techs.com/t/in...ols-2-15/30719
            Power Down Mitigation (PDM):
            At CSME v11 LP firmware, make sure to mind the PDM status which is distinguished between YPDM (Yes) and NPDM (No). PDM is some sort of erratum, which is only relevant to 100-series PCH-LP systems. Thus, it is an attribute of every CSME v11.0 - v11.8 firmware which supports 100-series PCH-LP systems. The PDM status of a firmware can be detected by ME Analyzer by loading either your SPI/BIOS image (Flash Descriptor + Engine + BIOS) or an Engine Firmware Recovery image which can be generated via FWUpdate tool parameter "-save recovery.bin".โ€‹
            • almussafer
              • Jun 2019
              • 79
              • Iraq
              #86
              Originally posted by peste
              Re: Dell E5570 - Bios / Clean ME ADM80 LA-C642P R1.0
              try..
              [Mod. Edit-Vesko356] This dump has issues - wireless card not working (code 10 in Device manager) as reported by few members.
              thanks man ok 100%
              • 3liMohmammad
                • Jan 2023
                • 42
                • Lattakia
                #87
                i have this bios not working
                can clear me Region or fix it
                  • 21606
                  service tag ?
                  • 3liMohmammad
                    • Jan 2023
                    • 42
                    • Lattakia
                    #89
                    service tag : 1WHDVD2
                    • LBTT1121
                      • Nov 2024
                      • 695
                      • Viแป‡t Nam
                      #90
                      try and feedback
                      • 3liMohmammad
                        • Jan 2023
                        • 42
                        • Lattakia
                        #91
                        Originally posted by LBTT1121
                        try and feedback
                        i am sorry your file is work 100%
                        thank you
                        • zenius
                          by zenius
                          12-08-2024, 06:13 AM
                        • mikeybass
                          by mikeybass
                          04-23-2025, 04:30 PM
                        • Akhlz001
                          by Akhlz001
                          09-20-2025, 07:15 PM
                        • jhanra
                          by jhanra
                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, ๐Ÿ˜…๐Ÿ˜…๐Ÿ˜…...
                          11-02-2024, 04:19 AM
                        • gizaha
                          by gizaha
                          02-13-2024, 07:18 AM
