HP Elitebook 820 G2 bios needed
  • techman1025
    • Jun 2014
    • 497
    Re: HP Elitebook 820 G2 bios needed
    Originally posted by imranromi
    send old bios i fix.2nd search techman1025 thread you will know how to add dmi .
    Here
    How to fix?
    Warning machine is not in committed state
    Warning: This BIOS is Not for Production Use.
    Downloads AMTBrand tool
    Brand11:
    1. Copy folder Brand11 to the root of the USB key formatted as FAT32.
    *** Your USB key should have less than 40 folders and files in the root. ***
    2. Goes to F10 -> System Configuration -> Boot options -> UEFI Boot Mode
    -> Press "Enter" to enable EFI boot -> Select "Accept" -> Save and exit.
    3. Press F9 then "Boot from EFI File", then select your USB key -> Brand11
    -> Bootx64.efi -> Press enter to run startup.nsh
    4. Follow menu to commit AMT and AT.
    Chose 1 to commit VPRO with AT, or 3 to commit Non-VPRO with AT
    5. Press 9 and then Enter key to lock descriptor and reboot the machine.
    6. Press F9 then "Boot from EFI File", then select your USB key -> Brand11
    -> Bootx64.efi. You should see the message "Pass!!! This machine is configured"
    7. Reboot to F10 and disable EFI boot mode. Done.
    Brand12:
    1. Copy folder Brand12 to the root of the USB key formatted as FAT16/FAT32.
    2. Goes to F10 -> System Configuration -> Boot options -> UEFI Boot Mode -> Press "Enter" to enable EFI boot -> Select "Accept" -> Save and exit.
    3. Press F9 then ìBoot from EFI Fileî, then select your USB key -> Brand12 -> Bootx64.efi.
    Brand13:
    1. Copy folder Brand13 to the root of the USB key formatted as FAT16/FAT32.
    2. Goes to F10 -> System Configuration -> Boot options -> Boot Mode -> Choose "UEFI Hybrid" mode -> Save and exit.
    3. Press F9 then ìBoot from EFI Fileî, then select your USB key -> Brand13 -> Bootx64.efi.
    TECHMAN1025
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      #82
      I try probook 450 g3 this method but not success.finally add dmi bios file edit and success.
      Windoz friend try techman1025 method and tell me working or not.
      • rioreno
        • Feb 2009
        • 540
        • Indonesia
        #83
        Originally posted by Windoz
        rioreno, I know this is an old thread, but I have been pulling my hair out trying to get the correct ndbmifit version to get rid of the "Uncommitted state" error after replacing the mobo on my HP Revolve G3. I have several of these, and I have the tool all the way up to 2.07, but this mobo needs the latest version. I have asked everyone I know and you are the only one that may have a copy of this tool. Do you know of anyway I can get it?
        this the latest nbdmifit v2.10 from cyberhack...
        https://www.badcaps.net/forum/showpo...9&postcount=30
        try to read README folder first...
        • Mr.dialogue
          • Sep 2015
          • 11
          • pakistan
          #84
          HERE Hp elitebook 840 6050A2637901-MB-A02
          • Mr.dialogue
            • Sep 2015
            • 11
            • pakistan
            #85
            Originally posted by satdream
            I finally ordered another SPI programmer (EZP2013) as with the CH341 I never successfully programmed the Windbond Q128.
            Yes
            No, after the warning, it was not possible to boot before the bios restored configuration (network etc.) and then the MPM mode was disabled before being able to boot WinME and run winmifit etc.
            Finally I got another Bios (here also) of 820 G2 (fully compatible with 840 G2), from somebody asked to clear password ... flashing with bios I got a fully workable laptop (no warning message etc.) BUT, I got also the SKU/Serial of the PC the Bios come from ... and not mine ...
            In any case for me the CH341 never worked for the main Bios chip, I tried several release of the software but once detected, then error to communicate ...)
            Hope this help
            Hp elitrbook 840 system board fan error issue resolve with bios .... Thanks for bios .... Thanks all
            • longi
              • Oct 2017
              • 3
              • italia
              #86
Name:	hp elitebook 820 g2.jpg
              Could anyone help me?
              i have the same problem of the others, i need to change the boot order because the OS doesn't work and it continusly restart. The bios have the administrator password setted, so i can t access it!
              below a screenshot of the bios.
              Please help me
              Regards
              • imranromi
                • Jan 2015
                • 1288
                • Pakistan
                #87
                Originally posted by longi
                [ATTACH]164345[/ATTACH]hello,
                could anyone help me?
                I have the same problem of the others, i need to change the boot order because the os doesn't work and it continusly restart. The bios have the administrator password setted, so i can t access it!
