Hello, I have a DELL XPS 9550 which powers on and does nothing. I am suspecting the bios to be corrupted. I noticed that this laptop has 3 flash IC's. Can somebody please provide me a working dump of all 3 ic's UH8 16MB, UT5 4MB, UT2 1MB? Thank you in advance!
DELL XPS 9550 bios dumps
Every donation made will go towards server fees and maintenance costs. -
Re: DELL XPS 9550 bios dumps
Thanks for the reply. I tried those dumps. At first boot I get the bottom orange led's blinking, but no new behavior. Does anybody have the full set of 3 dumps for this laptop? Thanks!Comment
Do you have your original dump? I've extracted bios file from Dell bios update exe-s on newer models and merged them with original dump. Thus far I have only needed to program the 16MB EEPROMs.Comment
Hi, If I upload here old bios, can you help me? Has the same problem like man above.
Thank youComment
try...Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
put the original bios here, someone who has the time, can fix it.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Please, if anyone able to "repair it" I appreciate it. Many thanks.Attached FilesComment
Try this bios .Attached FilesComment
Worked like a charm. Thank you for sharing.
I had to switch back to UEFI in the settings to boot Windows.
Just FYI so you won't go around and desolder all 3 bioses to figure out which 0ne it is.
It is the one closest to the PCH - W25Q128BVLast edited by ZixuTech; 05-30-2020, 09:49 PM.Comment
I have tried this image but i have a problem.. the laptop posts with the cleared ME BIOS, but only once, i can enter bios and it stay there working just fine, but after reboot it's back to black screen no post.
Any one have an idea what i could do?Comment
I am facing a similar, probably worst, issue with a XPS 15 9550 that is almost dead :
- first push on power button = lights on
- second push = nothing, no fan spin, no screen back-light.
- power led goes off after 10 sec
- LCD auto-test (d+power) never fires
- battery side indicator lights up, but i suspect it always display full battery, although that may be wrong.
- Battery charging led lights up when connected to PSU.
I tried to flash the main bios with the bin that you guys had success with, but with no luck. I also flashed the to other W25Q chips with bins i got from a working identical model. No better.
Its probably worthless, but i want to give it a final try using three bins extracted from a model that was saved by flashing the clean_me rom provided here. I dont't now, maybe those i have don't match and fail when calling each other on incorrect physical addresses.
Can anyone who successfully flashed the main clean_ME be kind enough to dump the bin of the two other W25Q and deposit them here?
Thanks in advanceComment
Here are the two dumps.Attached FilesComment
I HAVE A PASSWORD IN SETUP in this casa please helpAttached FilesComment
Hi could someone help me fix my bios. turn on but no display, has keyboard backlight. i try
clean me with intel fitc but can't open file from the dump. i've flashed with File Type: zip XPS_9550_1.11.2 ME_CLEAN.BIN.zip above got it to display but me drowngrade error and
can't boot. many thanksAttached FilesComment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... - Loading...
