hp 640 g2 password need bios dump
  • mhaita074
    • Aug 2020
    #121
    Re: hp Probook 640 g2 bios password
    Worked perfect, many thanks!!!!
    • fyaagoub
      • 269
      • maroc
      #122
      HP Probook 640 G2 Bios Password
      hi friends please clean this bios password HP Probook 640 G2 thank you.
      • peste
        • 13718
        • ROMANIA
        #123
        Re: HP Probook 640 G2 Bios Password
        https://www.badcaps.net/forum/showthread.php?t=79956
        • fyaagoub
          • 269
          • maroc
          #124
          Thank you
          • dr.tubes
            • Jan 2020
            • 21
            • Serbia
            #125
            Hi friends,
            can you please clean this bios password HP Probook 640 G2?
            Thank you!
              • 22078
              Originally posted by dr.tubes
              Hi friends,
              Thank you!
              Use the HP Unlocker, the link is at post #2 .
              • dr.tubes
                • Jan 2020
                • 21
                • Serbia
                #127
                I can not start the exe on my laptop.
                Also, Probook 640 G2 is not on the list of supported models.
                [SUPPORTED MODELS]
                HP 6550B, HP 2530P, HP 6930P, HP 8530W, HP 8460P, HP 6460B, HP 2230S ,HP 6455B, HP 2730P, HP 8530P, HP 2740P, HP 4310S, HP s4510, HP 6535B, HP 6730B, HP 6735B, HP 8730W, HP 2560P, HP 8560P, HP 8440P, HP 8540W, HP 8560W
                  • 22078
                  [SUPPORTED MODELS]
                  Read further down from the 1st link in the post,read the instructions,download and use the attached file - HPUnlocker_v1.rar
                  • peste
                    • 13718
                    • ROMANIA
                    #129
                    [SUPPORTED MODELS]
                    try..
                    • dr.tubes
                      • Jan 2020
                      • 21
                      • Serbia
                      #130
                      Originally posted by peste
                      try..
                      I did what you told me and it is working.
                      Thanks so much.
                      • Rockton
                        • Dec 2020
                        • 27
                        Re: hp 640 g2 need bios dump
                        My HP 640 G2 was dead.. Suspect Bios corrupt...
                        I dumped the BIOS. looking for a clean version to load back on.
                        • peste
                          • 13718
                          • ROMANIA
                          #132
                          try..
                          • Rockton
                            • Dec 2020
                            • 27
                            No luck with above flash. Hit power button, keyboard lights up as do WiFi and Spk buttons.. Orange charge light flashes 3 times then stays solid.
                            • Rockton
                              • Dec 2020
                              • 27
                              After finding a Flash in the forum called 640OK I loaded the chip, now the laptop has different symptoms.. Cap Locks key flashes 5 times.. keyboard lights up for about 10 seconds, CPU fan Hums.. but nothing on the monitor.
                                • 22078
                                Is that bios you posted at #31 the original.Whats the history of the laptop ,has someone tried to fix it before ? .The 640 g2 has 2 different bios versions , N76 and N87.The bios you posted has version N76 .
                                Is this the 640OK bios you tried, post #1 - https://www.badcaps.net/forum/showthread.php?t=82222 .If you open that bios with MEAnalyzer you`ll see that the ME firmware is "Initialised" which means the ME FW is "Dirty" as its already been booted on another machine and married to the chipset.Thats why your results are different now.You need a bios with clean ME firmware.
                                • Rockton
                                  • Dec 2020
                                  • 27
                                  Is the BIOS original.. No.. The BIOS has been replaced at one time before. After the BIOS was changed the laptop ran for a couple of months. The BIOS chip was purchased programmed online. Popped it in and it worked.
                                  The BIOS I posted in 31 is what I read of the chip in the laptop.
                                  The 640OK Bios is attached here.
                                    • 22078
                                    Try these.If they don`t work theres others (N76) in this thread with clean ME firmware.
                                    • Rockton
                                      • Dec 2020
                                      • 27
                                      No luck with the above two.. will keep trying THx
                                        • 22078
                                        Not a bios issue. Try another charger for a start,a genuine one with enough wattage, and clean the RAM gold fingers with an eraser if they`re tarnished looking .
                                        • newjan
                                          • Mar 2016
                                          • 67
                                          • Egypt
                                          #140
                                          hi i need bios for
                                          6050a2566301
                                          can any one help me
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • dell_bios
                                            Need unlocked BIOS dump for W25Q64FV (Admin Password removal)
                                            by dell_bios
                                            I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
                                            The board has three SPI flash chips:
                                            - W25Q64FV (main BIOS)
                                            - W25Q32FV (EC/TPM)
                                            - W25X10CL (configuration)
                                            I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
                                            The dump contains protection that needs to be removed.
                                            If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
                                            I’m also happy to share my dump for comparison if needed.
                                            Laptop model: [please specify, e.g....
                                            10-16-2025, 04:28 PM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • ArkzG
                                            [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                            by ArkzG
                                            Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                            What I currently have available:
                                            - Model: FA506NF (2021)
                                            - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                            - Tools: CH341A programmer ready to use
                                            Does anyone have either a clean 2MB .bin dump of this model,...
                                            09-26-2025, 09:34 PM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
