Dell 5480 Bios need urgently
  • Murtaza527
    • May 2018
    • 262
    • Malaysia
    this is his original bios with computrace Plz clear
    thanks in advance
    • 22276
    Re: Dell 5480 Bios need urgently
    Try the bios at post #29 , if it doesn`t work then you need to flash the EC as well .
    https://www.badcaps.net/forum/showth...highlight=5480
    • imranromi
      • Jan 2015
      • 1291
      • Pakistan
      No... Computrace activate in bios not need to ec flash..
      • imranromi
        • Jan 2015
        • 1291
        • Pakistan
        My tool this exe file not extract correctly..
          • 22276
          Ok ,thanks ,i`ll remember that .
            • 22276
            Which exe do you mean .
            • imranromi
              • Jan 2015
              • 1291
              • Pakistan
              Dell bios exe 2 methods 1 change bios region remove and 2nd inside the bios and find.Bios region is easy just replace...
                • 22276
                If its lbe i don`t use it myself, i just use a few tools and hxd.
                • Murtaza527
                  • May 2018
                  • 262
                  • Malaysia
                  i tried that link bios but with that bios display comes but after few seconds off
                  i download this bios from internet but with this bios all otherthings working fine but trackpad only works in bios only i try update bios now fully updated but still trackpad not working
                  • Murtaza527
                    • May 2018
                    • 262
                    • Malaysia
                    anyone plz
                    • Murtaza527
                      • May 2018
                      • 262
                      • Malaysia
                      plz give me solution
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Just use the bios which works fully and clean me region to fix late display issue.
                        • Murtaza527
                          • May 2018
                          • 262
                          • Malaysia
                          that bios trackpad not working only working in bios
                          i dont know how to clean can you tell me bios me region and password how to remove and which software have to use
                          • foulou0238
                            • Mar 2014
                            • 109
                            • France
                            hello
                            test this one and let me know
                            • Murtaza527
                              • May 2018
                              • 262
                              • Malaysia
                              i have download this file earlier with this display comes but after few seconds its off
                                • 22276
                                Try this one. Consumer LP firmware, for the U version CPU`s
                                The EC is extracted from the bios update, its not the full size,it would need merging using a hex editor
                                • foulou0238
                                  • Mar 2014
                                  • 109
                                  • France
                                  Hello
                                  What’s is the ref of ur motherboard exctely ??
                                    • 22276
                                    @foulou0238 , the bios you posted at #14 has a dirty ME region, i took your bios, updated it with the latest bios update and cleaned the ME with the VPro_LP firmware ,it should be ok.
                                    • Murtaza527
                                      • May 2018
                                      • 262
                                      • Malaysia
                                      Try this one.
                                      with this totally no power
                                        • 22276
                                        Whats your service tag and motherboard id
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • capoplays
                                          Help with BIOS update on Dell G15 5515 after chip replacement
                                          by capoplays
                                          Hey everyone,
                                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                          When I check the BIOS using the F12 menu Flash...
                                          10-24-2025, 06:53 AM
                                        • Akhlz001
                                          by Akhlz001
                                          09-20-2025, 07:15 PM
                                        • Sathsul
                                          Dell Latitude 5431 issues with dumping bios
                                          by Sathsul
                                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                          10-28-2025, 07:49 AM
