Please , I need working dump bios for Dell Latitude E6430 , mainboard LA-7781P , thanks
Please help!! Bios dump Dell Latitude E6430
Re: Please help!! Bios dump Dell Latitude E6430
Try this.Attached FilesPremium supporters get full download access and other benefits.
thanks , i will try this , maybe work . i was try from model dell e6420 but dont work , blank image , i destroy the original main bios cip when i take out from motherboard , the second bios is ood , dell e6420 seams to be identical but have diferently cip memory from windond and is mising one chip near bios memoryComment
i was try this bios , i have the same problem , its start but no image, the main problem was a shortcircuit on 1,5v power supply line , a small capacitor was broken , but first i was try to change bios and i broke the cip with airflow , maybe the poblem is another now
, thanks much for replay
try with this if not you must rebail the chipAttached FilesPremium supporters get full download access and other benefits.
i was try the bios from ridamouth159 but this is from model with dedicated video , its start but no video , i was having taday a Dell 6430 with dedicated video with problem no start , and this bios was good for that model , thanks for this bios it was usefull for that model
Dell E6430 Dump of A18 Bios
I need a dump of the recent A18 Bios of Dell E6430 (Bios and EC)
The Notebook has A12 and just ingores any attempt to update its bios. (the upgrade itself does never start, it just does a reboot)
I guess it is because of "Signed Firmware Update Feature", as I programmed the Eeproms with an eeprom reader. I have trouble with lan connection when using a docking station.
There are dumps already posted on badcaps, but just A07 and A12.
Or is there a way to create the 2 bin files out of the 14MB .hdr file you can create?
Thanks for your help!Comment
Re: Dell E6430 Dump of A18 Bios
i did not find a way to extract bin form hdr yet
but as i remember if you have hdr file, put it on fat32 formatted usb drive and turn off laptop
hold END and turn on while holding END and it should force flash from stick
as i remeber good...
and did you try runningCode:http://en.community.dell.com/support-forums/laptop/f/3518/t/19534608
E6430A18.exe /Writeromfile
or
E6430A18.exe /Writehexfile
i dont have dell machine so when i run flash file it just crashes so i cant do anything :/Last edited by ala_borbe; 07-19-2016, 06:30 AM.Im Back... sort of...
Flashing the HDR File while pressing "end" does not work. Either because it is not the proper HDR file, the filename is wrong, or because the signed firmware feature prevents this. Maybe this method does not work anymore anyway.
The /writeromfile /writehdrfile does not work anymore since quite a while.
Is it possible to dump the two Eeproms (8MB+4MB) from windows/linux using software? RWEverything or something like this?Comment
As far as i know its not posible to dump reliably any way other than programmer
Did you try to clean %temp% and run flash?
Somerimes flasher there create folder with .fd file and that can be used to extract filesIm Back... sort of...
I managed to Dump the Bios from Windows using Intels FTPW Programm (it creates one 12.6MB file, but this can be split).
Is there anyone with a Dell E6430 with recent Bios A18 who can help me?
I attached the FTPW Progamm, just unzip and execute dump.bat (I guess from command line, I did not try it from Windows Explorer, but it may work also) and upload the the file bios.bin it creates?Attached FilesPremium supporters get full download access and other benefits.
here isAttached FilesPremium supporters get full download access and other benefits.
Thank you very much ridamouh159!
I allready found these files of yours in another thread. They are working perfect, but it is version A14 (correct me if I am wrong).
I was searching for A18.
Thank you anyway for your support and keep up the good work.Comment
It does not work. It just does a normal reboot, when it is supposed to flash.
It does not help to add /f or /forceit suffix. Restoring Bios settings to default does not help either. It does not matter if I try to flash from Dos or Windows.
It does not work with Upgrade from A14 to A15, or directly A18.Comment
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by prontoHi can you help me to repuild bios dump fo dell latitude 9450 2-in-1 ultra 7
original problem was password but the chip 512mb its broken before read it
motherboard/JDB45-LA-M397P
ST/2PFD064
here dump of anoher laptop 9450 2-in 1 but not working whit first laptop...-
Channel: BIOS Requests ONLY!
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by SwatouHi everyone,
I bought a used Dell OptiPlex 3090 Micro with a BIOS administrator password that I cannot remove. Dell support refuses to help without the original proof of purchase, and the seller is unreachable.
I would like to try flashing the BIOS chip with a CH341A programmer, but I need a clean SPI BIOS dump for this exact model.
Here are my machine details:
Service Tag: 50P1BB3
Express Service Code: 10925963391
Form factor: Micro
I can share my current BIOS dump (read with CH341A) for comparison if needed....-
by TripTopHi
i have dell latitude E7270 with following symptoms:
- takes long time to restart.
- sometimes powers on and then off
- sometimes while working it just dies,
From googling online bios clean could possible resolve this?
i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
I reinstall...-
- Loading...
