MacBook Pro 2018 - A1990 Dead - not charging - only 5V
  • mon2
    • Dec 2019
    • 14691
    Ok - good on both updates. You should not use the connector with the burnt pads. Is the paddle board from the other side available for use? Any issues with the contacts over there? Do take a known good paddle board and share it across the 2 sides of the logic board but only after the power is OFF at the power adapter. Never swap anything while 'hot' on.
    If the adapter is a known good power delivery adapter (ideally is from Apple) and can offer the 20V power delivery contract then you can continue to use it here. We use a few 3rd party models rated @ 100W and higher. The cable between the power delivery brick and the logic board must be a special cable with e-marker support. Otherwise, the current support will be much lower.
    The general guideline is to review the LDO (power) rails on each power delivery controller (CD3215/CD3217, etc. - named as 'ACE' controller in the schematic).
    Review this article by piernov and others:
    CD3215 Bootup Sequence - LogiWiki
    • envym
      MacBook Pro 2018 with Activation Lock
      by envym
      Hi everyone!
      I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
      I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
      06-27-2025, 08:54 AM
    • mattknudstrup@gmail.com
      2018 Macbook Pro A1990 2Tb, SSD1 dead
      by mattknudstrup@gmail.com
      Hello All,
      My 2018 Macbook Pro (2TB) crapped out recently, won't turn on. Diagnosed so far as shorted second terabyte SSD1. Question for the forum. I'm thinking about removing or disabling SSD1 and just using SSD0 which will still give me 1Tb usable. I'm assuming all the boot up stuff is all in SSD0. Am I correct about this? If so is there a way to disable SSD1 without removing all the associated components? Will just powering it down do the trick?
      I currently have U9580 (TPS62180) removed as it was fried but that is as far as I have gone with it. In other words I...
      08-30-2023, 09:15 AM
    • pcash0007
      Dead 2018 Macbook Pro A1990 820-01041-07 stuck at 5V 0A
      by pcash0007
      First time looking at a logic board this closely, learnt enough from videos and forums here to be dangerous
      I was doing a OS update when the screen went blank at some point. Does not seem to be in DFU mode (checked using apple configurator).
      PPDCIN_G3H is 5.16V​
      PPBUS_G3H is 0.045V
      Resistance between TP_PPBUS_G3H and ground is 23.8 Ohms (which seems low)
      F7000 and F7001 seems fine.
      From what I learnt seems like there might be short on the down side on PPBUS_G3H.
      Is injecting low voltage and see what...
      03-07-2024, 06:19 PM
    • netboy69
      Macbook Pro 15, A1990 2018, showing recovery not dfu, error 9 when restore, HELP
      by netboy69
      Hi to all i have a faulty a1990 from 2018, no liquid damage, died during update, now on configurator i see recovery not dfu, and i get error 9. caps around u7701 show short after removing u7701 and shorted caps still short. can any help....
      02-07-2024, 04:34 PM
    • drlarsen
      MacBook Air M1 A2337 battery/charging issue
      by drlarsen
      Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
      I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
      On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
      After some hours, the battery status did not improve. Restore via DFU did not help.
      I connected the power adapter to a Kill-a-Watt...
      07-17-2025, 02:35 PM
