Dell 5480 Bios need urgently
TRYAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello!
I have a Dell Latitude 5480 (service tag dpmszf2) that has not been used for some time, I reinstalled windows, updated it through windows updates to version 1.31 and I get the error: Alert! TPM device is not detected. and it does not go further unless I press f1.
I activated bios downgrade in the bios, I tried several options in windows to downgrade the bios but they didn't work, error after restart.
I tried about 5-6 options posted by you above - it didn't want to display the laptop at all.
I saved my bios and rewrote it then the laptop displayed.
can anything be done?
this error and pressing f1 at startup really annoys me.
I also attach my bios below.​Attached Filesif you find these attachements useful please consider making a small donation to the site
Build new bios with clean ME -Fix TPM
add service tag manually from bios setup
Please clean me for this laptop.
Dell 5480-CDM70 LA E081P, REV 2.0
Service tag- GVQS9H2, express code 36747957494.
The problem is hard drive not detected in bios.
Keyboard not working in bios.
I have tried working hard drive in mbr and uefi mode,changed another drive,
changed hard drive cable,window installer does not detect hard drive so can not install window.
I have swapped working keyboard but even that is not working in bios
I have enclosed my faulty bios. ​Attached Filesif you find these attachements useful please consider making a small donation to the site
tryPlease clean me for this laptop.
I have tried the file but i still have same problem. file hasnt worked.
With new file hard drive is not detected in bios,does not boot window from hard drive.
The keyboard is not working.
With new file there is now delay of about 20 sec before it comes up.
Any more ideas pleaseComment
did you tru from post #105
what about in bios setup ? are you able to see hdd in bios ?Comment
Thank you qayyum.
Post #105 bios is for dell precision 3520.My laptop is dell 5480.
I can not see hdd in bios,hdd and keyboard are not detected in bios,in bios keyboard is not working
i have to use usb keyboard to get in to bios by using F2.
Full details of problem and service tag etc are in post#117.
I think some details about hdd and keyboard are missing in bios.
Please build bios for me to try.Comment
I have tried file at post#105.With this file Hdd is detected in bios and i was able
to load window but every time i bootup it stops at screen saying press f1 to boot again or press f2 for setting
After presssing f1 2-3 times it loads window ok. The keyboard is still not detected.
Is it possible to fix f1 error at bootup and keyboard not working?
ThanksComment
Try a new one
ThanksAttached Filesif you find these attachements useful please consider making a small donation to the site
are you able to use keyboard in bios setup if no than go for HW if yes than install new OS
TRY..Attached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
- Loading...
