HP Elitebook 820 G2 bios needed
  • imranromi
    • Jan 2015
    • 1290
    • Pakistan
    #101
    Re: HP Elitebook 820 G2 bios needed
    Originally posted by diesalweasel
    much appreciated for your reply
    do i need the 1.8v spi flash adapter to read this chip
    i i only own the the tl866cs and the soic8 clip
    thanks in advance
    best regards
    yes you need adapter first.
    • Diesalweasel
      • May 2016
      • 49
      #102
      hi here is hp 840 g2 .need bios password removed please
      motherboard info 6050A2637901-MB-A02
      serial 5CG5274CCZ
      product G8S00AV
      thanks in advance best regards
      • imranromi
        • Jan 2015
        • 1290
        • Pakistan
        #103
        motherboard info 6050a2637901-mb-a02
        serial 5cg5274ccz
        product g8s00av
        you send me a bios is not good this board main bios 16mb you send me 2 mb plz upload 16mb.
        • ATB57791
          • Jun 2012
          • 16
          • Suomi
          #104
          Please unlock bios administrator password in my HP Elitebook 840 G2.
          Full dump attached.
          Thanks in advance!
          • imranromi
            • Jan 2015
            • 1290
            • Pakistan
            #105
            Here try this and reply.
            • Diesalweasel
              • May 2016
              • 49
              #106
              hi here you go. sorry for the confusion
              best regards
              • imranromi
                • Jan 2015
                • 1290
                • Pakistan
                #107
                Try this and reply.
                • Diesalweasel
                  • May 2016
                  • 49
                  #108
                  Try this and reply.
                  Hi many thanks. It worked first time. All good
                  Much appreciated best regards
                  • vince59
                    • Nov 2017
                    • 46
                    • italy
                    #109
                    Hi I kindly ask for instructions how-to extract BIOS form my laptop. it is an HP elitebook 820 g3 and bios is locked. I got an smc.bin file from Hp but it did not owrk so I would like extract the bios and see what to do.
                    I will eventually replace the chip
                    Thank you
                    • techman1025
                      • Jun 2014
                      • 497
                      Ok real easy take your top half of your original file and merge it with the bottom half of either the update or donor file so let's say your bio's file is 8mb so the first 4mb merge to the other 4mb and you are done on most hp on newer ones pass words are stored in the kbc all doable just need the correct programmer to load the clean firmware and the last is the newer hex tool using disable code .
                      Techman1025
                      • vince59
                        • Nov 2017
                        • 46
                        • italy
                        #111
                        Techman1025
                        Thanks for your kind reply I was not completely clear. The laptop I am trying ti fix is BIOS locked. I am not a tech but I have good skills...the problem is I do not know how to read the BIOS from the device.
                        So I was wondering if it exists any sofwtare capable doing this.
                        I believe the hardware solution is to physically connect to the chip and read the BIOS. I am ready to do it as well.
                        • vince59
                          • Nov 2017
                          • 46
                          • italy
                          #112
                          Hi here is my dump from winbond 25Q128FVQ
                          Please help. Thanks
                          • saveriuccio
                            • Dec 2017
                            • 16
                            • italia
                            #113
                            .You excuse ops I translate
                            please tell me if it is at least this the integrated 25L12873F bios on my hp elitebook 820 g2. Thank you
                            • imranromi
                              • Jan 2015
                              • 1290
                              • Pakistan
                              #114
                              Originally posted by saveriuccio
                              .you excuse ops i translate
                              please tell me if it is at least this the integrated 25l12873f bios on my hp elitebook 820 g2. Thank you
                              no this bios is corrupt how to read and save can you save eprom programmer if use universal bkup tools software is not good use programmer and save file.
                              • vince59
                                • Nov 2017
                                • 46
                                • italy
                                #115
                                @saveriuccio
                                sono italiano e ti rispondo io poi traduco in inglese. Per il dump devi fisicamente collegarti al chip con un programmatore BIOS e leggerlo. Non c'è altro modo.
                                To get the proper dump you have to physically connect connect to the chip and read it with a EEPROM programmer. This is the only way toget a valid dump.
                                • vince59
                                  • Nov 2017
                                  • 46
                                  • italy
                                  #116
                                  try this and reply.
                                  Thanks I will let you know as soon I flash the chip. It will take some time I am not home right now.
                                  • luisbrank
                                    • Oct 2017
                                    • 21
                                    • morocco
                                    #117
                                    please any one unlock my dump for hp 820 g2
                                    here is the original dump and ec
                                    • imranromi
                                      • Jan 2015
                                      • 1290
                                      • Pakistan
                                      #118
                                      try this and reply.
                                      • askaraqer
                                        • Mar 2017
                                        • 6
                                        • Russia
                                        #119
                                        Hi! i need help too.
                                        here is the myl dump and ec
                                        • imranromi
                                          • Jan 2015
                                          • 1290
                                          • Pakistan
                                          #120
                                          Originally posted by askaraqer
                                          hi! I need help too.
                                          here try this.
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • TacticalFahrrad
                                            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                            by TacticalFahrrad
                                            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                            06-30-2025, 04:09 AM
                                          • vinaypundith
                                            Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                            by vinaypundith
                                            I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                            So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                            08-03-2024, 12:32 PM
                                          • James Maxwell
                                            HP DM1-4000er Bios Dump needed
                                            by James Maxwell
                                            I badly need bios dump for HP DM1-4000er,
                                            Model: HP DM1-4000er
                                            Motherboard: DA0NM9MB6D0 REV.D
                                            Product: QJ490EA#ACB
                                            Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                                            10-28-2024, 05:38 PM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
