Macbook 2018 above firmware password
  • Siddig
    • Jun 2017
    • 275
    • Sudan
    • electronic repairing (hardware laptop) ,Reader, history and Politic
    what kind of security for Macbook 2018 above.
    its not EFI type !!!!
    I have try with hex edit but I didn't find it $SVS .
    how I can clear password from dump.
    and
    tell me whats good connector for it.
    need help
    clean dump attach
  • KvnTM
    • May 2018
    • 434
    • Board Repair
    Re: Macbook 2018 above firmware password
    You may take a look at this:
    About Activation Lock on your Mac
    • ibo
      • Oct 2019
      • 121
      • Turkiye
      is this your serial number C02XM3HSJHC9
      • Siddig
        • Jun 2017
        • 275
        • Sudan
        Pro this dump for example.
        I want know how to remove frimware from bios dump or T2 chip.
        • KvnTM
          • May 2018
          • 434
          • Board Repair
          Does it have EFI Password or Activation Lock?
          Activation Lock is the same as iCloud Lock on iPhones. Not sure if you could get around that.
          • Siddig
            • Jun 2017
            • 275
            • Sudan
            I get it that. It's been like iphone activate on line.
            But
            I am ask about soultion
            • ibo
              • Oct 2019
              • 121
              • Turkiye
              there is no solution yet what i know, only SCBO file from apple
              • azanwaqas771
                • Feb 2019
                • 54
                • Pakistan
                how to read t2 chip
                • lobz
                  • Jul 2020
                  • Andorra
                  macOS Catalina allows you to block the firmware from showing the seed that Apple needs in order to remove the password. Type this in Terminal: sudo firmwarepasswd -disable-reset-capability.
                  • MughalG
                    Seeker
                    • Aug 2012
                    • 9
                    • Dubai
                    • Apple
                    and
                    need help
                    clean dump attach
                    $SVS will not work for T2
                    • 5chematic
                      • Jun 2019
                      • 77
                      • Computers, Electronics, Programming
                      Hey Siddig, can I ask where or how you managed to find the uson chip on your model? I cannot find it any where on my board. it supposed to be a 4mb chip. my board is: A2141 820-01700-A
                      • 5chematic
                        • Jun 2019
                        • 77
                        Hey Siddig, BTW, do not try unlocking it via the image. I unlocked mine using another mac. just link them both and then you can unlock them. now the reason I want to dump the image is because I want to modify it.
                        • RethoricalCheese
                          • Mar 2013
                          • 1519
                          • Estonia
                          Could you tell a bit more about that?
                          • Marc97
                            • Jan 2016
                            • 193
                            • Phillipines
                            • New Idea
                            and
                            need help
                            clean dump attach
                            . Do you have pict where efi IC was located
                            • piernov
                              • Jan 2016
                              • 4438
                              • France
                              EFI is stored on the encrypted NAND chips and fed to the PCH by the T2.
                              • Nico Latour
                                Banned
                                • Sep 2019
                                • 52
                                • france
                                • Do not contact me for unlocks or questions whether I share methods or keygens, if I want to help som
                                wrong wrong wrong! the 4mb bin its only thing you can do is change serial no unlock!
                                4mb bin you can read and manage with neo, if you have a good macbook and copy efi free bin to the same locked macbook dont work, also read locked mac and after unlock read again and compare and change is not working! activation lock is not only linked in serial!
                                ps the chip is a wson 2x3 1,8 volt
                                • imranromi
                                  • Jan 2015
                                  • 1297
                                  • Pakistan
                                  What about Mdm after change Serial number?
                                  • fatguy1121
                                    • Jan 2021
                                    Have you guys considered hijacking the iCloud dns and pointing it to a local server that is emulating the correct response to report that it is not locked just long enough to unlock it to disable secure boot?
                                    • levi12345
                                      • Mar 2021
                                      • city
                                      Hi I need your help.Anyone of you have the original 4mb .bin file for a2141 820-01700 without serial number which you can read and manage ?
                                      • Stephen
                                        Meow Meow MEOW!
                                        • Apr 2020
                                        • 685
                                        • Apple Products and Live Broadcasting
                                        How does one go about this? I have a 16” in inventory and it be a blessing to learn how to do this!
                                        sigpic
                                        MEOWING IN THE IMPOSSIBLE UNIVERSE!
                                        • D6i
                                          MacBook Air 2017 EFI Firmware Password Unlock - SCBO Request
                                          by D6i
                                          I accidentally locked myself out of my MacBook Air 2017 after a failed OpenCore installation. I need an SCBO file to reset the firmware password.
                                          Model: MacBook Air 2017
                                          Hash Code: FV9749303Q4J22GDC35A225DD456B2B91
                                          Thanks in advance for your help!
                                          04-12-2026, 02:30 PM
                                        • megacap
                                          MacBook Pro Retina 15.4-inch (2018) A1990 820-01041 No charge, no power after letting battery die and not using for a bit
                                          by megacap
                                          So I this MacBook Pro Retina 15.4-inch (2018) A1990 laptop that suddenly will not charge or start. It was working fine before. It would charge and was starting up normally from sleep. The only thing abnormal is that it seemed to be getting battery health warnings. Maybe a precursor of what was to come. Let it sit in sleep mode for about a week. Now it seems completely dead. Seems like no power at all. No lights, no fans, no screen, no touchpad clicks. Battery charger, which is apple 87w, doesn't get hot at all when plugged in. Charger will charge an iphone just fine though....
                                          06-05-2026, 12:38 PM
                                        • mferna14
                                          Password removal on MacBook Pro A2159
                                          by mferna14
                                          Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                                          05-13-2025, 04:16 PM
                                        • weisian
                                          VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
                                          by weisian
                                          I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
                                          1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
                                          2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
                                          03-12-2026, 05:54 AM
                                        • chriswfrye21
                                          HP 255R G10 – BIOS Admin Password Locked, Cannot Enter BIOS (Need Guidance / SMC.bin Help)
                                          by chriswfrye21
                                          I’m working on an HP 255R 15.6" G10 Notebook PC that has a BIOS Administrator / Setup password I cannot bypass. I can boot Windows normally, but F10 is completely blocked unless the password is entered. I do not know the password.
                                          This is not a Power‑On Password. This is a BIOS Admin password stored in NVRAM, and the system will not allow BIOS access at all.
                                          I’m posting here to get help identifying the correct procedure, dump, or method needed to clear the password on this model. System Details
                                          Model: HP 255R 15.6 inch G10 Notebook PC SK...
                                          08-10-2026, 03:49 AM
