DELL XPS 9550 bios dumps
  • msiulian
    • Jan 2017
    • 13
    • Romania
    Hello, I have a DELL XPS 9550 which powers on and does nothing. I am suspecting the bios to be corrupted. I noticed that this laptop has 3 flash IC's. Can somebody please provide me a working dump of all 3 ic's UH8 16MB, UT5 4MB, UT2 1MB? Thank you in advance!
    0
    OUI
    0%
    0
    NON
    0%
    0
    The poll is expired.
  • peste
    • Dec 2016
    • 12872
    • ROMANIA
    Re: DELL XPS 9550 bios dumps
    https://www.laboneinside.com/dell-xps-15-9550-bios-bin/
    • msiulian
      • Jan 2017
      • 13
      • Romania
      Thanks for the reply. I tried those dumps. At first boot I get the bottom orange led's blinking, but no new behavior. Does anybody have the full set of 3 dumps for this laptop? Thanks!
      • RethoricalCheese
        • Mar 2013
        • 1518
        • Estonia
        Do you have your original dump? I've extracted bios file from Dell bios update exe-s on newer models and merged them with original dump. Thus far I have only needed to program the 16MB EEPROMs.
        • hopkok
          • Oct 2014
          • 178
          • Slovakia
          Hi, If I upload here old bios, can you help me? Has the same problem like man above.
          Thank you
          • peste
            • Dec 2016
            • 12872
            • ROMANIA
            try...
            • hopkok
              • Oct 2014
              • 178
              • Slovakia
              Originally posted by peste
              try...
              Not working sir, getting CPU Error code and if I remove RAM not getting RAM error code. With original bios, screen is blank, but no CPU error code and there is error code, if RAM removed. Thanks for try to help anyway.
              • peste
                • Dec 2016
                • 12872
                • ROMANIA
                put the original bios here, someone who has the time, can fix it.
                • hopkok
                  • Oct 2014
                  • 178
                  • Slovakia
                  Please, if anyone able to "repair it" I appreciate it. Many thanks.
                    • 21029
                    Try this bios .
                    • hopkok
                      • Oct 2014
                      • 178
                      • Slovakia
                      Originally posted by SMDFlea
                      Try this bios .
                      Solved, thank you sir.
                      • spike888ph
                        • Jun 2015
                        • 31
                        • Philippines
                        Try this bios .
                        just confirming that this bios indeed works!
                        • ZixuTech
                          • Oct 2017
                          • 90
                          Worked like a charm. Thank you for sharing.
                          I had to switch back to UEFI in the settings to boot Windows.
                          Just FYI so you won't go around and desolder all 3 bioses to figure out which 0ne it is.
                          It is the one closest to the PCH - W25Q128BV
                          • maxslo
                            • Nov 2013
                            • 64
                            • Slovenia
                            I have tried this image but i have a problem.. the laptop posts with the cleared ME BIOS, but only once, i can enter bios and it stay there working just fine, but after reboot it's back to black screen no post.
                            Any one have an idea what i could do?
                            • philippe.fields
                              • Jan 2021
                              • France
                              I am facing a similar, probably worst, issue with a XPS 15 9550 that is almost dead :
                              - first push on power button = lights on
                              - second push = nothing, no fan spin, no screen back-light.
                              - power led goes off after 10 sec
                              - LCD auto-test (d+power) never fires
                              - battery side indicator lights up, but i suspect it always display full battery, although that may be wrong.
                              - Battery charging led lights up when connected to PSU.
                              I tried to flash the main bios with the bin that you guys had success with, but with no luck. I also flashed the to other W25Q chips with bins i got from a working identical model. No better.
                              Its probably worthless, but i want to give it a final try using three bins extracted from a model that was saved by flashing the clean_me rom provided here. I dont't now, maybe those i have don't match and fail when calling each other on incorrect physical addresses.
                              Can anyone who successfully flashed the main clean_ME be kind enough to dump the bin of the two other W25Q and deposit them here?
                              Thanks in advance
                              • maxslo
                                • Nov 2013
                                • 64
                                • Slovenia
                                I have dumps from a working laptop.
                                Those two chips are for thunderbolt FW and for power delivery FW,
                                i've compared them with multiple dumps, the content is always the same.
                                • maxslo
                                  • Nov 2013
                                  • 64
                                  • Slovenia
                                  Here are the two dumps.
                                  • philippe.fields
                                    • Jan 2021
                                    • France
                                    Wow, thank you very much.
                                    I'll give it a try.
                                    • crotale
                                      • Nov 2014
                                      • 5
                                      • maroc
                                      I HAVE A PASSWORD IN SETUP in this casa please help
                                      • lngcs
                                        • Jul 2011
                                        • 69
                                        Hi could someone help me fix my bios. turn on but no display, has keyboard backlight. i try
                                        clean me with intel fitc but can't open file from the dump. i've flashed with File Type: zip XPS_9550_1.11.2 ME_CLEAN.BIN.zip above got it to display but me drowngrade error and
                                        can't boot. many thanks
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                        • mrrubik
                                          Dell Optiplex 7010 micro bad BIOS flash?
                                          by mrrubik
                                          Hi folks,
                                          I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                          After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                          Steps I took:
                                          1. Read BIOS with CH341a, verified hash twice
                                          2. Patched
                                          12-23-2024, 04:11 PM
