Dell 8FC8 Patcher
  • rex98
    • Feb 2023
    • 1287
    • Mandaue CEBU, Philippines
    Dell 8FC8 Patcher
    DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices.
    The Patcher given here are for personal use only, ie. you accidentally set a password on
    your own machine, you forgot the password you set a long time ago or you mistyped the password
    when setting it and cannot get in again.
    DISCLAIMER: THE DELL 8FC8 PATCHER IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
    You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
    from it, and that you please credit the authors for the time and work they put into it.
    I TAKE NO RESPONSIBILITY FOR ANY DAMAGE YOU DO TO YOUR MACHINE. Making these kinds of
    modifications is risky and might leave you with an unusable/broken machine.
    USE AT YOUR OWN RISK.
    After flashing your bios: press F2 to enter bios setup, write service tag, save, restart, press alt+F to exit factory mode.
  • rex98
    • Feb 2023
    • 1287
    A simple video illustration on how to use the 8fc8 patcher.
    • mtherana
      • 118
      • South Africa
      thank you it worked on SVP but can not remove Absolute Persistent Module
      • rex98
        • Feb 2023
        • 1287
        its pretty obvious in the disclaimer only bios password. if you want absolute disabled clean the vsstore.
        • f@brice
          • Nov 2019
          • 76
          • France
          How is it possible that a so small source code make a so big executable ???
          • rex98
            • Feb 2023
            • 1287
            because it's standalone you don't need to install the dotnet-runtime-6.0.29-win-x86 to run the program. its with the exe
            • Delil
              • Dec 2024
              dell latitude 5510 8fc8 bios password, I understood that in order to use this I need to backup the bios and patch it with the program you made. But I could not backup even though I downloaded Universal BIOS Backup ToolKit 2.0. I added the error as a photo
              rex98
              • peste
                • Dec 2016
                • 13209
                • ROMANIA
                rex98
                you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
                • Delil
                  • Dec 2024
                  Is it not possible to remove the bios password without intervening in the hardware? I bought this Dell Latitude 5510 (8FC) 5 6 months ago from another user. I am currently using a notebook. I will install a 1tb with a 256 gb ssd. I had to enter the bios and make settings. In order to install windows on the new ssd. I did not intervene when I saw the bios password. The notebook is completely locked..
                  • peste
                    • Dec 2016
                    • 13209
                    • ROMANIA
                    I don't know, but maybe someone else does.
                    • alext28
                      • May 2020
                      • 48
                      Thanks for the app its just work fine !! tested on latitude 5440 , precision 3580 😀😀😀
                      • mtherana
                        • 118
                        • South Africa
                        thanks ... any tutorial on how to clean vsstore?
                        • nltheman
                          • Jan 2025
                          • NL
                          Hi there,
                          Can you explain from the beginning to the end? I mean, how do I extract the .bin file? My assumption is to remove the chip and backing it up with the SPI programmer. Is that correct? If yes, which application do I need to back it up and restore it?
                          It would be much clearer to us all to make a guide from beginning to end how to use this. The example video for the SPI programmer doesn't have the working links.
                          We would appreciate when you make all of this clear for us all. Thanks in advance!
                          • peste
                            • Dec 2016
                            • 13209
                            • ROMANIA
                            Originally posted by nltheman
                            Hi there,
                            There are a lot of videos on the internet, you just have to search.
                            here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                            • michel318
                              • Dec 2024
                              • Netherlands
                              Hi there,
                              I did a dell 7420 bios pswrd removal. buy a T48. Soldered 8 wires onto the ic. Mine was a wson-8 package so some room for 0,05 wire with micro soldering tip. I removed the motherboard completly but did not unsolder the ic (winbond 25r256jven). Use w25q256jv in t48 xgecu software.
                              extract .bin. Patch, write back, voila.
                              • Bornface Mulela
                                • Jan 2025
                                • Zambia
                                rex98 Does the patcher also remove the Admin password?.
                                • rex98
                                  • Feb 2023
                                  • 1287
                                  yes
                                  • solleo
                                    • Feb 2025
                                    • Turkey
                                    This patcher is pretty useful. Really thanks for your great work.
                                    • tomodachi
                                      • Apr 2012
                                      • 606
                                      • Turkey
                                      Thank you very much for this useful software.
                                      • kjosmofon
                                        • Mar 2014
                                        • 35
                                        • mkd
                                        thanks bro!!
                                          Dell 8FC8 Bios Password Patcher
                                          by SMDFlea
                                            The unlock scripts given here are for personal use only, ie. you accidentally set a password on
                                            your own machine,you forgot the password you set a long time ago or you mistyped the password
                                            DISCLAIMER: THE SCRIPTS
                                          11-03-2023, 06:02 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • al_b0sni
                                          Dell Optiplex 5000 8fc8 with chip W25Q128JVSN
                                          by al_b0sni
                                          Hey, i bought a Dell Optiplex 5000 8fc8 with chip W25Q128JVSN.
                                          I also used the CH341A programmer but my usb cable (i didnt attach it directly into the pc, i used a cable between) was corrupted. So i made a dump. Then i removed the password but unfortunately the dump had a loose contact so it was corrupted. And i've also overwrited the chip and now i dont have any dump anymore.
                                          Can someone help me? I am stuck since hours and i cannot find any bin file anywhere.
                                          I tried to extract the EXE for BIOS installation from dell and also the rcv file but i didn't manage to do that....
                                          06-18-2025, 03:42 PM
                                        • dr_crx
                                          Dell 7740 Bios locked J3JSD43-8FC8
                                          by dr_crx
                                          Hello i need help please
                                          i have DELL 7740 ST: J3JSD43-8FC8
                                          i tried to read bios bit i think it is wrong because the size of the file is around 1mb
                                          anyone can help to show its location on motherboard please.
                                          i attached the results file the IC i read is : winbond 25q80dvsig
                                          i don't know if its the needed bios or another bios on the motherboard.
                                          thank you in advanced for your help...
                                          07-11-2025, 12:22 AM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
