Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
  • vinaypundith
    • Nov 2020
    I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
    So, I'm looking for a BIOS dump for this machine - a 16MB one.
    Exact model number: RZ09-01682E20-R3U1
    Contents of Razer update:
    Click image for larger version  Name:	image.png Views:	0 Size:	54.6 KB ID:	3321948
    My original BIOS is attached.
    Thank you !
  • hoaca388
    Badcaps
    • Jan 2022
    • 12710
    You don't need to combine anything else, your original file is only 8 MB.
    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
    Subscribe to support us. It only takes 1 minute:
    https://www.badcaps.net/settings/subscriptions
    • istvanszasz99
      Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
      by istvanszasz99
      Product ID: RZ09-0421
      Motherboard: CH580
      Bios File Size: 32,768 KB
      Dear Forum Readers!
      !!! MY RAZER BLADE...
      11-24-2025, 05:52 PM
    • lming888
      Razer Blade 14 (2021) RZ09-0370 - Black Screen / Corrupted BIOS - Need Clean Dump with DMI
      by lming888
      I am looking for some help repairing my laptop's BIOS. The machine experienced a bad flash/corruption (wrong parameters were used during the flashing process) and currently results in a black screen with no boot / no POST when powering on.
      This is what I did,
      AFUWINx64.EXE P1106.rom
      Instead of
      AFUWINx64.EXE P1106.rom /p /b /n /RLC:E
      I have successfully desoldered the BIOS chip and performed a 100% verified dump using a CH341A programmer and NeoProgrammer (multiple read.000s matched perfectly, 0% difference)....
      07-01-2026, 05:51 AM
    • masufany
      Razer Blade 15 Advanced (2020) RZ09-03304F42 Not turning on, 0V on coils, bios not receiving power
      by masufany
      I have a Razer Blade 15 Advanced from 2020 model number RZ09-03304F42 that doesn't turn on, no led light and no charging. When I supply 19v the amperage goes to 6 amps for less than a second, and then drops to 0.5 amps for 1 second and drops once again to 0.1 amps, I checked the coils and they all give 0V, or some 0.4v. The power supply is working, and 19V enter the charging port, I followed its trace and it goes to a mosfet, which receives 19.5v at source, and 17.5v at gate, and goes to the other side of the board, but the coil there's 0V for some reason. What I have found is that the 8mb bios...
      03-21-2026, 11:31 AM
    • hafner@zendada.org
      BIOS dump for a Razer Blade Pro 17 FHD (RZ09-0220, 2017)
      by hafner@zendada.org
      Looking for a clean BIOS dump for a Razer Blade Pro 17 FHD (RZ09-0220, 2017). Unit was bricked by power transients during a tropical storm shutdown in Hawaii. Razer has EOL'd this product and won't provide BIOS support.
      Details:
      - Model: Razer Blade Pro 17 FHD
      - Part number: RZ09-0220
      - Year: 2017
      - Flash chip: Winbond W25Q128 (assumed)
      - Cause: power transient on shutdown — dead on next boot
      CH341A programmer + SOIC8 clip on the way. Happy to dump and share my chip back to the community once recovered — that's...
      03-17-2026, 03:25 PM
    • 0xx
      2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
      by 0xx
      Hi folks,
      My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
      What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
      I assumed that Windows Update was interrupted due to closing...
      09-14-2025, 03:46 PM
