Please help!! Bios dump Dell Latitude E6430
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Dell E6430 Dump of A18 Bios
    does it display any king of error message?
    Im Back... sort of...
    • GrafZahl
      • Jul 2013
      • 29
      Unfortunately it does not. It just does a normal reboot, instead rebooting and starting the flash process.
      I guess A18 will be the last Update for this model. If someone with a E6430 can send me a dump (should be possible with the software I attached) I can solve this with ease.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        Have you tried to disable secure boot and try again?
        • GrafZahl
          • Jul 2013
          • 29
          I always have secure boot disabled.
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            do you have "signed firware update" in bios? if yes, disable it
            • GrafZahl
              • Jul 2013
              • 29
              It is not possible to deactivate signed firmware update on the E6430 and newer models.
              Anyway I solved my problems. I bought another E6430 updated it to A18, made a dump and flashed it on the one I had problems with. Worked as expected.
              I attached the Bios Dump of both eeproms (U52+U53) if anybody else needs it.
              It recent Version A18 and does not contain a password.
              It is from a Dell Latitude E6430 with integrated Intel Graphics. I don't know if this works with E6430 with Nvidia or AMD Graphics.
              • TechGeek
                Computer Geek
                • Jan 2015
                • 2254
                Good solution there!
                Permanently Retired Systems:
                Kooky and Kool Systems
                sigpic
                • ruslan657
                  • Mar 2016
                  • 72
                  • Azerbaijan
                  #28
                  Re: Please help!! Bios dump Dell Latitude E6430
                  thank you working
                  • swanand
                    • Dec 2011
                    • 51
                    #29
                    thanks
                    • itrescuer
                      • Oct 2010
                      #30
                      thanks
                      • carrretero
                        • Spain
                        #31
                        Thank you GrafZahl for the A18 dump. I have a second hand E6430 with A11 BIOS and have the same issue as you have described here and could not find a solution for that, at Dell support forum they did not have answers and there seems to be no-one else with this issue. Me I also thought it could be the Signed Update Firmware variable setting, however, as it cannot be reversed back to off once it has been set to on, I don't see how it can be verified.
                        The zip file you posted contains two files. I was expecting a single file to flash using fpt. Please can you tell me how can I use the two files to flash the BIOS?
                        Best Regards
                        • AMN servis
                          • Nov 2015
                          • 10
                          • BiH
                          #32
                          Working bios dump.
                          • Bybuca35
                            • Apr 2017
                            • 11
                            • VVVvvv
                            #33
                            thanks
                            • GrafZahl
                              • Jul 2013
                              • 29
                              Best Regards
                              You need to write it directly to the 2 EEPROM chips using an eeprom programmer (you can also use an raspberry pi with the software "flashrom" for this). Either desolder the chips and put them in the programmer, or use a test clip without desoldering the chips.
                              • balobi
                                • Jan 2015
                                • 88
                                • phillippines
                                #35
                                Thanks to AMN SERVIS for working bin files. More power...
                                • infoplus
                                  • Aug 2017
                                  • 83
                                  • ALGERIA
                                  #36
                                  thanks a lot
                                  • charafmak77
                                    • Oct 2017
                                    • 81
                                    • jijel
                                    #37
                                    thank you
                                    • nucl3us
                                      • Nov 2017
                                      • Philippines
                                      #38
                                      Hi, I'm new to this forum and came here because of this thread, i just want to clarify if i can use this eeprom dumps to reset the unknown bios password i have in my unit? i can do soldering and have access to a universal programming tool.
                                      • fyaagoub
                                        • 269
                                        • maroc
                                        #39
                                        thank you
                                        • suiramix
                                          • Mar 2011
                                          • 131
                                          Hi there,
                                          I got this (like new condition) Dell E6430 and power up with a blank screen. after a few minutes CPU fan is cycling at normal speed.
                                          I have removed the battery and held power button 30 sec, removed CMOS, reseated RAM, rebooted without CD drive, HD, or battery connected... nothing has resolved the issue. I have the diagram (Model LA7781P)...how can I find if the BIOS is causing this problem? In the past I did reprogram a BIOS chip...this time there are two....!!!
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • jhanra
                                            by jhanra
                                            11-02-2024, 04:19 AM
                                          • TripTop
                                            Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                            by TripTop
                                            Hi
                                            i have dell latitude E7270 with following symptoms:
                                            - takes long time to restart.
                                            - sometimes powers on and then off
                                            - sometimes while working it just dies,
                                            From googling online bios clean could possible resolve this?
                                            i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                            As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                            I reinstall...
                                            09-09-2024, 02:05 PM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