                Below a screenshot of the bios.
                Please help me
                regards
                send old bios i try remove.
                • longi
                  • Oct 2017
                  • 3
                  • italia
                  #88
                  This all the information that i have.
                  Thanks in advance
                  • imranromi
                    • Jan 2015
                    • 1288
                    • Pakistan
                    #89
                    this all the information that i have.
                    Thanks in advance
                    [ATTACH]164373[/ATTACH]
                    no i need your laptop lock bios file.
                    • longi
                      • Oct 2017
                      • 3
                      • italia
                      #90
                      where i can get it? =)
                      • nimmay
                        • Dec 2015
                        • 82
                        • Pakistan
                        #91
                        hi friends
                        HP Elitebook 820 G2 BIOS dump need
                        • imranromi
                          • Jan 2015
                          • 1288
                          • Pakistan
                          #92
                          Originally posted by nimmay
                          hi friends
                          above many bios old bios problem what?
                          • nimmay
                            • Dec 2015
                            • 82
                            • Pakistan
                            #93
                            bios password problem bro kindly help
                            imran romi bro
                            really appricaited in advance
                            • imranromi
                              • Jan 2015
                              • 1288
                              • Pakistan
                              #94
                              send old bios.
                              • nimmay
                                • Dec 2015
                                • 82
                                • Pakistan
                                #95
                                [ATTACH]164772[/ATTACH]
                                • imranromi
                                  • Jan 2015
                                  • 1288
                                  • Pakistan
                                  #96
                                  send model 840 g1/g2/g3?
                                  • imranromi
                                    • Jan 2015
                                    • 1288
                                    • Pakistan
                                    #97
                                    Agar 820 g2 wala board ha to ya kam kary ga agar koe or model send karo.
                                    • Diesalweasel
                                      • May 2016
                                      • 48
                                      • United Kingdom
                                      #98
                                      Hi i need your help please i have a hp 840 g2 with bios password. I have tried to read both bios and ec memory in circuit i own to clips but fails every time .the tool I'm using is tl866cs i own the soic8 made by 3m and i also own the pomona soic8 both give same results .either all ffffff or all 000000
                                      Do i need to unsolder the chip to extract the data
                                      And when i do get the information do you need the bios or the ec or do you need both. Parts to decode the password
                                      Thanks in advance best regards
                                      Forgot to add the bios chip is winbound 25q16dvsig and the other chip is which i believe to be the ec chip is mx ic mx 25l12873f
                                      • imranromi
                                        • Jan 2015
                                        • 1288
                                        • Pakistan
                                        #99
                                        Originally posted by diesalweasel
                                        hi i need your help please i have a hp 840 g2 with bios password. I have tried to read both bios and ec memory in circuit i own to clips but fails every time .the tool i'm using is tl866cs i own the soic8 made by 3m and i also own the pomona soic8 both give same results .either all ffffff or all 000000
                                        do i need to unsolder the chip to extract the data
                                        and when i do get the information do you need the bios or the ec or do you need both. Parts to decode the password
                                        thanks in advance best regards
                                        forgot to add the bios chip is winbound 25q16dvsig and the other chip is which i believe to be the ec chip is mx ic mx 25l12873f
                                        need main bios 16mb lock bios.
                                        • Diesalweasel
                                          • May 2016
                                          • 48
                                          • United Kingdom
                                          #100
                                          Much appreciated for your reply
                                          Do i need the 1.8v spi flash adapter to read this chip
                                          I i only own the the tl866cs and the soic8 clip
                                          Thanks in advance
                                          Best regards
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • vinaypundith
                                            Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                            by vinaypundith
                                            I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                            So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                            08-03-2024, 12:32 PM
                                          • James Maxwell
                                            HP DM1-4000er Bios Dump needed
                                            by James Maxwell
                                            I badly need bios dump for HP DM1-4000er,
                                            Model: HP DM1-4000er
                                            Motherboard: DA0NM9MB6D0 REV.D
                                            Product: QJ490EA#ACB
                                            Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                                            10-28-2024, 05:38 PM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • rednix01
                                            Nuc7i5BNH Bios Dump Needed
                                            by rednix01
                                            I accidentally bricked my NUC7i5BNH after disabling the option to boot from USB, and now it's not showing any display at all. I tried the USB recovery method, but unfortunately, it didn't work.
                                            Local repair shops are quoting around $150 just to flash the EEPROM, but considering the unit is only worth about $75 these days, that’s not really an option. So I'm hoping to learn how to flash the chip myself. But to get started, I need a working BIOS dump for the NUC7i5BNH.
                                            I did come across a post with a dump for the NUC7i7BNH, but I wasn't sure...
                                            Yesterday, 06:37 PM
