ASUS ROG GX531GW BIOS Request
  • Suzn123
    • Oct 2022
    • 11
    • Nepal
    Re: ASUS ROG GX531GW BIOS Request
    Originally posted by peste
    bios extracted from the Asus site update..
    thankyou for your effort, but but i already have that one and dont know what to do with that, i can only extract bios region from that , other --- dont know.. . . . . . i have cleaned ME region, PMC region and put the latest bios on it but without modifying discriptor regon or changing its S/N , bios is not working , thats what i feel so... ; so i just want the bios with the s/n on it or whatever the input may require. . .since i dont have backup bios of old one so my summerized question is like.............. what to do when you change PCH , what modified bios we need ? . . . again thankyou soo much for your time.
    • peste
      • Dec 2016
      • 13202
      • ROMANIA
      you only have to write it on the bios chip... you don't have to delete anything on it .. it's the virgin bios..
      • hardware1
        • Sep 2021
        • 2943
        • N/A
        Anyone , please hep me with the bios. laptop turns on , takes 1.3 Amp , but no display. . i dont have the backup bios, i tried cleaning ME region with the backup bios from the internet but no good result. all voltages are OK to me , dont know what is the fault so first i wanna make sure bios is ok, then i can go back to board again, if same problem .. . . . so please someone rebuild fresh working bios with this serial number .. . . . and can can anyone share their dump file/ working bios backup of GX531GS with us??? please
        Model - GX531GS-AH76
        S/N - J9NRCV029123394
        CN - JL52
        MFD - 2018-09
        Perhaps this BIOS will help you, try it.
        If it doesn't work, take an image for any QR code/Bar code sticker on the motherboard and post it here.
        all donations are welcome,
        • Suzn123
          • Oct 2022
          • 11
          • Nepal
          thankyou so much for your effort , and , but its similar to above GX531-F1 image which i have already tried, but still it does not hurt to try again. . .. will try and let you know . . till then here are the QR image and also MEanalyzer error for that bios , could be the reason for not working . . . thankyou again.
          • hardware1
            • Sep 2021
            • 2943
            • N/A
            Just try my file and see what will happen. You got errors by ME Analyzer because you are using an old version. This isn't the correct QR code, search for another one, it could be on a sticker or printed on the board.
            • Suzn123
              • Oct 2022
              • 11
              • Nepal
              #26
              OMG , my life was a lie, i thought i was using the latest , didnt check. and luckily version r329 just been arrived, so that means you too now using old version. . . .
              .. and thanks alot. .. . . . i will give it a try. . . . abd about QR, i dont see anywhere else, just many barcodes. .which i share here . . .
              and if someone have (board view) brd version of this motherboard- GX531GS, please share. i could only find the pdf version which makes it difficult to find the connections.
              thanks again. have a great time. . .
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #27
                All schematic and/or boardview requests should be placed at "Schematic Requests ONLY!" sub-forum, so make your request in the thread where you "found the pdf version" as well, not here!
                Become a Badcaps supporter
                Thanks to all supporters.
                • Suzn123
                  • Oct 2022
                  • 11
                  • Nepal
                  #28
                  NO luck . . my problem is similar to https://www.badcaps.net/forum/showthread.php?t=84282 i guess. . but i dont have proper bios to verify if its PCH or bios. . .
                  same condition like him, all PWRGD voltage checked ok, PCH is turning suer hot to touch while starting, , 1.05VSUS voltage for PCH is ok but its 40ohm resistance to the groung, unlike another acer nitro 5 with similar PCH has 1kohm resistance to the ground . . is it ok?
                  he is lucky to find doner board, which i dont have .
                  i cant request brd here, . but i would like to request bios file from working motherboard or similar board. i want to make sure its not the bios , before moving on to PCH
                  and what i dont understand is the bios is 128mb but the bios file is 16mb , , am i missing something? . . please help.
                  thankyou
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #29
                    128 Megabits flash memory chip = 128 Megabits (Mb) = 16,384 KiloBytes (KB)
                    16,384 KiloBytes (KB)=16 MegaBytes (MB)
                    1 MB = 1,024 KB
                    • Suzn123
                      • Oct 2022
                      • 11
                      • Nepal
                      #30
                      ohh is it in megabits (Mb). . . Ohhhhhh lord where is my brain at. . this problem is killing my brain cells but i dont wanna give up. . trying again, keep learning... its addicting
                      hope someone making right bios for me to try again . . . .
