HP Elitebook 820 G2 bios needed
  • peste
    • 13917
    • ROMANIA
    #201
    Re: HP Elitebook 820 G2 bios needed
    Originally posted by BenVD
    Can someone unlock bios HP elitebook 820 G2?
    Thanks!
    the bios is not ok..read it again but remove the bios chip from the motherboard, do not use the clip, give errors, and post again ..
    • pronto
      • Mar 2019
      • 129
      • morocco
      #202
      hello
      please i need bin bios origine for elitebook 840 G2 6050A2637901-MB-A02
      thanks
      • lapfix
        • Mar 2020
        • 2764
        • my workshop
        #203
        Originally posted by pronto
        hello
        thanks
        Try this , if not post your old dump
        https://www.alisaler.com/hp-eliteboo...b-a02-bios-ec/
        • planet489
          • Aug 2020
          • japan
          #204
          I want to unlock the BIOS.
          Can anybody help me?
          • peste
            • 13917
            • ROMANIA
            #205
            the bios is corrupt..remove the bios chip from the motherboard before reading or writing ..if you use the clip you may get errors..what programmer do you have?
            • planet489
              • Aug 2020
              • japan
              #206
              Thanks for the good advice.
              This is my working environment.
              os: windows10
              programmer: CH341A Mini Programmer
              application: AsProgrammer
              I referred to here.
              https://github.com/boseji/CH341-Store
              https://www.onetransistor.eu/2017/08...schematic.html
              https://www.onetransistor.eu/2018/11...n-windows.html
              Certainly I used clips.
              However, there was no error from AsProgrammer, and it seemed that the BIOS was successfully dumped.
              Now try removing the MX25L12873F chip from the motherboard.
              Is there a way to check with me if the data I dumped is corrupted?
              • planet489
                • Aug 2020
                • japan
                #207
                I noticed a difference in compressed size.
                After sucking out several times, I tried compressing each.
                There was one thing that seemed to succeed.
                please make sure.
                • peste
                  • 13917
                  • ROMANIA
                  #208
                  please make sure.
                  try..Check the bios with the HxD program.
                  • danito
                    • Jun 2016
                    • 1259
                    #209
                    I also have 1x hp 820 g2(6050a2635701-mb-a02) for which I had the password on the bios and it didn't do me any good to save the bios (backup).
                    Can you help me?
                    thx
                    • peste
                      • 13917
                      • ROMANIA
                      #210
                      Can you help me?
                      thx
                      try..
                      • javiboys
                        • Oct 2020
                        • Spain
                        #211
                        Originally posted by rioreno
                        try this with crisisrecovery only, not flashing with spiprogrammer
                        have a nice try
                        Hello Rioreno.
                        I have a similar problem with a HP 820 G2 bios. Everywhere i read I have to start it with a pendrive with SMC.BIN file inside. My laptop only show a message of "EC-MPM and system MPM do not match. Warning, system is currently in illegal static". I cannot log on bios or anything else with it. Would you help me.
                        • Kekers
                          • Nov 2016
                          • 7
                          • Latvia
                          #212
                          Originally posted by bachir2004
                          SMDFlea,thanks for your answer,but i did before on another unit with success but this keeps returning the same message whatever i do."ME has been committed it can not be committed again Failed to commit Status = 80000000000007".this with uncommited state and mpm unlocked.
                          Hello bachir2014,
                          I have encountered this same issue and cannot fix it.
                          Did you find a solution for this issue?
                          Thanks!
                          • m0seba
                            • Mar 2016
                            • 38
                            • egypt
                            #213
                            HP Elitebook 820 G2 Bios Password removal
                            hi friends
                            i got tow laptops HP EliteBook 820 G2
                            both have password in bios, i try to flash bios with same model but i get this massage ( machine is not in committed state! )
                            so i made backup the original bin file and attach it here
                            PLZ some one help me to remove passwords from this two files
                            thank you
                            • peste
                              • 13917
                              • ROMANIA
                              #214
                              Re: HP Elitebook 820 G2 Bios Password removal
                              Originally posted by m0seba
                              hi friends
                              thank you
                              https://www.badcaps.net/forum/showthread.php?t=79956
                              • m0seba
                                • Mar 2016
                                • 38
                                • egypt
                                #215
                                thank you
                                i followed this link
                                its worked with me
                                • pixi75
                                  • 82
                                  • Serbia
                                  #216
                                  Hp Probook 840 G2 working bios
                                  6050A2635701-MB-A02
                                  sps 799513-001
                                  uma
                                  cpu: i7
                                  • Dzony83
                                    • Feb 2021
                                    • 20
                                    • Sweden
                                    #217
                                    Greeting,
                                    I have a problem with the above mentioned laptop and I hope you can help me. The laptop was working quite normally and then suddenly it started showing symptoms where the white and orange lights change and during that time I can't turn on the laptop. Only after some time when it turns off those lights, I can turn on the laptop but it throws out the following error: "BIOS Identity Data Recovered, The Embedded Controller MUD data is not valid while MPM is locked. Please unlock MPM, and lock again to capture valid MUD data.". Sometimes it also shows the following error: Embedded Controller Recovery, The Embedded Controller Policy Settings have been recovered to their default state. The Embedded Controller Flash was recovered from Shared SPI Flash. I note that I did not touch anything about the bios.
                                    Does anyone have any idea how I could fix this problem? Thanks!
                                    • djharold
                                      • Aug 2015
                                      • 247
                                      • COLOMBIA
                                      #218
                                      Originally posted by dycc
                                      Here
                                      thankyou work for me
                                      • leev999
                                        • Feb 2018
                                        • uk
                                        #219
                                        Hi
                                        I have a hp 840 g2 840 I messed up bois no backup
                                        It a 6050a2637901 mb a02 chip mx25l12873f
                                        Can any point me in the right direction
                                        I manged to flash it but it don't seem to b working
                                        Windows stuck on load up and can't seem to get usb in boot option
                                        Do I also need to flash the ec bois chip ( think thats what it call
                                        Thxs
                                        • smiley60
                                          • Jul 2021
                                          • 43
                                          • UAE
                                          #220
                                          Originally posted by imranromi
                                          Here try this and reply.
                                          hi
                                          can u tell me how can i remove passwords manually
                                          specially 840 g2
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • TacticalFahrrad
                                            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                            by TacticalFahrrad
                                            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                            06-30-2025, 04:09 AM
                                          • vinaypundith
                                            Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                            by vinaypundith
                                            I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                            So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                            08-03-2024, 12:32 PM
                                          • James Maxwell
                                            HP DM1-4000er Bios Dump needed
                                            by James Maxwell
                                            I badly need bios dump for HP DM1-4000er,
                                            Model: HP DM1-4000er
                                            Motherboard: DA0NM9MB6D0 REV.D
                                            Product: QJ490EA#ACB
                                            Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                                            10-28-2024, 05:38 PM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
