late 2013 13" Macbook pro firmware password HELP
  • cyber16
    • Oct 2021
    • 16
    I have done many of these over several years, But its been some time since the last time.
    Normally I dump the rom 3-5 times and compare before anything else
    Which I do have clean dumps, then I would search for $SVS and ff ff out every thing that follows that including the $SVS all the way down to the next large series of ff ff
    Upon 1st boot I will zap pram a few times, Password IS GONE
    yet the laptop is acting strange, powers off all of a sudden for no apparent reason.
    Besides that, the trackpad clicker does not work in internet recovery and other odd things.
    Maybe I remove part of the config? IDK
    For some reason it seemed like I had to ff out much more than I recall doing in the past, maybe I took too much out.
    Nonetheless, can someone just remove the password from this LOCKED dump, Once done I will compare with my work to see where I screwed up.
    Thank you.
  • alassane.dontavius
    Banned
    • Jan 2023
    • 28
    Re: late 2013 13" Macbook pro firmware password HELP
    Originally posted by cyber16
    i have done many of these over several years, but its been some time since the last time.
    Normally i dump the rom 3-5 times and compare before anything else
    which i do have clean dumps, then i would search for $svs and ff ff out every thing that follows that including the $svs all the way down to the next large series of ff ff
    upon 1st boot i will zap pram a few times, password is gone
    Maybe i remove part of the config? Idk
    for some reason it seemed like i had to ff out much more than i recall doing in the past, maybe i took too much out.
    Nonetheless, can someone just remove the password from this locked dump, once done i will compare with my work to see where i screwed up.
    Thank you.
    try this and let me know
    • cyber16
      • Oct 2021
      • 16
      Thank you, I will reply back once I write it, it will be a couple hours
      • cyber16
        • Oct 2021
        • 16
        Error: Image size (8388672 B) doesn't match the expected size (8388608 B)
        No size error if I write back the original locked dump
        • peste
          • 13199
          • ROMANIA
          read the original bios again and post again.. the laptop works strangely before deleting the password or after deleting the password..
          • cyber16
            • Oct 2021
            • 16
            No the laptop appeared to work just fine there is no liquid damage or anything like that. It would actually boot right into OS.
            I've noticed it's even got a power on issue now it's intermittent trying to get it to power on just to do a read and write with MY diy unlocked bin, with these particular MacBook Pros I learned a while ago you're powered on until you hear the chime and then press and hold the power button and do your reading write at that time.
            Like I said I check summed all the dumps to make sure they were identical/clean
            • peste
              • 13199
              • ROMANIA
              post the full name and model of the EMC laptop, motherboard model, serial number S/N, ETC
              • cyber16
                • Oct 2021
                • 16
                late 2013 macbook pro 13.3"
                Model A1502
                ECM 2678
                SN C02LGAEHFGYY
                i5 2.4GHz
                4GB
                128GB Fast Storage
                Actual logic board model number appears to be on the other side of the board sandwiched under the keyboard.
                I am attaching a locked bin
                As well as my DIY unlock that is causing a bunch of issues.
                • peste
                  • 13199
                  • ROMANIA
                  Model A1502
                  ECM 2678
                  SN C02LGAEHFGYY
                  i5 2.4GHz
                  4GB
                  128GB Fast Storage
                  try this..
                  • cyber16
                    • Oct 2021
                    • 16
                    THANK YOU SIR
                    That appears as it resolved issue, now I need to do some comparison to figure out what the heck I did wrong. I've unlocked many over the years I came from ghostlyhaks I've had a few of their clips use on a raspberry PI 3 over all these years.
                    It just appeared that there was an awful lot of data following that $SVS until the next zeroed out area of size.
                    • peste
                      • 13199
                      • ROMANIA
                      THANK YOU SIR
                      you deleted too much..
                      • zaler808
                        Macbook Pro 15" Late 2013 A1398 Turn off randomly but after workload it shows black screen with fans spinning
                        by zaler808
                        Hi guys, this my first post but i want to be brief about it, i recently got a MBP L2013, the problem was that after some use the macbook shutted down randomly, at first i suspected to be the battery, and after connecting it with the charger i noticed that i didn´t shut, but after an hour or so it shutdown, after that i started searching a solution to my problem, but my brother tried to help me to find the problem and it that process to replicate the problem he reproduced a 4k video in multiple tabs and not much time after the macbook shutdown to never power again, what i noticed was that the...
                        05-23-2024, 05:17 PM
                      • Gigabit2
                        Apple MacBook Pro 15" Retina i7 2.3Ghz 16GB Late 2013 water damaged - no power
                        by Gigabit2
                        I have acquired this Apple MacBook Pro 15" Retina i7 2.3Ghz 16GB Late 2013 and it is not powering on. No lights on charger and no chime.
                        Inspecting the unit shows liquid damage, indicators have gone red.
                        Can somebody help me to diagnose and repair the unit or where I should start?
                        Thank you all.
                        06-23-2023, 07:11 AM
                      • mferna14
                        Password removal on MacBook Pro A2159
                        by mferna14
                        Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                        05-13-2025, 04:16 PM
                      • Reda123456
                        MacBook Pro (Retina, 15-inch, Late 2013) A1398 need bios
                        by Reda123456
                        MacBook Pro (Retina, 15-inch, Late 2013)A1398
                        I need bios for this macbook
                        06-17-2022, 07:11 AM
                      • ritalo
                        MacBook Air 13 2014 - Remove EFI password
                        by ritalo
                        I have a MacBook Air 13 inches 2014.
                        I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
                        I know how to remove the password with a usb programmer.
                        I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
                        Then I have to find this value in the file : $SVS because it indicate where is the password.
                        But I can't find the value.
                        I have attached the file​
                        Thank...
                        05-14-2024, 12:10 PM
