hp 640 g2 password need bios dump
    • 20977
    Re: hp 640 g2 need bios dump
    Try this bios .
    • damian13030
      • Mar 2020
      • 10
      • Polska
      #82
      not work.
      Without bios, it doesn't start at all.
        • 20977
        Ok try this bios,it has no DMI so you`ll have to fill in your serial etc with wndmifit/BCU ,this is a known good bios so if this one doesn`t work your problem is somewhere else .
        • damian13030
          • Mar 2020
          • 10
          • Polska
          #84
          Did not work. No sound signal, capslock blinks 5x.
          The sound signal has always been present in previous dumps.
          • rehan
            • Apr 2020
            • 8
            • pakistan
            #85
            how to remove hp 640 g2 and elite book 1040 g3 bios passsword plz help if u can
            • peste
              • Dec 2016
              • 12859
              • ROMANIA
              #86
              try this tool.
              https://www.badcaps.net/forum/showth...ght=hpunlocker
              • GValdameri
                • Apr 2020
                • 24
                • Brasil
                #87
                Re: hp Probook 640 g2 bios password
                Hi friends.
                I'm new here.
                I have the same problem on my notebook HP 640 G2.
                I bought an eprom recorder and tomorrow I must have it at home.
                I want to know on which line will I find the BIOS lock code, so that I can remove it?
                Thank you very much. ;-)
                • RethoricalCheese
                  • Mar 2013
                  • 1518
                  • Estonia
                  #88
                  There isn't a certain line. The address is slightly different even on same model.
                  • GValdameri
                    • Apr 2020
                    • 24
                    • Brasil
                    #89
                    I understand.
                    But in the hexadecimal file editor, what am I looking for?
                    • mermel
                      • Nov 2016
                      • 17
                      • Romania
                      #90
                      hello ... I have a hp 640 g2 with the password on the bios, you can help me with this ... I tried with a bios from here and it gives me an error to start something of serial identification ... thanks, I attach the bios file
                      http://www.filedropper.com/hpg2reads
                      • peste
                        • Dec 2016
                        • 12859
                        • ROMANIA
                        #91
                        try..
                        • mermel
                          • Nov 2016
                          • 17
                          • Romania
                          #92
                          tnx it work …. hello form Romania
                          • RethoricalCheese
                            • Mar 2013
                            • 1518
                            • Estonia
                            #93
                            Originally posted by GValdameri
                            I understand.
                            Use my HPUnlocker tool and compare both files using hex editor.
                            You are looking either for BiosUser00 or UserCred. Depending on what gen machine you have.
                            • GValdameri
                              • Apr 2020
                              • 24
                              • Brasil
                              #94
                              I tried to run your program, but it presents me with the following message.
                              "Failed to execute script HPUnlocker"
                              I use Windows 10 and I'm running as an administrator, I also disabled my Norton, but even in compatibility mode with windows xp or windows7 it displays the error message.
                              Attached is the original file.
                              Thank you for help.
                              • RethoricalCheese
                                • Mar 2013
                                • 1518
                                • Estonia
                                #95
                                Did you just download and open exe? Or drag and drop your .bin file?
                                Please read first post on how to use it.
                                • GValdameri
                                  • Apr 2020
                                  • 24
                                  • Brasil
                                  #96
                                  I'm sorry, I'm sorry, I'm sorry.
                                  I didn't really pay attention.
                                  I dragged the file to your program and it identified the "UserCred".
                                  PERFECT.
                                  Now I am recording the chip and then I will test the notebook.
                                  Just an observation.
                                  I downloaded several programs to read the bin files, but none of them could find the word "UserCred".
                                  Only yours.
                                  Thanks for your help!!!
                                  • RethoricalCheese
                                    • Mar 2013
                                    • 1518
                                    • Estonia
                                    #97
                                    That is because it is UserCred in unicode. That means it is written with 00-s in between each character. Thus it is actually seen as U.s.e.r.C.r.e.d
                                    Hex editor or uefitool work fine for that, just use unicode when searching for UserCred or use regular string when searching for U.s.e.r.C.r.e.d
                                    • GValdameri
                                      • Apr 2020
                                      • 24
                                      • Brasil
                                      #98
                                      Hello my friends.
                                      I read the original BIOS and unlocked it with the friend's tool, RethoricalCheese.
                                      But when testing the new unlocked BIOS, the notebook won't turn on.
                                      Even if you reset the original BIOS with the password, the notebook will not turn on.
                                      When placing another BIOS that I got here on this forum, the computer turns on, but emits 4 audible warnings and the monitor does not turn on.
                                      My knowledge is limited.
                                      Please, could someone help me.
                                      Thanks.
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1518
                                        • Estonia
                                        #99
                                        Seems like you did not verify the file you read. So your backup is faulty.
                                        • lapfix
                                          • Mar 2020
                                          • 2732
                                          • my workshop
                                          #100
                                          Hello my friends.
                                          Thanks.
                                          Hope that you`re not using a clip! .
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • kingiii
                                            downloaded bios is smaller than the original bios dump
                                            by kingiii
                                            Can someone help me explain how to fix the original bios when downloaded and exacted bios is much smaller than the original one?
                                            Thank you very much
                                            06-07-2025, 04:21 PM