                      • zapdus
                        • Jun 2024
                        • Portugal
                        #31
                        I have 306 version on my gx531gw zepherys s 2070 max-q 8750H
                        BIOS 307 and 308 locks out undervolting completely, so for this purpose you have 2 choices
                        1. Install BIOS 306
                        2. Modify your Bios 307 or 308 (there is a videoo on Youtube how to do this) in order to unlock undervolting
                        Cant make XTU undervolting to work (new XTU version greyout adjustments) old version of XTU crashes.
                        But I still managed to do -.140mV in ThrottleStop
                        PS: I couldnt find working version of 306 BIOS nowhere in the internet, hope ill help somebody with this.
                        Hi
                        I have installed this BIOS V306 sucessfully
                        but still can't see voltage configuration on advanced tab
                        is it suppose to not have voltage configuration and other options related to clock speed to undervolt?
                        cant change modify values for core voltage on intel xtu and asus armory crate, not avaliable
                        • mgrharry
                          • Sep 2016
                          • 211
                          • usa
                          #32
                          I've got an Asus GX531GW-AB76 that is not posting after a failed attempt to flash v306 in order to enable undervolting. I've dumped the BIOS via CH341 us AsProgrammer and it is attached. FYI, the BIOS chip was soldered directly to CH341 for the dump, not attached via test clip so the reading should be good. The motherboard model number is 60NR02H0-MB1010. Thanks for any help folks can provide.
                            • 21472
                            Thread merged. Type and post the laptop serial number
                            • mgrharry
                              • Sep 2016
                              • 211
                              • usa
                              #34
                              Serial number is K5NRCV01W093197. Thanks.
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12129
                                #35
                                Fault backup .
                                • noname2024
                                  • Aug 2024
                                  • 275
                                  • CỎ MỸ XỊN
                                  #36
                                  Model: GX531GWR
                                    • 21472
                                    Make another backup before you flash any other bios, then at least you will have DMI + windows key to transfer to the new one, if your backup is good. Use NeoProgrammer software, see if you get better results with it.
                                    • mgrharry
                                      • Sep 2016
                                      • 211
                                      • usa
                                      #38
                                      Thank you! File from noname2024 worked. The original BIOS chip turned out to be bad, which is why my dump was blank. I was able to pull another BIOS chip from a dead motherboard and flash that and I'm back in business. Appreciate everyone help.
                                      • tktrom
                                        • Jul 2022
                                        • 79
                                        • Bolivia
                                        #39
                                        Good evening, my machine is an Asus GX531GX-SX74
                                        SN:K1NRCV03U061049
                                        The bios that I will publish only recognizes the Intel video and not the dedicated video, in the bios it appears that it is model GX531GM and the serial number does not appear. Apparently the bios has already been changed, I tried the bios published in this thread but no video shows, some teacher could provide me with a good bios for the model of my machine. (GX531GX)​
                                        • noname2024
                                          • Aug 2024
                                          • 275
                                          • CỎ MỸ XỊN
                                          #40
                                          SN:K1NRCV03U061049
                                          working
                                          • razor_amd
                                            by razor_amd
                                            12-15-2020, 07:07 PM
                                          • grimacelord
                                            by grimacelord
                                            07-10-2025, 02:52 PM
                                          • throwaway327
                                            by throwaway327
                                            Model No: RC72LA
                                            Serial No: SBNVKD001014459
                                            06-18-2025, 05:52 PM
                                          • skurvysyn
                                            BIOS request - Asus Rog Zephyrus GA503RS - DANJPMB3AA0 Rev. A
                                            by skurvysyn
                                            laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
                                            original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...
                                            01-08-2025, 04:45 PM
                                          • skipron.rm
                                            ASUS Zephyrus GX701LXS BIOS request
                                            by skipron.rm
                                            Hello everyone, trust you're doing well.
                                            I'm currently facing an issue with my ASUS Zephyrus GX701LXS, as it isn't posting.
                                            I've downloaded the latest BIOS version, "GX701LXS-AS.311" (v.311), from the ASUS website.
                                            However, there's a challenge – the file size exceeds the capacity of the BIOS chip, making it impractical for writing.
                                            The current BIOS dump ("GX701LXS.307 bios-dump.bin" find attached), is of version 307.
                                            My attempt to extract "GX701LXS-AS.311" using the "AMI_BIOS_GUARD_Extractor" was aimed at combining...
                                            Badcaps - Capacitor Search Engine & Electronics Repair Forum
                                            12-11-2023, 06:12 PM
