hp 640 g2 password need bios dump
  • Genova
    • Jan 2020
    • 118
    • FRANCE
    #41
    Re: hp Probook 640 g2 bios password
    I did not unsolder the chip I just put a clamp on the bios connected with the USB CH341A.
    Is it also valid like that?
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria šŸ‡§šŸ‡¬
      #42
      Yes of course, if you didn't unsolder the bios chip use the clamp to do the steps, just first remove the main and cmos battery.
      Become a Badcaps supporter
      Thanks to all supporters.​
      • Genova
        • Jan 2020
        • 118
        • FRANCE
        #43
        Possible protection is enabled. Press "Unprotect" and check datasheet
        Erasing memory...
        Does it take some time to erase ? or just few minutes ?
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria šŸ‡§šŸ‡¬
          #44
          If it takes more than 5 minutes to erase the chip, something is not OK.
          Remove the main battery and connect the charger to the board, then try to do the steps again.
            • 22083
            Thank you so much.
            I'm new in this practice so now what i need to do ? just write the bios with this file or erase bios before or other thing ?
            The bios posted by Vesko356 is for @Patalouf ,you need to backup and post your own bios.
            • Genova
              • Jan 2020
              • 118
              • FRANCE
              #46
              @ SMDFlea
              Sorry for the mistake @patalouf was our first personnal account on badcap forum.
              Genova is our main account for office I did not pay attention as i connect at home and also at work
              • Genova
                • Jan 2020
                • 118
                • FRANCE
                #47
                ok I will try your suggest.
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria šŸ‡§šŸ‡¬
                  #48
                  And yes, as SMDFlea wrote, if you don't have the unlocked bios bin file for your machine, you must first read an verify the bios chip from your machine, then post the file here so we can unlock the file for you, and then do the steps mentioned above to write the unlocked bin file back to bios chip!
                  Also if the erace/write/verify operations failed after manipulation with the charger, try to do the job with the version 1.4.1 of AsProgrammer
                  Download link
                  • Genova
                    • Jan 2020
                    • 118
                    • FRANCE
                    #49
                    Erasing in progress...
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria šŸ‡§šŸ‡¬
                      #50
                      Excellent...
                      • Genova
                        • Jan 2020
                        • 118
                        • FRANCE
                        #51
                        All is dont correctly but now the laptop won't start :/
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria šŸ‡§šŸ‡¬
                          #52
                          This is not possible, you probably doing something wrong, did the verification of the written file completed successfully by the AsProgrammer?
                          • Genova
                            • Jan 2020
                            • 118
                            • FRANCE
                            #53
                            Yes verification completed
                            • Genova
                              • Jan 2020
                              • 118
                              • FRANCE
                              #54
                              We are trying again with AsProgrammer 1.41 with the unlock, erase, programm, verify.
                              In progress...
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria šŸ‡§šŸ‡¬
                                #55
                                OK, now read the chip with the AsProgrammer and compare the content of the chip with the unlocked bin file. You can do it with Total Commander.
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria šŸ‡§šŸ‡¬
                                  #56
                                  In progress...
                                  OK, good.
                                  • Genova
                                    • Jan 2020
                                    • 118
                                    • FRANCE
                                    #57
                                    the beginning and the end is the same
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria šŸ‡§šŸ‡¬
                                      #58
                                      What do you mean?
                                      The unlocked bin file from my post and the content of the chip after programming must be the same - absolutely the same you must check the content of the two files with Total Commander, if the program showing any difference between the two files you doing something wrong!
                                        • 22083
                                        The ME firmware in your bios was corrupt.Try this bios with your pass removed and new ME firmware .
                                        • Genova
                                          • Jan 2020
                                          • 118
                                          • FRANCE
                                          #60
                                          How can i read in total commander the content of the chip ??
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • dell_bios
                                            Need unlocked BIOS dump for W25Q64FV (Admin Password removal)
                                            by dell_bios
                                            I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
                                            The board has three SPI flash chips:
                                            - W25Q64FV (main BIOS)
                                            - W25Q32FV (EC/TPM)
                                            - W25X10CL (configuration)
                                            I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
                                            The dump contains protection that needs to be removed.
                                            If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
                                            I’m also happy to share my dump for comparison if needed.
                                            Laptop model: [please specify, e.g....
                                            10-16-2025, 04:28 PM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • ArkzG
                                            [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                            by ArkzG
                                            Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                            What I currently have available:
                                            - Model: FA506NF (2021)
                                            - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                            - Tools: CH341A programmer ready to use
                                            Does anyone have either a clean 2MB .bin dump of this model,...
                                            09-26-2025, 09:34 PM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
