mec 16xx dump with info block
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    #81
    Re: mec 16xx dump with info block
    Originally posted by imranromi
    Now not difficult to buy original.i just order yesterday.i have also Sas copy programmer but copy is copy not work like original.
    I checked today and it's still way easier to buy the copy
    But I'll see about activating the copy then. Actually sent him an email a week ago and haven't had a response.
    Edit: Nevermind, it went to junkmail
    • imranromi
      • Jan 2015
      • 1292
      • Pakistan
      #82
      I buy from this sites.
      https://www.vss.store/
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        #83
        Yes, that's the only place it is sold. As I said, it is still easier to buy the copy because the copy is sold in multiple sites. It doesn't come up as a google search response aswell, only the copies do.
        I got mine a couple years ago and at that time, I didn't even know that the original and copy are 1:1. ioprogrammer seemed like a legit seller aswell but it turned out to be the copy after I bought it.
        But if activating copy is truely possible then atleast it doesn't go to waste. Original author can still get something for it.
        • imranromi
          • Jan 2015
          • 1292
          • Pakistan
          #84
          Sas programmer is clone not original.Made in Turkey i know guy.
          Above i send you link i think is original programmer.
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            #85
            Yes, I know that. You missed my point. My point was that it is too easy to buy the wrong programmer compared to buying the correct one.
            • imranromi
              • Jan 2015
              • 1292
              • Pakistan
              #86
              Correct i understand.
              • RethoricalCheese
                • Mar 2013
                • 1519
                • Estonia
                #87
                Originally posted by evserv
                Today I spoke with the author at your request ...
                Anyone can activate a clone of the programmer through the author of the programmer Vertyanov and make the programmer licensed. It will work with the latest software version 8.2 which can work with the eeprom area. The activation cost is $ 50.
                Activation successful on SAS rev 3.9. First victim was T490s using eeprom read/write and it worked nicely. No serial number rewriting needed now.
                • zomi
                  • Nov 2011
                  • 513
                  #88
                  Excellent news
                  • dimkka
                    • May 2013
                    • 16
                    • moldova
                    #89
                    So did you manage to unlock it? Or did you just read and write? I have Svod3, read and write ok, laptop remains locked Lenovo thinkpad T14 gen 1
                    • RethoricalCheese
                      • Mar 2013
                      • 1519
                      • Estonia
                      #90
                      As I said, I used vertyanov, not svod3 to unlock it. Still no idea how people use svod3 to unlock. But since I haven't seen anybody confirm it to work, maybe it just doesn't.
                      • AAAC
                        • Jan 2020
                        • 459
                        • Mexico
                        #91
                        @dimkka
                        When you perform the READ-ERASE-PROGRAM procedure in the EC/KBC, try to disconnect all source of energy including CMOS battery, check if that makes a difference. We had a similar problem, which was solved by disconnecting all source of energy for 2-3 minutes.
                        • RethoricalCheese
                          • Mar 2013
                          • 1519
                          • Estonia
                          #92
                          Tried it with both SAS and SVOD3. Did not help. It was not needed for vertyanov and rt809 tho.
                          • siddiq
                            • Dec 2011
                            • 121
                            • Ghana
                            #93
                            Originally posted by dwirachmat
                            Work for svp password. But for computrace cant be done. Computrace still remaining when entering bios setup. All id are gone, but computrace still actived. Any solution?
                            Hello, if you haven't solved the computrace already, try writing a fresh bios with ME area cleaned.. worked for me. I have both SVOD and RT809H but the latter worked for me concerning the MEC.
                            • salim1gr
                              • Oct 2018
                              • 22
                              • Sweden
                              #94
                              I have flash MEC wrong file and Now laptop is not turn on
                              T490
                              Please help
                              • AAAC
                                • Jan 2020
                                • 459
                                • Mexico
                                #95
                                @salim1gr
                                That’s not a problem, you can extract the EC/KBC firmware from a ThinkPad T490 bios update executable, trim the file so it can be used, then use this new file to update the EC/KBC chip using the programmer you have.
                                • Ghamidi
                                  • Mar 2020
                                  • 306
                                  • France
                                  #96
                                  T490
                                  Please help
                                  try..
                                  • nabilgo
                                    • May 2016
                                    • 307
                                    • L.A
                                    #97
                                    If you want to unlock lenovo, use the patch method instead.
                                    does it work with lenovo t490s 8 generation ?????
                                    • nabilgo
                                      • May 2016
                                      • 307
                                      • L.A
                                      #98
                                      Originally posted by Aditya11ttt
                                      try this try to find jtag1 connector name on the board only space will be there without connector !!
                                      can i just patche it lenovo t490s or i should use jtag
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1519
                                        • Estonia
                                        #99
                                        Didnt you read 3rd post?
                                        • mysticusa
                                          • Feb 2021
                                          • 11
                                          #100
                                          did you use soldering method or through (kbc?) keyboard/controller cable method?
                                          thank you
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            āœ… What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
