Dell 8FC8 Patcher
Here you go, this is the source code (Python script).Attached FilesPremium supporters get full download access and other benefits.
this is the original source codeAttached FilesPremium supporters get full download access and other benefits.
I've been researching how to dump the BIOS from a Dell 5420. This Youtube video shows the exact model and uses the same chip (W25R256JVEN) as the one I am trying to read. However, I have a few questions before I proceed.
I do not have the funds for a decent hot air station setup, so I will need to read the chip directly on the board. I planned on using a CH341A programmer and the ASProgrammer software. Is this reader and software appropriate?
I did realize that the CH341A programmer package linked above uses a SOIC8 clip but since the chip package is WSON8, I will need this probe attachment in 8x6. I plan to do three full dumps and compare the checksums to hopefully ensure a good dump.
In ASProgrammer I found the chip "W25R256JV" which I assume will work for the W25R256JVEN variant. The data sheet says that it is 3V and ASPRogrammer did not denote 1.8V like it does for other chips. Is that correct? Does it matter that the chip in ASProgrammer doesn't end in "EN"?
I appreciate any help you can give and I realize I'm asking a lot of questions. 🙂
I did not see a way to edit my previous post but I will answer my own questions to serve as guidance for others who may wish to perform the same process.
Yes, the CH314A will work to read the firmware from the W25R256JVEN. In the CH314 Programmer v2.21 (by Shichang Zhuo) it will be recognized as a W25Q256FV, but it will read, wipe, and verify fine. However, what will not work, is what I originally tried - running windows in a VM (VirtualBox on Linux) and passing the USB programmer through to the guest OS. This setup never resulted in a good read of the chip so I had to go directly to the hardware running windows.
Also what will not work - if you orient the pins on the WSON probe incorrectly in the ZIF socket on the reader. The part of ZIF (on my reader) with the lever is where pin 1 is located. To read 25 series BIOS chips you need to orient pin 1 correctly and at the bottom of the ZIF socket if you use the same hardware in the link above. Thankfully, the reader is smarter than I am and would reset when incorrectly connected.
I'd love to know more about how someone was able to find the correct sequence of bytes to replace and if/how one could view the assembly of the firmware. Perhaps more to learn in the future.
So, a big thanks to everyone for the help. I learned a lot and bought someone a beer (hopefully.) Cheers!Comment
I was trying to unsolder the bios chip (windbond 25Q256JVEN) of my dell 5430 and I broke one of the connectors of the chip before being able to save the bios.
I know the service tag and have a similar dell 5430 for which I also need to unlock the bios.
If I succeed in saving the bios of the second computer and buy a new bios chip, would it work if I write the bios of the second computer in the new chip in order to install it on the first computer or is the computer for which I broke the chip is now completely useless?
Thank you for your answersComment
I tried using some BIOS downloaded in another post and my laptop didn't turn on. So, I'll just have to test it to find out. But after cleaning it with the program available here, it worked.Comment
I have dell latitude 5521. I tried with master password it does mot work. Now my only hope is the reflash with the patcher. But before i proceed i just wany to make sure, does winbond 25R256JVEN works with CH341 programer or T48 programer and which SW shouls i use with it. Also does that SW recognize winbond chip. Thanks.Comment
Hello, can you remove my bios password please?
I tried with all the bios (2 bios of 1MB, 1 bios of 2MB and a bios of 64MB) but it does not work on the bios of 64MB it tells me that it cannot find the word.
This is for the dell XPS 15 9520
ST : 978MPN3Attached FilesPremium supporters get full download access and other benefits.
try this one and report please
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by SMDFlea
DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices.
The unlock scripts given here are for personal use only, ie. you accidentally set a password on
your own machine,you forgot the password you set a long time ago or you mistyped the password
when setting it and cannot get in again.
DISCLAIMER: THE SCRIPTS
Channel: BIOS Requests ONLY!
by AcuMarikHi guys.
I need your help.
Who know if we have bios update for 8fc8 or 1b58.
I need to unlock it. Not for free of course.-
by Antoine314Hi everyone, Could anyone help me generate a master password for my Dell laptop?
My system number is: 1Q3BPH4-8FC8
Thank you very much for your help!...-
by Reflyx
- Hello, Please help me generate the master password to unlock my laptop BIOS.
- Model: Dell Latitude 7300
- Service Tag / System Number: [DMZNM13-8FC8]
- Loading...
