hp 640 g2 password need bios dump
  • GValdameri
    • Apr 2020
    • 24
    • Brasil
    #101
    Re: hp Probook 640 g2 bios password
    Originally posted by lapfix
    Hope that you`re not using a clip! .
    I'm not using a clip.
    I removed the chip from the notebook and soldered it to the eprom reader.
    I read the eprom and then saved the file.
    after I unlocked it.
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      #102
      Can't agree about the clip thing. 95% of the time I use a clip on soic8 chips. It either works flawlessly or verification gives me an error which makes me read again. And errors almost always happen when I have broken a wire on my programmer.
      It is more about what programmer and software is used and how the user uses them. Success comes with knowledge here.
      But yes, reading unsoldered chips is easier but this doesn't mean that you don't have to verify what you read. It is always something you must do.
      • GValdameri
        • Apr 2020
        • 24
        • Brasil
        #103
        Can you help me?
        • RethoricalCheese
          • Mar 2013
          • 1519
          • Estonia
          #104
          Upload your files.
          You need a file with clean ME and VSS section from your file (if it is intact).
          • GValdameri
            • Apr 2020
            • 24
            • Brasil
            #105
            Upload your files.
            This is the file read with the Ch341 programmer version 1.29.
            Also attached with information about the motherboard.
            • lapfix
              • Mar 2020
              • 2742
              • my workshop
              #106
              This is the clean of your file
              • GValdameri
                • Apr 2020
                • 24
                • Brasil
                #107
                Did not work.
                Please, clean this file that I saved in version 1.32 of the eprom reader.
                This version 1.32 turns on the notebook, but the monitor does not turn on, and the fan runs at full speed.
                Thank you.
                • lapfix
                  • Mar 2020
                  • 2742
                  • my workshop
                  #108
                  1.32 clean ME
                  • peste
                    • Dec 2016
                    • 12972
                    • ROMANIA
                    #109
                    Originally posted by GValdameri
                    Did not work.
                    Thank you.
                    try..
                    • GValdameri
                      • Apr 2020
                      • 24
                      • Brasil
                      #110
                      1.32 clean ME
                      Does not work.
                      Turns on the notebook, but the monitor does not turn on, the fan runs at full speed and the NumLock and CapsLock lights flash.
                      • GValdameri
                        • Apr 2020
                        • 24
                        • Brasil
                        #111
                        Originally posted by peste
                        try..
                        Does not work.
                        Turns on the notebook, but the monitor does not turn on, the fan runs at full speed, the NumLock and CapsLock lights flash.
                        It also emits 3 beeps followed by another 2 beeps.
                        I left the notebook on for several minutes but nothing changes.
                        • peste
                          • Dec 2016
                          • 12972
                          • ROMANIA
                          #112
                          try it too
                          • GValdameri
                            • Apr 2020
                            • 24
                            • Brasil
                            #113
                            Dear friends.
                            With your help I managed to solve the problem.
                            When testing one of the versions sent by you, the notebook showed beeps and signals on the screen.
                            I identified that the 3 beeps followed by 2 bytes refer to a memory problem.
                            So I cleared the memory (one less problem).
                            after that, i cleaned the monitor connector (one more problem solved).
                            Then, after realizing that there was a signal on the screen, I placed the unlocked bin file that was generated by the programmer Ch341A version 1.32.
                            The notebook came back to life.
                            You are all great.
                            Thank you for the patience.
                            Thank you all.
                            I'm sorry if my English was not very clear.
                            • lapfix
                              • Mar 2020
                              • 2742
                              • my workshop
                              #114
                              Nice to hear that
                              • spying86
                                • Feb 2018
                                #115
                                Re: hp probook 640 G2
                                Hi all i Have hp Probook 640 G2 has bios password can anyone help me plzzz to remove the bios password and anyone can show me how to remove plzzzz
                                • lapfix
                                  • Mar 2020
                                  • 2742
                                  • my workshop
                                  #116
                                  Try mazzive tools : https://www.badcaps.net/forum/showth...ght=hpunlocker
                                  • thandazile85@gmail.com
                                    • Jun 2020
                                    • 4
                                    • south africa
                                    #117
                                    hi guys i have 640 g2 i hv programed the bios chip bt now it powers on bt no display
                                    • peste
                                      • Dec 2016
                                      • 12972
                                      • ROMANIA
                                      #118
                                      post the original bios
                                      • mhaita074
                                        • Aug 2020
                                        • Romania
                                        #119
                                        Hi, could you also help unlocking my bios?
                                        It's from a HP Probook 640 G2, bios version: N76 Ver.01.13
                                        • lapfix
                                          • Mar 2020
                                          • 2742
                                          • my workshop
                                          #120
                                          Try
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • kingiii
                                            downloaded bios is smaller than the original bios dump
                                            by kingiii
                                            Can someone help me explain how to fix the original bios when downloaded and exacted bios is much smaller than the original one?
                                            Thank you very much
                                            06-07-2025, 04:21 PM
