Dell 5480 Bios need urgently
hello masters
My Dell laptop shuts down after 10- 15 seconds of turning on.
Can you repair my bin file?
Dell 5480 17859-1
service tag(sn): F0QR6P2
model: P77F001Attached FilesComment
I have Dell Latitude 5480
i have the orginal bios
but there is 2 file 1MB
on board 2 ic flash W25Q80V
in my lap top it is empty because of me
pleas i need this 3 file
16MB U5c
1MB UT6
1MB UT2
core i5 7th
nvidia
CDP 70 LA - E142P REV 2.0
sevice tag : JZ193H2
i upload the orginal 16MB and extrcted file from Dell bios updateAttached FilesComment
any help pleas ??I have Dell Latitude 5480
16MB U5c
1MB UT6
1MB UT2
core i5 7th
nvidia
i upload the orginal 16MB and extrcted file from Dell bios updateComment
UT2 thunderbolt firmware - https://www.badcaps.net/forum/troubl...85#post3646585
UT6 attached. For UC5 you should be able to find a working bios in this topicAttached FilesComment
thank you i will try it
UT6 attached. For UC5 you should be able to find a working bios in this topicComment
thank you it works 100 %
i need to fix tpm not detected pleas
service tag : JZ193H2Attached FilesComment
try this and update thanks- All donations to badcaps are welcome, click on this link to donate. Thanks to all supporters
same problemtry this and update thanks- All donations to badcaps are welcome, click on this link to donate. Thanks to all supporters
tpm not dedectedComment
try this,,- All donations to badcaps are welcome, click on this link to donate. Thanks to all supporters
I am sorry , but same problem
Try this one https://www.badcaps.net/forum/troubl...41#post1547641 ,if TPM still isn`t working replace the TPM chip https://www.badcaps.net/forum/troubl...-ic-in-laptopsComment
Thank you , i can not try now , but when i can i will post the result
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
- Loading...
