DELL XPS 9550 bios dumps
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    Re: DELL XPS 9550 bios dumps
    Originally posted by lngcs
    hi could someone help me fix my bios. Turn on but no display, has keyboard backlight. I try
    clean me with intel fitc but can't open file from the dump. I've flashed with file type: Zip xps_9550_1.11.2 me_clean.bin.zip above got it to display but me drowngrade error and
    can't boot. Many thanks
    try
    • lngcs
      • Jul 2011
      • 72
      Tried and behave like my original dump. no display.
        • 22276
        Try this one .
        • lngcs
          • Jul 2011
          • 72
          tried this one power button led comes on for 20 sec then off and that's it. it repeat if turn on again.
            • 22276
            Give it time,wait 5 minutes
            • lngcs
              • Jul 2011
              • 72
              #26
              tried this one and power on for about w20sec then turn off and repeat the same if power on again
                • 22276
                did you remove the CMOS battery before flashing the bios .
                • lngcs
                  • Jul 2011
                  • 72
                  #28
                  after a few mins it turn off. turn on again manually and now it is life.thank you so much.
                    • 22276
                    Great,
                    • abubin
                      • Sep 2021
                      • noname
                      #30
                      Originally posted by crotale
                      I HAVE A PASSWORD IN SETUP in this casa please help
                      Me too have a BIOS password. Have resolved the issue? If yes, how?
                      • Alassane
                        • Oct 2018
                        • 65
                        • MALI
                        #31
                        Dell XPS 15 9550 AAM00 LA-C361P rev : 1.0(A00) 2015-07-30
                        good evening badcaps.net Community members I'm new to your discussion. But I follow you a very long time for the bios that you apply on badcaps.net. Anyway I need your help for the Bios of a certain Dell XPS 9550 (LA-C361P rev: 1.0) it turns on and does not appear. the fan is running at full speed please can i have the bios dump corrected.Thank you
                        • peste
                          • 13920
                          • ROMANIA
                          #32
                          Re: Dell XPS 15 9550 AAM00 LA-C361P rev : 1.0(A00) 2015-07-30
                          try..
                          • Alassane
                            • Oct 2018
                            • 65
                            • MALI
                            #33
                            Originally posted by peste
                            try..
                            I tried but I get the same thing fan goes to full speed and it restarts several times and it does not display
                            • tienlk19
                              • Jan 2020
                              • 16
                              • Vietnam
                              #34
                              Hi. My 9550 powers on but has a black screen though it can go to display test mode (power on + d). I tried to clean ME and reflash the bios but it did not work. Can anyone help me with the bios? And if possible, can you explain briefly how to fix the bios while keeping the system serial and keys? Thanks
                              • tienlk19
                                • Jan 2020
                                • 16
                                • Vietnam
                                #35
                                Never mind. It did work. I didn't detach the CMOS battery. Unplug it and let the laptop restart a few times do the trick. The DMI info lies in the padding of the BIOS region.
                                • lau2rentiu
                                  • Jan 2020
                                  #36
                                  Originally posted by RethoricalCheese
                                  Do you have your original dump? I've extracted bios file from Dell bios update exe-s on newer models and merged them with original dump. Thus far I have only needed to program the 16MB EEPROMs.
                                  Hi. By any chance can you please give a reference of the eemprom chip you programed with the 16mb file? i have a pc but someone removed the eemprom chip and i have no ideea with ehat kind of chip to replace it. the ones I have tryed are just 8mb so are to small for the 16mb file. please help.
                                  • Mazorca
                                    • Jan 2017
                                    • 463
                                    According to post #13 this is the one for the 16MB bin. W25Q128BV and is a windbond make.
                                    • lau2rentiu
                                      • Jan 2020
                                      #38
                                      Thank uoy for your replay. I'm stil a bit confused about the last leters in the chip reference . does it make any diference if is ... BVSig or BVSG? Can be replasec with w25q128fv?
                                      Thank youfor your help
                                      • Mazorca
                                        • Jan 2017
                                        • 463
                                        The last letters do not matter, but I am not sure about the FV replaced by BV. Try it, check chip schematics for leg inputs/outputs, I'm pretty sure they match. Here are the leg pinouts for wson, the soic are the same.
                                        • lau2rentiu
                                          • Jan 2020
                                          #40
                                          Thank you very much for your help. really appreciated
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • capoplays
                                            Help with BIOS update on Dell G15 5515 after chip replacement
                                            by capoplays
                                            Hey everyone,
                                            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                            When I check the BIOS using the F12 menu Flash...
                                            10-24-2025, 06:53 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • Sathsul
                                            Dell Latitude 5431 issues with dumping bios
                                            by Sathsul
                                            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                            10-28-2025, 07:49 AM
