Dell 8FC8 Patcher
  • larryb01
    • Jul 2025
    • 6
    • usa
    #81
    Originally posted by rex98
    Is the source code still available? I'd like to learn more about this process.
    • diamon
      • 107
      • Netherlands
      #82
      Here you go, this is the source code (Python script).
      • larryb01
        • Jul 2025
        • 6
        • usa
        #83
        Thank you!
        • rex98
          • Feb 2023
          • 1293
          • Mandaue CEBU, Philippines
          #84
          this is the original source code
          • larryb01
            • Jul 2025
            • 6
            • usa
            #85
            Thank you! VB.Net will always hold a place in my heart... 😀
            • Banagus33
              • Jul 2025
              • 15
              • Poland
              #86
              i succensfully patched my BIOS by myself usig patcher. It was DELL Latitude 5300 NortBay Non-TBT MB A00 18827-1 P3HJY$CA. BIOS has 32 Megabytes single IC.
              Thank You
              • larryb01
                • Jul 2025
                • 6
                • usa
                #87
                I've been researching how to dump the BIOS from a Dell 5420. This Youtube video shows the exact model and uses the same chip (W25R256JVEN) as the one I am trying to read. However, I have a few questions before I proceed.
                I do not have the funds for a decent hot air station setup, so I will need to read the chip directly on the board. I planned on using a CH341A programmer and the ASProgrammer software. Is this reader and software appropriate?
                I did realize that the CH341A programmer package linked above uses a SOIC8 clip but since the chip package is WSON8, I will need this probe attachment in 8x6. I plan to do three full dumps and compare the checksums to hopefully ensure a good dump.
                In ASProgrammer I found the chip "W25R256JV" which I assume will work for the W25R256JVEN variant. The data sheet says that it is 3V and ASPRogrammer did not denote 1.8V like it does for other chips. Is that correct? Does it matter that the chip in ASProgrammer doesn't end in "EN"?
                I appreciate any help you can give and I realize I'm asking a lot of questions. 🙂
                • larryb01
                  • Jul 2025
                  • 6
                  • usa
                  #88
                  I did not see a way to edit my previous post but I will answer my own questions to serve as guidance for others who may wish to perform the same process.
                  Yes, the CH314A will work to read the firmware from the W25R256JVEN. In the CH314 Programmer v2.21 (by Shichang Zhuo) it will be recognized as a W25Q256FV, but it will read, wipe, and verify fine. However, what will not work, is what I originally tried - running windows in a VM (VirtualBox on Linux) and passing the USB programmer through to the guest OS. This setup never resulted in a good read of the chip so I had to go directly to the hardware running windows.
                  Also what will not work - if you orient the pins on the WSON probe incorrectly in the ZIF socket on the reader. The part of ZIF (on my reader) with the lever is where pin 1 is located. To read 25 series BIOS chips you need to orient pin 1 correctly and at the bottom of the ZIF socket if you use the same hardware in the link above. Thankfully, the reader is smarter than I am and would reset when incorrectly connected.
                  I'd love to know more about how someone was able to find the correct sequence of bytes to replace and if/how one could view the assembly of the firmware. Perhaps more to learn in the future.
                  So, a big thanks to everyone for the help. I learned a lot and bought someone a beer (hopefully.) Cheers!
                  • rasta101
                    • Mar 2025
                    • Florida
                    #89
                    Hello everyone, please tell me if the patcher will help with this blocking of the Dell latitude 5520, or do I need to fix the BIOS?
                    • peste
                      peste commented
                      Editing a comment
                      Don't post pictures unless asked..
                  • bhcomputadores
                    • Jun 2017
                    • 25
                    • Brazil
                    #90
                    A simple video illustration on how to use the 8fc8 patcher.
                    Do you have a copy of the video?
                    • bhcomputadores
                      • Jun 2017
                      • 25
                      • Brazil
                      #91
                      SMDFlea
                      Muito Obrigado pela boa vontade em ajudar!
                      Thank you very much for your willingness to help!
                      • dugi7106
                        • Jul 2025
                        Help!!!
                        Please Post this video!!!
                        Thanks!!!
