mec 16xx dump with info block
  • RethoricalCheese
    • Mar 2013
    • 1518
    • Estonia
    #101
    Re: mec 16xx dump with info block
    It doesn't matter AT ALL because you need to disassemble the laptop anyway to move that resistor. So just use jtag solder pads and don't bother with keyboard connector. You should use keyboard connector ONLY if you have tens or hundreds of laptops of the same model.
    I used it just to make testing various things easier. But for single unlocking, it's way faster and easier to use jtag solder pads.
    • mysticusa
      • Feb 2021
      • 11
      #102
      does it mean, in either cases you have to move/solder the resistor anyway? or kbc can do it without resistor issue? i m confused just trying to figure it out. thanx
      • RethoricalCheese
        • Mar 2013
        • 1518
        • Estonia
        #103
        Take the second half of that quote - "you need to disassemble the laptop anyway to move that resistor"
        This answered your question.
        • mysticusa
          • Feb 2021
          • 11
          #104
          i ordered the vertyanov kit, and it comes with the keyboard connectors as it looks like thats why i was asking, the pogo pins you have to make one and arrange it, extra work... when you remove the mobo, it is easier to just plug keyboard flex cable no? pogo pins/cables you will need to get stable contact tapes etc?
          i read aaac comment about read-backup-erase-program data, and use tool to fix serial model etc info you only need to move the resistor on erase-program stage? and move it back after that and before the fixing the bios additional info? or do you need to move the resistor before doing read/backup?
          thanx
          • RethoricalCheese
            • Mar 2013
            • 1518
            • Estonia
            #105
            Jtag uses different connector, not the keyboard cables so I highly doubt you can use those. Got to make one yourself. Like I said, if you have only one machine, stop thinking about the keyboard connector.
            You need to move the resistor only once. No need to move it back later.
            And when you read it using vertyanov, you can just delete password part and write that file back. This is the newer method. Then you won't have to mess with writing back serial numbers because they will not be deleted.
            • AAAC
              • Jan 2020
              • 458
              • Mexico
              #106
              @mysticusa
              For the MEC chips, which this thread is all about, it uses a different connector as RethoricalCheese says; but for other EC/KBC chips like Nuvoton, ENE, ITE you use the keyboard connector for programming ec/kbc, sometimes the pinout is already defined in programmer configuration file, other times you have to find out the correct pinout and add an entry to configuration file.
              • anhbanxoi
                • Sep 2021
                • 172
                • VN
                #107
                Thank you for the information. I've just tried with Vertyanov but I don't know how to delete password part. In the software there are 2 things to select (FLASH and EEPROM) and the password is in EEPROM but also Serial Number,... So when I erase this EEPROM area it also deleted serial number. Could you please share how to delete only password part? Thank you
                • imranromi
                  • Jan 2015
                  • 1288
                  • Pakistan
                  #108
                  No, when you select eeprom read only password section where is store.Mec have 8 block password store in 7th block or dmi info is 8th block.If you read eeprom send will remove password.
                  • anhbanxoi
                    • Sep 2021
                    • 172
                    • VN
                    #109
                    I think in my case (Thinkpad T490) the password stored in the first block of EEPROM because when I try to fill the first line with FF I can go to the BIOS setting but with serial number invalid.
                    • imranromi
                      • Jan 2015
                      • 1288
                      • Pakistan
                      #110
                      Try this.
                      • msnessay
                        • Apr 2015
                        • 121
                        • GRANDY
                        #111
                        Try this.
                        can you patch this file ITE8227 read via vertyanov
                        THINKPAD L590 with password
                        FL490/FL590 NM-B931 rev 1.0
                        • msnessay
                          • Apr 2015
                          • 121
                          • GRANDY
                          #112
                          GT4A3/GX3A2 NM-C891 Rev :1.0 Lenovo x13
                          i need jtag pins
                          please
                          • msnessay
                            • Apr 2015
                            • 121
                            • GRANDY
                            #113
                            Thinkpad X13 with password
                            vetyanov gives me this message
                            what will i do please ? erase chip?
                            • korhy
                              PatchedBIOS
                              • Nov 2021
                              • 6
                              • Russia
                              #114
                              Hi everyone here, got same mec1663 on locked Thinkpad T590(starting with bios message 0199 - system security security password retry count exceeded) now waiting for Vertyanov Jig delivery, so is it necessary to move resistors?
                              • evserv
                                • Jun 2014
                                • 355
                                • Russia
                                #115
                                There is an instruction in the program directory, study it carefully and there will be no more questions like this.
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1518
                                  • Estonia
                                  #116
                                  I guess I have said many times here already. You have to move the jtag reset resistor in any case.
                                  • msnessay
                                    • Apr 2015
                                    • 121
                                    • GRANDY
                                    #117
                                    any help please
                                    • evserv
                                      • Jun 2014
                                      • 355
                                      • Russia
                                      #118
                                      any help please
                                      Without reading this manual, you will not be able to use this programmer ...
                                      • msnessay
                                        • Apr 2015
                                        • 121
                                        • GRANDY
                                        #119
                                        i tried vertyanov for some others model like T490 with success Bro
                                        read and whrite good
                                        but in this model i used RT809 also i read the the mec but empty without data
                                        also with vertyano gives me message like photo before
                                        Thnks for your answsers
                                        • evserv
                                          • Jun 2014
                                          • 355
                                          • Russia
                                          #120
                                          If you have blocked jitag, then you will not be able to read it. First, you need to completely erase, and then write the firmware there in turn, and then eeprom.
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            āœ… What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • Andreas_de
                                            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                            by Andreas_de
                                            Hello!
                                            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                            04-12-2025, 10:38 AM
                                          • re-atari
                                            Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                                            by re-atari
                                            Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                                            Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                                            02-03-2025, 06:49 PM
