Hp elitebook 840 g5 bios password
Re: Hp ellİtebook 840 g5 bİos password
There is a password in bios. can you help me please
bios 32mb 25q256
https://dosya.co/xybze6qn0n9d/ellite...40_g5.rar.html
rar pas . 1
*************Last edited by SMDFlea; 04-10-2023, 12:43 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Last edited by Vesko356; 02-07-2020, 10:55 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------
yes not working
but RethoricalCheese for the tool working.
tkans veskoComment
Re: Bios elitebook 840 g5
try .. if it doesn't go read again and put the bios here ..Last edited by SMDFlea; 04-10-2023, 12:54 PM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Hp elitebook 840 g5 bios clean
Hi guys
could anyone clean the bios password from this bin file, please?
Many thanksAttached FilesComment
Re: Hp elitebook 840 g5 bios clean
HP Elitebook 840 G5 Admin Bios PW Removal
I've got an HP Elitebook 840 G5 laptop with admin bios password.
I have managed to get a dump of the bios (I think) and have tried all the tools I can find on this site (and others) but am not having any luck.
I have tried the "HP BIOS unlock tool" sticky'd in this forum but unable to get that to run at all.
I have tried using the HP BIOS Password Removal Tool, but I am not able to get the USB to boot on my laptop.
Can someone please remove the admin password for me?
ThanksLast edited by SMDFlea; 04-10-2023, 12:54 PM.Comment
Re: HP Elitebook 840 G5 Admin Bios PW Removal
ThanksDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Yes the chip is still on the board. I was able to solder wires to it and used the CH341 to get a dump of it.
I don't understand what you mean by post its contents. I have posted the dump of the chip as an attachment to this post.
Please clarify what you mean?
This is my 2nd request, but will be first time I will be writing back to the chip.
ThanksComment
Please ignore this request. I have got it working.
For some reason the HP Bios Unlock Tool, did not run on my computer.
I ran it on a different computer, and it worked. It gave me an _unlcoked_ file, which I wrote back to the chip, and I am now able to get into the BIOS!
Very happy. This is the first bios password removal I have done.
Thanks to this site and all the contributors. You guys are doing a great thing!Comment
Hello
Can somebody assist me as to which chip is to be read for removing the BIOS password on this model?
I see here Winbond 25Q256JVEQ , is this the right one or not ? and how would you interface it without desoldering if you did it already?
I have full package of RT809H with 52 pieces, but I am thinking of extending some wires directly from the SOP8 SOIC8 clipper to the pins on the board without desoldering.
And lastly after making backup has somebody tried Mazif's tool to remove the password as the BIOS seems to be the same as in older models of Elitebooks?
thanksComment
Mazzif tool doesn't work since 8470p and later. My tool does but it varies on 840 G5 right now. Make copies of both chips and upload them to me.
You could try soldering. If it doesn't work straight away, you could try removing batteries, attaching charger, then turning laptop on, go to F10 screen, turn laptop off again but do not remove charger. Attach programmer to wires and try to read. If this doesn't work aswell then remove charger and try again. If still nothing then you need to desolder them.
But I suggest to invest in a hot air station like yihua 2008D or similar. They are cheap but quite good. Makes the job way easier.Comment
Hey everyone,
I recently bought a CH341A programmer, but I’m still not 100% sure what to do next. I couldn’t find any tutorials specifically for the HP Elitebook 835 G11, so I’m trying to piece things together.
From what I’ve learned so far, the process looks something like this:- Use the programmer to read the chip.
- Save a backup of the dump.
- Open the .bin file in Hex Workshop.
- Replace certain lines with “FF”.
- Write the modified file back to the chip.
- Boot the laptop → password should be gone.
I’ve also heard that some systems have both a Main chip and...-
Channel: BIOS Requests ONLY!
09-07-2025, 04:28 PM -
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
- Loading...
