Issues with TPM ic in laptops
  • traveler0091
    • Aug 2023
    • 10
    • Armenia
    Greetings everyone!
    I decided to open a separate thread dedicated to TPM related issues.
    Before writing about your problem/solution, let's assume that you/we have tried all the steps officially suggested by the manufacturer, but it didn't yield positive results.
    In my case there is a Dell Latitude 5480.
    1. On booting up, the message "Alert! TPM device not detected!".
    2. The TPM settings have disappeared from the BIOS menu.
    3. My laptop has a TPM chip (QFN32 IC: NPCT650VB2YX) on the motherboard (LA-E142P).
    4. BIOS upgrades and downgrades didn't give a positive result.
    Who has encountered this problem and how did you manage to solve it?
    By the way, the point is not just to hide the error, but to make the laptop see the chip itself and in the future it should not disappear again with new BIOS updates from Dell.
  • diamon
    • 106
    • Netherlands
    Re: Issues with TPM ic in laptops
    I had this issue, and after replacing the TPM chip (Dell 5580 and replaced the chip from a donor board
    , also a 5580 board) everything worked again.
    • RethoricalCheese
      • Mar 2013
      • 1517
      • Estonia
      Either bios or tpm chip issue. Fixed em maybe 20+ times.
      • traveler0091
        • Aug 2023
        • 10
        • Armenia
        Does flashing the BIOS with clean ME solve the problem?
        • traveler0091
          • Aug 2023
          • 10
          • Armenia
          I have tried to flash the bios with clean ME region.
          It didn't give any result. Still have a not detected TPM device.
          So the next step will be replacing the chip itself.
          I have already ordered the new one from China and will write here about the results.
          • black0hackers
            • Jul 2020
            • 365
            No, not bios chip. this is problem on bios file. i know some one who can fix through fixing bios. but i dont know how to do it
            I also have dell 9310 with TPM error, i try more than 10 time do bios fix. but stil TPM display on screen.
            i think downgrade ME firmware may solve this problem
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Try older versions of bios one by one unless TPM error goes away.
              • traveler0091
                • Aug 2023
                • 10
                • Armenia
                I have tried to downgrade the bios up to v1.6.*.
                But unfortunately it doesn't give a result.
                The old versions (below 1.9) may just hide the error message but not solve the problem. Also with that versions I noticed that the laptop starts functioning unstable and the windows starts arising some BSOD errors.
                Of course not the bios chip. I meant the TPM chip )
                As I understand from the forums, there is a way to hide this message by doing some changing in the bios dump, but that's not what I want.
                I haven't tried to downgrade only the ME firmware. I don't know, maybe it will work. But I guess the process itself will take a lot of time. )
                • traveler0091
                  • Aug 2023
                  • 10
                  • Armenia
                  Just to summarize,
                  the issue was resolved by replacing the chip with a new one.
                  The BIOS was able to recognize and initialize the new TPM IC even without a clean ME region, which was tried before but did not yield positive results.
                  Thank you to everyone for their contributions.
                  • black0hackers
                    • Jul 2020
                    • 365
                    Have some one remove TPM on Dell latitude 7300?
                    • SuperAman
                      Keyboard replacement not working issues with Win 10/11 (2) different laptops
                      by SuperAman
                      I have had an issue that I've never come across in all my years of laptop repairs and it has happened twice in the last couple of weeks. The issue occurred on 2 laptops.
                      1. The first laptop a Lenovo Yoga 7 convertible 14 inch 13th gen i7. This laptop came in working, customer wanted to replace the top keyboard assembly for cosmetic reasons so I replaced the keyobard assembly and put their touchpad in it. After booting into windows it would not work, so I assumed I needed to update it or something. Since they didn't give me the Admin account, as it was a company laptop and the...
                      08-31-2024, 07:30 PM
                    • NanoTesting
                      Anyone else been having problems with chinese laptops using ESSX8336 / ES8336 audio?
                      by NanoTesting
                      This audio chipset has been a pain to deal with, most of the time its impossible to find drivers for chinese laptops that have no name/brand, or generic rebranded laptops.
                      Huawei also started to use it BUT they no longer host drivers on their website since they want you to force their PC manager app that often refuses to install after bios flashing and apparently the generic drivers around wont work on some intel systems and others wont work on amd systems, the generic ones have worked only once and i think i have had this problem on 30+ laptops so far in the last year.
                      02-21-2025, 12:33 AM
                    • SoulFreeze
                      Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                      by SoulFreeze
                      Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                      After repairing the above issue, I realized the following remaining problem,
                      Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                      The computer recognizes headphones are connected and displays a popup in windows
                      Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                      06-21-2025, 09:53 AM
                    • Nagyesz
                      Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                      by Nagyesz
                      I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                      All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                      How can I extend its lifespan? Could reflow help?
                      It has ryzen 5 5500h, rtx 2050, no soldered ram.
                      Example of the artifacts:
                      03-01-2025, 11:11 AM
                    • pwnjuice
                      Bitlocker issues
                      by pwnjuice
                      Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
                      Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
                      Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
                      01-06-2025, 05:33 PM
