Dell 8FC8 Patcher
  • shnxxx
    • Apr 2025
    • Philippines
    #41
    Hi! I just bumped to this thread looking for answers on how to remove my Dell Latitude 5420 BIOS password. I am quite confused on how to do it. I can see that there's a patcher. I already saw a video how to use it.
    From my understanding:
    1. You just need to drag the "file" to the patcher
    2. Patcher will do its trick
    3. Patcher done its work
    Where am I confused:
    1. Where could I get the file?
    2. On the video provided, didn't saw the password.
    3. Do i need to open the laptop? Because in my case, I can't open the laptop since it was from an organization. My problem is that, I need to complete reset/reimage the laptop, but it won't let me do it since the BIOS is locked. "Reset this PC" option doesn't work on my end for unknown reasons.
    EDIT: Here are the infos for my laptop:
    Model: Dell Latitude 5420
    Service tag: 7JFJPN3-8FC8
    Any help would be much appreciated! I only need to unlock the BIOS so I can boot from USB.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12426
      #42
      Red : In your machine. You need to buy a programmer and learn how to use it.
      https://www.youtube.com/results?sear...mer+how+to+use
      Blu : Must disassemble the machine.
      • MOHDZGSM
        • Feb 2023
        • 11
        • zoui ouled rechache
        #43
        Thanks it worked for me dell 5440
        • Ven
          • Jul 2016
          • 46
          Hi, just to confirm - before I mess anything up - is this patch for unlocking the BIOS Admin Password, as shown in the attached photo? Thanks
Name:	WhatsApp Image 2025-04-22 at 08.25.55_d924c997.jpg
            • 22209
            Click image for larger version  Name:	WhatsApp Image 2025-04-22 at 08.25.55_d924c997.jpg Views:	0 Size:	385.4 KB ID:	3620313
            If the suffix is 8FC8 yes.
            • newVAS01
              • May 2025
              I would like to use the patcher app on Precision 3550 to clean the BIOS password.
              I can access the BIOS but can't change the settings: Absolute is set to enabled.
              I moved an nvme SSD with W11pro installed and finished the install from the
              Precision 3550. I looked for typical files installed by an active Absolute service:
              none, so maybe it might not have been activated.
              (Precision 3550, Motherboard: LA-J451P, ServiceTag: 5ZQNK63-8FC8)
              Well, before the patcher/Absolute I don't know exactly which one is the BIOS,
              therefore my question:
              Which one is the BIOS main chip? (take a look at the images attached)
              A: sop8, 1MB GigaDevice GD25Q80CSIG
              B: sop8, 1MB GigaDevice GD25Q80CSIG
              C: wson8, 32MB XMC QH256BXIQ
              or there is another chip on the motherboard that is the main BIOS chip?
              I clamped both A and B chips, took some readings. 1MB each, compared them and they
              are different. I am almost sure main BIOS is the 32MB chip: C (wson8 XMC QH256BXIQ)
              I have to desolder chip C and, on the other face there are some small electronic parts
              that I am concerned with while reflowing.
              (I am new at working with a hot air reflow station so maybe some of you which are
              highly skilled would be nice to share some tips/tricks about desoldering when there
              are some parts on the other face in order to protect them from accidental overheating.
              I have plenty of old boards to practice...)
              Many thanks for reading my post and for your advice.​
              • peste
                • 13865
                • ROMANIA
                #47
                the bios is the one with 256...try removing the chip on other boards...find a video on the internet...if you are careful the pieces on the other side won't come off...
                re is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                • DAHOUD
                  • Sep 2023
                  • 36
                  • Tanzania
                  #48
                  This Patcher is unmatchable, worked well today am just appreciate for your effort rex98 and other members, may God bless you All 🙏
                  • newVAS01
                    • May 2025
                    Desoldered the 32MB chip, took multiple readings, did the patch, wrote patch on
                    chip, took a reading of patched chip and compared it with the original patch.
                    All good. Soldered back the chip. The small parts from the back side looks good,
                    soldering looks good. I have 2 cheap programmers (EXP 2023+ and CH34 v1.7 blue)
                    and readings were done with both of them.
                    Put back all parts. Plugged battery. Used verified RAM. Verified all things connected
                    the right way. Power button works good. Plugged in Dell 180W power supply unit.
                    1st: Without pressing the power button laptop turned on when I plugged PSU, keyboard
                    illuminated, power LED is white, no Dell logo, fan is spinning, turned off by itself
                    in 10-12 seconds. I was expecting to reboot by itself... nothing, power LED off.
                    2nd: Press power button, the power LED is amber for an instant then is off. As long
                    the power button is pressed the power LED is amber.
