hp 640 g2 password need bios dump
    Re: hp Probook 640 g2 bios password
    Originally posted by lapfix View Post
    Hope that you`re not using a clip! .
    I'm not using a clip.
    I removed the chip from the notebook and soldered it to the eprom reader.
    I read the eprom and then saved the file.
    after I unlocked it.
      Can't agree about the clip thing. 95% of the time I use a clip on soic8 chips. It either works flawlessly or verification gives me an error which makes me read again. And errors almost always happen when I have broken a wire on my programmer.
      It is more about what programmer and software is used and how the user uses them. Success comes with knowledge here.
      But yes, reading unsoldered chips is easier but this doesn't mean that you don't have to verify what you read. It is always something you must do.
        Can you help me?
          Upload your files.
          You need a file with clean ME and VSS section from your file (if it is intact).
            Upload your files.
            This is the file read with the Ch341 programmer version 1.29.
            Also attached with information about the motherboard.
              This is the clean of your file
                Did not work.
                Please, clean this file that I saved in version 1.32 of the eprom reader.
                This version 1.32 turns on the notebook, but the monitor does not turn on, and the fan runs at full speed.
                Thank you.
                  1.32 clean ME
                    Originally posted by GValdameri View Post
                    Did not work.
                    Thank you.
                    try..
                      1.32 clean ME
                      Does not work.
                      Turns on the notebook, but the monitor does not turn on, the fan runs at full speed and the NumLock and CapsLock lights flash.
                        Originally posted by peste View Post
                        try..
                        Does not work.
                        Turns on the notebook, but the monitor does not turn on, the fan runs at full speed, the NumLock and CapsLock lights flash.
                        It also emits 3 beeps followed by another 2 beeps.
                        I left the notebook on for several minutes but nothing changes.
                          try it too
                            Dear friends.
                            With your help I managed to solve the problem.
                            When testing one of the versions sent by you, the notebook showed beeps and signals on the screen.
                            I identified that the 3 beeps followed by 2 bytes refer to a memory problem.
                            So I cleared the memory (one less problem).
                            after that, i cleaned the monitor connector (one more problem solved).
                            Then, after realizing that there was a signal on the screen, I placed the unlocked bin file that was generated by the programmer Ch341A version 1.32.
                            The notebook came back to life.
                            You are all great.
                            Thank you for the patience.
                            Thank you all.
                            I'm sorry if my English was not very clear.
                              Nice to hear that
                                Re: hp probook 640 G2
                                Hi all i Have hp Probook 640 G2 has bios password can anyone help me plzzz to remove the bios password and anyone can show me how to remove plzzzz
                                  Try mazzive tools : https://www.badcaps.net/forum/showth...ght=hpunlocker
                                    hi guys i have 640 g2 i hv programed the bios chip bt now it powers on bt no display
                                      post the original bios
                                        Hi, could you also help unlocking my bios?
                                        It's from a HP Probook 640 G2, bios version: N76 Ver.01.13
                                          Try
