mec 16xx dump with info block
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1221
    • France
    #421
    Originally posted by bhatt
    what is the u1u zip file password
    password for the zip is LenovoUone​
    https://github.com/HackerajOfficial/Lenovo-U1-Tool
    • Stefan Steff
      • Mar 2024
      • 239
      #422
      It's : LenovoUone
      • abuge
        • Oct 2022
        • 69
        Hello friends, I have a T14 Gen1 NM-C931 Intel laptop with MEC1663. This unit has a password, and I've tried using the SVOD4 programmer, but it wasn't successful. I'm encountering an error—I've moved the resistor, and it's detecting the I/O, but it's not reading. Attached are pictures and the SVOD4 error log.
        Software version 0.0.5.4 date 5.08.2024
        Running Microsoft Windows 10 Pro 64 bit
        Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
        .NET Framework Version: 4.8 or later
        Device connected in work mode
        Firmware version 0.0.4.0 date 5.7.2024
        MEC mode selected
        MEC eeprom flash mode selected
        MEC IDCODE: B1240020
        Device ID: 0
        Device Revision: 0
        Device Status: 0
        Flash Status: 0000000000
        Boot Block in not protected mode
        Flash Configuration: 0000000000
        MECxxxx series in protect mode, work mass erase only
        Start erase in: 06-11-2024 2:24:09
        End erase in: 06-11-2024 2:24:09
        Erase OK
        • miyagik
          • Jun 2018
          • 21
          • Mexico
          #424
          Can someone help me with a MEC1663 clean dump for a Thinkpad T14 Gen1
          I tried to read with Rt809H but i get 290kb files. Tried to write them but no video. stuck at .500~ A and turns off.
          Any advice it well recived, thanks in advance.
          • PacoGT
            • Sep 2022
            • 83
            • Guatemala
            #425
            i need some info , i have a t14 gen1 locker of bios
            which progammer cheaper of course i need buy?
            xgecu
            or RT809F
            • miyagik
              • Jun 2018
              • 21
              • Mexico
              #426
              xgecu
              or RT809F
              RT809H
              • rickjansen01
                • Feb 2016
                • 129
                • nederland
                #427
                Hello
                Can someone remove the password from this mec1663 flash and eeprom dump
                X1 Yoga gen 5
                PF-2CG9F9
                20UB-S05E00
                Best regards Chris
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1221
                  • France
                  #428
                  Originally posted by rickjansen01
                  Hello
                  X1 Yoga gen 5
                  PF-2CG9F9
                  20UB-S05E00
                  Best regards Chris
                  try
                  • rickjansen01
                    • Feb 2016
                    • 129
                    • nederland
                    #429
                    Hello Maxpower2
                    thanks it works perfect
                    Best regards chris
                    • saisoni20
                      • Feb 2022
                      • 111
                      Hi There,
                      I have RT809F and I am trying to connect MEC1663 for Lenovo X1 Yoga 5th Gen. Programmer is identifying to chip but always gives error for CHIP MAY BE DAMAGED or ENCRYPATED as below.
                      What should cause this issue?
                      • mshone
                        • Jan 2014
                        • 56
                        • serbia
                        #431
                        Originally posted by saisoni20
                        Hi There,
                        MEC1663 or 1633?
                        • saisoni20
                          • Feb 2022
                          • 111
                          Originally posted by mshone
                          MEC1663 or 1633?
                          It's 1663
                          • mshone
                            • Jan 2014
                            • 56
                            • serbia
                            #433
                            It's 1663
                            Your programmer is recognizing 1633. Maybe this is the reason of error
                            • ktvdung89@gmail.com
                              • Sep 2022
                              • 14
                              • viet nam
                              #434
                              Originally posted by volinakis
                              Re: mec 16xx dump with info block
                              I want to share my 1st experience with MEC1663 from Yoga X1 4th gen.
                              Many thanks to AAAC, RethoricalCheese, EvilBzyk, their shared knowledge helped me a lot.
                              1. Connected jtag pins as in picture, no pull up resistor needed. Moved 10k resistor from pull-down to pull-up. Chose MEC1633#ISP. power on motherboard.
                              2. Got message "Chip may be damaged or encrypted, the data is not valid" I did try other options, MEC1653#ISP, MEC1633_256k, same result.
                              3. I hit "Erase" and laptop stops working, no power on/charge led lit.
                              4. I took EC file from bios update and trim 32bytes, the same version it was in bios (I took a photo of info in bios before pulling off the motherboard) wrote the file into EC then power off motherboard. Waited few minutes an power on motherboard, power on/charge led lit. Moved the 10k resistor to pull down.
                              5. schematics IS WRONG! TP1 IS REVERSED WITH TP5.
                              Please help bios EC, SERI: MJ0ERADK
                              Model: x1 carbon 8th
                              My computer has a bios password and can't access the information​
                              • menelik
                                • Mar 2023
                                • germany
                                #435
                                Originally posted by wangbreeze
                                Turned out to be the programmer issue. The RT809F I have worked on the first machine but stopped working on the second (showing 0xCDCDCDCD chip id and reading garbage). I used another rt809h and everything works now.
                                For anyone who encounters this issue with the RT809F and 0xCDCDCDCD, let me save you days of probing and wasting your time. Uninstall the drivers in the Software, then reinstall und it suddenly works again 🤦
                                • menelik
                                  • Mar 2023
                                  • germany
                                  #436
                                  Hi There,
                                  Uninstall the drivers in the software, there is an option for this in the menu. The IDs of the drivers to be uninstalled should be prefilled, just click on uninstall. Then reinstall and you should be good to go.
                                  • azozexd
                                    • Sep 2019
                                    • 47
                                    • Maroc
                                    #437
                                    MEC1663 or 1633?
                                    same error bƩcause chip is protected from reading you can just erase and create new file ec file with new dmi information and you can reprogram the mec1663
                                    • ajbernasko
                                      • Mar 2022
                                      • 229
                                      • ghana
                                      #438
                                      Kindly find the attached file and make sure to select MEC1663_256_ISP# to verify read or write before writing this file
                                      • pokyss1
                                        • Mar 2019
                                        • 57
                                        hello i have the same laptop you can give my the file merc thax and good day
                                        • volinakis
                                          • Jan 2021
                                          • 2704
                                          • N/A
                                          #440
                                          you have to provide your MEC dump and serial no. There are 4 versions for this model.
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            āœ… What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • Andreas_de
                                            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                            by Andreas_de
                                            Hello!
                                            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                            04-12-2025, 10:38 AM
                                          • re-atari
                                            Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                                            by re-atari
                                            Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                                            Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                                            02-03-2025, 06:49 PM
