Dell 5480 Bios need urgently
  • alihomee
    • Dec 2012
    • 1594
    • malaysia
    #101
    Originally posted by kalilinux25
    2 files check and try and report
    thanks for help i tried bith files but no post on screen....both files same behaviour no display...notebook turns on after 5 seconds turn off and then no responce
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      #102
      LETS wait for more expert to help you but that bios is the best build
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        #103
        TRY
        • servicepcpascani@gmail.co
          • Oct 2022
          • 29
          • romania
          #104
          Hello!
          I have a Dell Latitude 5480 (service tag dpmszf2) that has not been used for some time, I reinstalled windows, updated it through windows updates to version 1.31 and I get the error: Alert! TPM device is not detected. and it does not go further unless I press f1.
          I activated bios downgrade in the bios, I tried several options in windows to downgrade the bios but they didn't work, error after restart.
          I tried about 5-6 options posted by you above - it didn't want to display the laptop at all.
          I saved my bios and rewrote it then the laptop displayed.
          can anything be done?
          this error and pressing f1 at startup really annoys me.
          I also attach my bios below.​
          • qayyum786
            • Aug 2018
            • 1959
            • INDIA
            #105
            Build new bios with clean ME -Fix TPM
            add service tag manually from bios setup
              • Oct 2022
              • 29
              • romania
              #106
              it worked, thanks!!!
              • inkman
                • Sep 2019
                • 55
                #107
                Please clean me for this laptop.
                Dell 5480-CDM70 LA E081P, REV 2.0
                Service tag- GVQS9H2, express code 36747957494.
                The problem is hard drive not detected in bios.
                Keyboard not working in bios.
                I have tried working hard drive in mbr and uefi mode,changed another drive,
                changed hard drive cable,window installer does not detect hard drive so can not install window.
                I have swapped working keyboard but even that is not working in bios
                I have enclosed my faulty bios. ​
                • danito
                  • Jun 2016
                  • 1108
                  • Romania
                  #108
                  try
                  • inkman
                    • Sep 2019
                    • 55
                    #109
                    Originally posted by danito
                    try
                    I have tried the file but i still have same problem. file hasnt worked.
                    With new file hard drive is not detected in bios,does not boot window from hard drive.
                    The keyboard is not working.
                    With new file there is now delay of about 20 sec before it comes up.
                    Any more ideas please
                    • qayyum786
                      • Aug 2018
                      • 1959
                      • INDIA
                      #110
                      did you tru from post #105
                      what about in bios setup ? are you able to see hdd in bios ?
                      • inkman
                        • Sep 2019
                        • 55
                        #111
                        Thank you qayyum.
                        Post #105 bios is for dell precision 3520.My laptop is dell 5480.
                        I can not see hdd in bios,hdd and keyboard are not detected in bios,in bios keyboard is not working
                        i have to use usb keyboard to get in to bios by using F2.
                        Full details of problem and service tag etc are in post#117.
                        I think some details about hdd and keyboard are missing in bios.
                        Please build bios for me to try.
                        • inkman
                          • Sep 2019
                          • 55
                          #112
                          I have tried file at post#105.With this file Hdd is detected in bios and i was able
                          to load window but every time i bootup it stops at screen saying press f1 to boot again or press f2 for setting
                          After presssing f1 2-3 times it loads window ok. The keyboard is still not detected.
                          Is it possible to fix f1 error at bootup and keyboard not working?
                          • qayyum786
                            • Aug 2018
                            • 1959
                            • INDIA
                            #113
                            Try a new one
                            • inkman
                              • Sep 2019
                              • 55
                              #114
                              Try a new one
                              Thank you for new file.I have tried it.
                              The problem with F1 to retry boot remains.i still get it.
                              The keyboard is still not working.
                              i have tried some other files with no luck
                              so i think it may be hardware related problem.
                              Thank you for your time
                              • qayyum786
                                • Aug 2018
                                • 1959
                                • INDIA
                                #115
                                are you able to use keyboard in bios setup if no than go for HW if yes than install new OS
                                • inkman
                                  • Sep 2019
                                  • 55
                                  #116
                                  I cant use keyboard in bios.i have tried two diferent working keyboard and they do not work in bios.
                                  usb keyboard working in bios.
                                  • rex98
                                    • Feb 2023
                                    • 1293
                                    • Mandaue CEBU, Philippines
                                    #117
                                    TRY..
                                    • inkman
                                      • Sep 2019
                                      • 55
                                      #118
                                      Originally posted by rex98
                                      TRY..
                                      Thank you rex98 for your file.
                                      I have tried your file. I still have same problem of keyboard not working.
                                      I think i have hardware fault . i have tried few files and its not sorted so it must be motherboard.
                                      thanks
                                      • lucky12
                                        • Dec 2020
                                        • 7
                                        • india
                                        #119
                                        5480 bios
                                        master blank bios try to match you me version LP AND H.
                                        • ddhlawi
                                          • Feb 2017
                                          • 169
                                          • algerian
                                          #120
                                          I have dell 5480 bios password
                                          MODEL: P72G
                                          NCM: CDM70 LA-E082P REV:2.0(A01)
                                          Système number: 2P8NNH2-0001
                                          ST: 2P8NNH2
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • capoplays
                                            Help with BIOS update on Dell G15 5515 after chip replacement
                                            by capoplays
                                            Hey everyone,
                                            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                            When I check the BIOS using the F12 menu Flash...
                                            10-24-2025, 06:53 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • Sathsul
                                            Dell Latitude 5431 issues with dumping bios
                                            by Sathsul
                                            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                            10-28-2025, 07:49 AM
