BIOS request - Asus Rog Zephyrus GA503RS - DANJPMB3AA0 Rev. A
  • skurvysyn
    • Oct 2024
    • Czech republic
    laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
    original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter temps, keyboard illuminated, dimms and illuminates again in a pattern, blank screen, no caps lock reaction, i tried bios from (attachment (from vinafix) and also from (https://www.badcaps.net/forum/troubl...lay-after-bios) - the behaviour is the same, no caps light, no beeping - im using battery as power source, dont have big charger for asus...
    If possible, not sure if this laptop can work in such combination, wasnt the best decision but if someone could get a dump which was from RS model and just somehow modify to work with the R9 (i think its RW model) that would be amazing.
  • skurvysyn
    • Oct 2024
    • Czech republic
    hello, pls close thread, turns out there is multiple revisions of ryzen cpus, the 544 which i bought is for LPDDR5 which the laptop doesnt have, i should have bought 560 one, which is for normal DDR5 - also learnt tdp is controlled by bios so HS=HX - sorry for trouble
      • 21467
      The posted bios might help someone else.
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • skipron.rm
        ASUS Zephyrus GX701LXS BIOS request
        by skipron.rm
        Hello everyone, trust you're doing well.
        I'm currently facing an issue with my ASUS Zephyrus GX701LXS, as it isn't posting.
        I've downloaded the latest BIOS version, "GX701LXS-AS.311" (v.311), from the ASUS website.
        However, there's a challenge – the file size exceeds the capacity of the BIOS chip, making it impractical for writing.
        The current BIOS dump ("GX701LXS.307 bios-dump.bin" find attached), is of version 307.
        My attempt to extract "GX701LXS-AS.311" using the "AMI_BIOS_GUARD_Extractor" was aimed at combining...
        Badcaps - Capacitor Search Engine & Electronics Repair Forum
        12-11-2023, 06:12 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
