mec 16xx dump with info block
  • AAAC
    • Jan 2020
    • 459
    • Mexico
    #61
    Re: mec 16xx dump with info block
    Yeap, they are named "pogo pins".
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      #62
      Keyboard connector is easier to use in some cases No need to solder anything except that one resistor.
      • black0hackers
        • Jul 2020
        • 369
        Originally posted by LenBios
        this pins
        where i can buy it?
        • zomi
          • Nov 2011
          • 513
          #64
          which one works better, more reliable rt809 ?
          or is the svod3 just as good, keyboard connector sounds so good..
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            #65
            When it comes to the keyboard connector, it doesn't matter if you use rt809 or svod3. That cable you need to make yourself anyway.
            • zomi
              • Nov 2011
              • 513
              #66
              • RethoricalCheese
                • Mar 2013
                • 1519
                • Estonia
                #67
                Who here even uses SVOD3 and can successfully unlock all thinkpads with it? What's the secret? Thus far it seems just as bad as SAS JIG when it comes to that.
                • keczuk
                  • 84
                  • WWW
                  #68
                  Do you use this adapter for rt809h for programming via keyboard ??::
                  https://www.eliptor.pl/index.php?p10...-rt809f-simple
                  if not please send what did u use.
                  • RethoricalCheese
                    • Mar 2013
                    • 1519
                    • Estonia
                    #69
                    No. I took some random flex from some random HP laptop, attached it to some random project board that had that same connector connected to pin header and used jumper wires to connect it to programmer. So it's totally diy.
                    I guess that adapter board would work aswell but not sure.
                    • evserv
                      • Jun 2014
                      • 365
                      • Russia
                      #70
                      Yesterday there was an update for the programmator: "Vertyanov" which can read and write the eeprom area.
                      https://www.vss.store/magazin/product/programmator
                      Now you do not need to erase the entire firmware and you can edit only the eeprom area.
                      You can download it from here:
                      https://drive.google.com/file/d/1cWB...ew?usp=sharing
                      • zomi
                        • Nov 2011
                        • 513
                        #71
                        Which programmer works best just about to buy one
                        1. svod
                        2. rt809h
                        3.Vertyanov
                        which is most consistent and trouble free
                        thanks
                        • RethoricalCheese
                          • Mar 2013
                          • 1519
                          • Estonia
                          #72
                          Out of those 3, only rt809h has worked fine for me... Until somebody who owns a svod finally tells me how they use it to unlock lenovos...
                          • evserv
                            • Jun 2014
                            • 365
                            • Russia
                            #73
                            Of these, only the programmer Veryanov can read and write eeprom, this is the DMI block where the password is stored.
                            • zomi
                              • Nov 2011
                              • 513
                              #74
                              @evserv have you used one to unlock a Lenovo ?
                              • evserv
                                • Jun 2014
                                • 365
                                • Russia
                                #75
                                programmer Vertyanov yes used
                                • zomi
                                  • Nov 2011
                                  • 513
                                  #76
                                  Also
                                  Anyone cleared the password on a x1 yoga 4th gen or x1 carbon 7th gen ?
                                  using this method..
                                  thanks
                                  • RethoricalCheese
                                    • Mar 2013
                                    • 1519
                                    • Estonia
                                    #77
                                    Too bad it's difficult to buy the original but it's easy to buy the copy. And I guess it's not possible to just buy the software license to use vertyanov software with the copy board.
                                    • evserv
                                      • Jun 2014
                                      • 365
                                      • Russia
                                      #78
                                      Today I spoke with the author at your request ...
                                      Anyone can activate a clone of the programmer through the author of the programmer Vertyanov and make the programmer licensed. It will work with the latest software version 8.2 which can work with the eeprom area. The activation cost is $ 50.
                                      • imranromi
                                        • Jan 2015
                                        • 1292
                                        • Pakistan
                                        #79
                                        Now not difficult to buy original.i just order yesterday.i have also Sas copy programmer but copy is copy not work like original.
                                        • evserv
                                          • Jun 2014
                                          • 365
                                          • Russia
                                          #80
                                          Everyone understands that the original is the original!
                                          This is news for those who might want to activate their clone so they can work now.
                                          Once activated, the clone will work just like the original.
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            āœ… What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
