mec 16xx dump with info block
  • dinarte
    • Sep 2021
    • 13
    • Brazil
    #261
    Re: mec 16xx dump with info block
    Originally posted by dinarte
    the solution presented in this topic only works for intel models, right?
    also, does it work with rt809F or just with rt809H?
    • SteK
      • Nov 2019
      • 23
      #262
      Have a look at this video, it explains alot, unfortunatley audio is in Russian but you can get the general idea.
      https://www.youtube.com/watch?v=XBcINkWU7xM&t=27s
      • spider300
        • Apr 2022
        • 34
        • morocoo
        #263
        Can you help me after reprogramming mec 1663 the password still remains is there any solution ??
        • AAAC
          • Jan 2020
          • 458
          • Mexico
          #264
          @spider300
          The first time we did one had a similar problem, then I suggested my friend to completely disconnect all source of energy for 1-2 minutes, after that the Supervisor Password was gone, may have been a coincidence or not, but that made a difference at the time.
          What's the ThinkPad model number and EC/KBC programmer you are using?
          • spider300
            • Apr 2022
            • 34
            • morocoo
            #265
            I use svod 4 device ThinkPad T14s
            • couillu76
              • Jan 2022
              • 39
              #266
              tried to unlock x13 gen 1 can read and write mec but password wont disappear
              what i doing wrong help ,using svod4
              • pokyss1
                • Mar 2019
                • 58
                • TUNISE
                #267
                Originally posted by RethoricalCheese
                Looks like JTAG reset resistor is marked in red box. Move the resistor next to that capacitor on the empty pads.
                I will test it tomorrow.
                hello thank you for this photo I have a vertyanove can you show me how I do it I have tag thank you for unlock bios t490s lenovo
                • pokyss1
                  • Mar 2019
                  • 58
                  • TUNISE
                  #268
                  hello I tested it on a lenovo t490s he told me invalid jtag
                  • volinakis
                    • Jan 2021
                    • 2748
                    • N/A
                    #269
                    Read post #239 you have photos.
                    • coolshrimp
                      • Nov 2016
                      • 54
                      I have a Lenovo T14 I need to remove Bios password.
                      I have the RT809H Programmer, I connected wires to JTAG but cannot read chip (MEC-1663).
                      Iv attached diagram of how its wired up.
                      I used diagram from another T14 model but the board is slightly different i cant find a diagram for my exact board.
                      Did I wire this right?
                      Does CLK go to TCK jtag point?
                      Someone said I need 10K pull up resistor, what points do i connect that to?
                      I don't see the missing resistor other point to my boards a bit different.
                      I know you cant edit out the password but if you re-flash the dump it clears iv been told. (rt809h + read MEC1663 + write MEC1663) then you use the maintenance tool to restore serial etc.
                      • akhtian
                        • Oct 2022
                        • 20
                        • Ukraine
                        #271
                        Hi. My t480s is not working, need EC rom for it. Please, help me) Give me working one)
                        • exe557
                          • Jan 2021
                          • 24
                          Actually you have to move the resistor for reading/writing and move it to original pad after you finished.
                          • coolshrimp
                            • Nov 2016
                            • 54
                            So I have the board view and schematics so I know I have the right points.
                            I have tried:
                            With and without 10k resistors on Jtag Pads 1-4
                            Pad 6 rst seems to be 3.3v but only has 3.3v when I put the missing resistor for that pad.
                            Iv tried with battery/charger connected.
                            But still I get error can't detect a chip model 0xFFFFFFFFF
                            Iv seen some can't be read and you simply get a donor EC file to simply wipe and write it back to the chip. But the chip would at least be detected and just fail reading correct?
                            Next step would be using the keyboard header points they have 10k resistors inline on the board.
                            • akhtian
                              • Oct 2022
                              • 20
                              • Ukraine
                              #274
                              Connection to from laptop to RT809H is wrong. Check it. I got similar situation yesterday))
                              • coolshrimp
                                • Nov 2016
                                • 54
                                LMAO who can see what I did wrong ����
                                Now while that was an issue, Iv fixed that but I still can’t get a read.
                                Are the pads wrong?
                                As I traced them back to the board.
                                Or should I be using the built in isp port and connecting Tx/RX?
                                • akhtian
                                  • Oct 2022
                                  • 20
                                  • Ukraine
                                  #276
                                  Connect it directly by small cables like on this picture.
                                  • coolshrimp
                                    • Nov 2016
                                    • 54
                                    See Image This Is How It is wired and where I put a jumper for R/W.
                                    • akhtian
                                      • Oct 2022
                                      • 20
                                      • Ukraine
                                      #278
                                      where did you find junper place?
                                      • coolshrimp
                                        • Nov 2016
                                        • 54
                                        From board view the white line it connects to a pad (1) and a resistor(circled in yellow) the connected pad (1) goes no where looks like a test point, the resistor is missing putting in the resistor gets 3.3v to the pad. and is connected to #RESET 3.3v line.
                                        Also every other pad connects directly under the MEC chip, only that pad (6) has an inline resistor (the missing one) on its way to the MEC.
                                        That’s prob why 10k resistors are recommended on the pads 1-4 but I seen 2 others say they’re not needed.
                                        • exe557
                                          • Jan 2021
                                          • 24
                                          This resistor needs to be moved from red to yellow position.
                                          If you cannot read after that, chip is locked. Just write extracted dump from bios update and it will be ok
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • hyperwood
                                            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                            by hyperwood
                                            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                            āœ… What I need:
                                            • A working 2MB BIOS dump
                                            • Matching NM-E471 Rev. 2.0, e.g. JY575
                                            06-25-2025, 02:28 PM
                                          • Andreas_de
                                            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                            by Andreas_de
                                            Hello!
                                            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                            04-12-2025, 10:38 AM