                    Precision 3550, Motherboard: LA-J451P Rev:1.0(A00), ServiceTag: 5ZQNK63-8FC8
                    Here is the BIOS backup + my patched/written file. I would appreciate if you make
                    a working patch so I can try again.
                    Thank you.​
                    • peste
                      • 13865
                      • ROMANIA
                      #50
                      Thank you.​
                      Write back the original bios and see what happens...
                      • wing
                        • Apr 2017
                        #51
                        I tried to download the patcher, but every time I click on the file to download it, I get a "Invalid File Specified" message on a blank page. I tried to access it from an incognito window to rule out browser cache, but got the same result.
                        Any help would be greatly appreciated
                          • 22209
                          The site has had some downtime due to a database error. It may take some time for some files to recover.
                          • madjid911
                            • 412
                            • France
                            #53
                            Hello, I can't download it. I would like to try the patch, but there is no way to download it from the website. I tried other internet pages like Google Chrome. Do you have a solution, please. I'm stuck.
                            • peste
                              • 13865
                              • ROMANIA
                              #54
                              post the bios to be unlocked in the thread corresponding to the laptop...along with ST, full name and model, motherboard model and we will unlock it...
                              • madjid911
                                • 412
                                • France
                                #55
                                Hello, ok thank you, here is my bios to unlock.
                                DELL latitude 5330
                                bios password with suffix 8FC8
                                SN : 9KX07S3
                                Asset : 115027
                                • peste
                                  • 13865
                                  • ROMANIA
                                  #56
                                  DELL latitude 5330
                                  SN : 9KX07S3
                                  Asset : 115027
                                  the bios with the password is 32MB...look for another chip and post the content...
                                  • madjid911
                                    • 412
                                    • France
                                    #57
                                    ok here it is
                                    • peste
                                      • 13865
                                      • ROMANIA
                                      #58
                                      ok here it is
                                      try...
                                      • madjid911
                                        • 412
                                        • France
                                        #59
                                        try...
                                        Thank you very much, it works perfectly.
                                        • Arador
                                          • Jun 2025
                                          • 9
                                          Originally posted by rex98
                                          DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices.
                                          The Patcher given here are for personal use only, ie. you accidentally set a password on
                                          your own machine, you forgot the password you set a long time ago or you mistyped the password
                                          when setting it and cannot get in again.
                                          DISCLAIMER: THE DELL 8FC8 PATCHER IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                          You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                          from it, and that you please credit the authors for the time and work they put into it.​
                                          I TAKE NO RESPONSIBILITY FOR ANY DAMAGE YOU DO TO YOUR MACHINE. Making these kinds of
                                          modifications is risky and might leave you with an unusable/broken machine.
                                          USE AT YOUR OWN RISK.
                                          After flashing your bios: press F2 to enter bios setup, write service tag, save, restart, press alt+F to exit factory mode.
                                          Is this still available? I click on the links and it says "invalid file"
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Dell 8FC8 Bios Password Patcher
                                            by SMDFlea
                                              The unlock scripts given here are for personal use only, ie. you accidentally set a password on
                                              your own machine,you forgot the password you set a long time ago or you mistyped the password
                                              DISCLAIMER: THE SCRIPTS
                                            11-03-2023, 06:02 AM
                                          • al_b0sni
                                            Dell Optiplex 5000 8fc8 with chip W25Q128JVSN
                                            by al_b0sni
                                            Hey, i bought a Dell Optiplex 5000 8fc8 with chip W25Q128JVSN.
                                            I also used the CH341A programmer but my usb cable (i didnt attach it directly into the pc, i used a cable between) was corrupted. So i made a dump. Then i removed the password but unfortunately the dump had a loose contact so it was corrupted. And i've also overwrited the chip and now i dont have any dump anymore.
                                            Can someone help me? I am stuck since hours and i cannot find any bin file anywhere.
                                            I tried to extract the EXE for BIOS installation from dell and also the rcv file but i didn't manage to do that....
                                            06-18-2025, 03:42 PM
                                          • Livewire07
                                            Need Bios Dell Precision 7760 8FC8
                                            by Livewire07
                                            Please need Help to unlock this Bios. 8FC8
                                            Dell Precision 7760
                                            S/T 99XX2M3
                                            Much appreciated
                                            11-17-2025, 04:54 PM
                                          • dr_crx
                                            Dell 7740 Bios locked J3JSD43-8FC8
                                            by dr_crx
                                            Hello i need help please
                                            i have DELL 7740 ST: J3JSD43-8FC8
                                            i tried to read bios bit i think it is wrong because the size of the file is around 1mb
                                            anyone can help to show its location on motherboard please.
                                            i attached the results file the IC i read is : winbond 25q80dvsig
                                            i don't know if its the needed bios or another bios on the motherboard.
                                            thank you in advanced for your help...
                                            07-11-2025, 12:22 AM
