mec 16xx dump with info block
  • coolshrimp
    • Nov 2016
    • 54
    Re: mec 16xx dump with info block
    Originally posted by exe557
    This resistor needs to be moved from red to yellow position.
    If you cannot read after that, chip is locked. Just write extracted dump from bios update and it will be ok
    do i leave my jumper in place?
    • coolshrimp
      • Nov 2016
      • 54
      No luck do I remove both resistors?
      Seems red line and resistor bellow it both bridge the same trace.
      • exe557
        • Jan 2021
        • 24
        The resistor will be on the red marked one and act as PULL UP resistor. You need to move it from red position to yellow to make it PULL DOWN.
        Not remove it!
        • volinakis
          • Jan 2021
          • 2877
          • N/A
          #284
          exe557 is right. Remove RST wire from JTAG connector, put pull up resistor in the place he indicated, choose MEC1633 in RT809H, plug in AC adapter then you can read MEC. After you read it hit erase, unplug ac adapter, leave it 1-2mins, plug in again ac adapter and write back the dump you saved. Then put back pull up resistor. You have all this infos here if you bother to read it.
          • coolshrimp
            • Nov 2016
            • 54
            Ok Iv done that and still won’t read.
            I tried erase as well it also just gives same chip error 0xFFFFFF.
            Rst wire removed.
            Pads (1-5) connected to RT809h (no resistors inline)
            Moved red resistor to yellow position
            Board is powered (leds on and I read 3.3v on pad 6)
            I also read ever post in the thread and tried all and nothing has worked so far on this stubborn chip.
            • exe557
              • Jan 2021
              • 24
              Do you still have the jumper on rst in place?
              I always keep RST line connected to RT908. Try without your jumper.
              • coolshrimp
                • Nov 2016
                • 54
                I got it!
                you said to move resistor from red to yellow i did and still didnt work.
                So i held a spare 10K resistor in place on the same yellow point and suddenly it reads now, I stopped holding my 10K and now it works fine.
                • coolshrimp
                  • Nov 2016
                  • 54
                  Ok now that that is solved ill share my diagram and instructions.
                  T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
                  Now next issue setting Serial / Model / Etc.
                  Lenovo T14s (NM-B891)
                  Iv Tried to Use Lenovo Maintenance Utility 1.89 (i7tm38us)
                  But I get and error *EEPROM Overflow
                  Same issue here: https://www.badcaps.net/forum/showth...EPROM+overflow
                  • coolshrimp
                    • Nov 2016
                    • 54
                    To set the Serial Number, Model on my Lenovo T14s:
                    I Used "ThinkPad Config Information Update Utility v1.11" attached
                    -Extract and run "usbfmtpw.exe" this will format your USB and copy the files over.
                    (check that the files copied after format. if not manually copy them to the root of the usb).
                    -Insert to laptop and boot to USB FDD it is EFI not Legacy (USB you just created).
                    -Now go 1, then use 2 to read current keys. record any keys shown, take a photo of them they will be erased if there not already.
                    -Now go back to main menu and choose initialize EEPROM, this clears all keys plus UUID and now the overflow error wont happen.
                    -Now go 1, then use 1 again to add new info, enter C0 then Enter.
                    -Now enter serial and model in long form will start with 1S so (1STTTTMMMMCCSSSSSSS)
                    -Enter and Key is stored.
                    -If you like can add more or go back and use option 3 for a few more config details. (I set my brand name there)
                    -Once all info is set go to assign UUID, and say Yes.
                    (once you generate the UUID you cannot edit the serials unless you initialize and do them all over again.
                    -Reboot and check bios screen your info should be there no more beeps on boot.
                    Product ID: TTTT-MMMMCC
                    Serial#: SS-SSSSS
                    TTTT = Machine Type
                    MMMM = Model Type
                    CC = Country Code
                    SSSSSSS = Serial Number
                    • volinakis
                      • Jan 2021
                      • 2877
                      • N/A
                      #290
                      I got it!
                      That means you didn't solder properly 10k pull up resisto when you move it.
                      • coolshrimp
                        • Nov 2016
                        • 54
                        possibly its so tiny. but it finally worked.
                        • takura
                          • Sep 2016
                          • Zimbabwe
                          #292
                          I managed to read the MEC1663 with an RT809H JTAG and then wrote back the backed up file and the machine is now booting without password but the DMI information is missing.
                          • coolshrimp
                            • Nov 2016
                            • 54
                            https://www.badcaps.net/forum/showpo...&postcount=289
                            • mesdova
                              • Oct 2015
                              • 24
                              • algeria
                              #294
                              NEED THE PIN conect JTAG MEC-1653 T580
                              ThinkPad T580 17812-1
                              448.0CW18.0011
                              • AAAC
                                • Jan 2020
                                • 459
                                • Mexico
                                #295
                                @mesdova
                                It will be a lot more easier if you do the BIOS patch, which is supported on ThinkPad T580.
                                • mesdova
                                  • Oct 2015
                                  • 24
                                  • algeria
                                  #296
                                  Because I placed a new EC MEC1653 And I wante to reprogram it
                                  • coolshrimp
                                    • Nov 2016
                                    • 54
                                    448.0CW18.0011
                                    Here is the boardview and schematics.
                                    https://www.badcaps.net/forum/showthread.php?t=104317
                                    If you're not sure how to figure out with the files above let me know I could take a few min and figure it out for you.
                                    • mesdova
                                      • Oct 2015
                                      • 24
                                      • algeria
                                      #298
                                      THENK YOU coolshrimp
                                      let me know Pictures pictures pin conect
                                      Where is
                                      • ymifdal
                                        • Jan 2022
                                        • 120
                                        • Morocco
                                        #299
                                        clean MEC1633 dump for T440 anyone?
                                        • coolshrimp
                                          • Nov 2016
                                          • 54
                                          448.0CW18.0011
                                          Move Resistor R6140 to R6117 to enable Jtag R/W.
                                          Return resistors to original configuration for normal operation.
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            āœ… What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