                          SMDFlea commented
                          Editing a comment
                          Drag the bios over the exe , that`s it, drag and drop.
                      • Forformi
                        • Jul 2025
                        • 3
                        • France
                        #93
                        I was trying to unsolder the bios chip (windbond 25Q256JVEN) of my dell 5430 and I broke one of the connectors of the chip before being able to save the bios.
                        I know the service tag and have a similar dell 5430 for which I also need to unlock the bios.
                        If I succeed in saving the bios of the second computer and buy a new bios chip, would it work if I write the bios of the second computer in the new chip in order to install it on the first computer or is the computer for which I broke the chip is now completely useless?
                        Thank you for your answers
                        • bhcomputadores
                          • Jun 2017
                          • 25
                          • Brazil
                          #94
                          I tried using some BIOS downloaded in another post and my laptop didn't turn on. So, I'll just have to test it to find out. But after cleaning it with the program available here, it worked.
                          • Forformi
                            • Jul 2025
                            • 3
                            • France
                            #95
                            Thank you, I'll try and update when done.
                            • Vishxavier
                              • Jul 2025
                              I have dell latitude 5521. I tried with master password it does mot work. Now my only hope is the reflash with the patcher. But before i proceed i just wany to make sure, does winbond 25R256JVEN works with CH341 programer or T48 programer and which SW shouls i use with it. Also does that SW recognize winbond chip. Thanks.
                              • ccx
                                Gandalf
                                • Sep 2023
                                • australia
                                #97
                                Thank you so much!
                                This worked so well on my dell precision 3640.
                                I spent the whole day trying to bypass the password but once I found your little program, it took me a minute to do it.
                                I'd love to buy you a coffee.
                                • madjid911
                                  • Dec 2016
                                  • 412
                                  • France
                                  #98
                                  Hello, can you remove my bios password please?
                                  I tried with all the bios (2 bios of 1MB, 1 bios of 2MB and a bios of 64MB) but it does not work on the bios of 64MB it tells me that it cannot find the word.
                                  This is for the dell XPS 15 9520
                                  ST : 978MPN3
                                  • f@brice
                                    • Nov 2019
                                    • 78
                                    • France
                                    #99
                                    ST : 978MPN3
                                    try this one and report please
                                    • madjid911
                                      • Dec 2016
                                      • 412
                                      • France
                                      #100
                                      Perfect, it works, thank you very much.
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                        Dell 8FC8 Bios Password Patcher
                                        by SMDFlea
                                          DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices.
                                          The unlock scripts given here are for personal use only, ie. you accidentally set a password on
                                          your own machine,you forgot the password you set a long time ago or you mistyped the password
                                          when setting it and cannot get in again.
                                          DISCLAIMER: THE SCRIPTS
                                        11-03-2023, 06:02 AM
                                      • al_b0sni
                                        Dell Optiplex 5000 8fc8 with chip W25Q128JVSN
                                        by al_b0sni
                                        Hey, i bought a Dell Optiplex 5000 8fc8 with chip W25Q128JVSN.
                                        I also used the CH341A programmer but my usb cable (i didnt attach it directly into the pc, i used a cable between) was corrupted. So i made a dump. Then i removed the password but unfortunately the dump had a loose contact so it was corrupted. And i've also overwrited the chip and now i dont have any dump anymore.
                                        Can someone help me? I am stuck since hours and i cannot find any bin file anywhere.
                                        I tried to extract the EXE for BIOS installation from dell and also the rcv file but i didn't manage to do that....
                                        06-18-2025, 03:42 PM
                                      • dr_crx
                                        Dell 7740 Bios locked J3JSD43-8FC8
                                        by dr_crx
                                        Hello i need help please
                                        i have DELL 7740 ST: J3JSD43-8FC8
                                        i tried to read bios bit i think it is wrong because the size of the file is around 1mb
                                        anyone can help to show its location on motherboard please.
                                        i attached the results file the IC i read is : winbond 25q80dvsig
                                        i don't know if its the needed bios or another bios on the motherboard.
                                        thank you in advanced for your help...
                                        07-11-2025, 12:22 AM
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
