HP 840 g10 bios
  • rex98
    • Feb 2023
    • 1278
    • Mandaue CEBU, Philippines
    #141
    Originally posted by volinakis
    Please clean ME or provide MFIT 16.1.30.2264.
    Thank you.
    HP 840 G10
    SN: 5CG4165891
    updated to 16.1.32.2418 corpLP
    • volinakis
      • Jan 2021
      • 2733
      • N/A
      #142
      thank you.
      • DinkfingerBrad
        • Jun 2025
        • 4
        I noticed there's a lot of unlock request for this model HP EliteBook 840 14 inch G10
        The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both.
        first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
        use BCU and put your original DMI.
        frequently asked questions:
        can i use this to my HP EliteBook 840 14 inch G10 - Yes
        I've read through all the guides/documentation that I've been directed to, but I cannot figure out how to eliminate the bios password on this laptop and the seller claims they do not have any record of what the password is.
        I've run the utility but it just sajus"Wrong chip. Try reading and unlocking 16mb chip!"
        I cannot install new OS as it stands. Not sure what I'm doing wrong here. Thanks in advance!
        • lapfix
          • Mar 2020
          • 2720
          • my workshop
          #144
          For the moment no solution is clear, however some laptops with certain version have found a final solution, just look for rex98 in some posts.
          post your bios here maybe you find your unlock
          • DinkfingerBrad
            • Jun 2025
            • 4
            Great. Thanks!
            How can I take a dump of my bios without being able to access it directly?
            • DinkfingerBrad
              • Jun 2025
              • 4
              Great. Thanks!
              It is too early in the morning and I'm not thinking clearly. I will get a dump directly via ch341a and then post here once I've got a good dump. Thanks again!
              • lapfix
                • Mar 2020
                • 2720
                • my workshop
                #147
                YESSS
                • Duckie-Electronics
                  • Jun 2025
                  • 10
                  Hi, after applying post 120 the password prompts for F9, F11 and F12 were disabled, but unfortunately not F10. After flashing both chips (and re-reading and verifying against supplied bins) the HP Elitebook 840 G10 went through its normal few reboots, but before I got the opportunity to get to a point where I could press F10 to set factory defaults, I was presented with "BIOS Identity Data Recovered: The BIOS has recovered its identity from the Embedded Controller due to data mismatch"
                  Anyway, please see attached dumps. Hopefully they can help identify a resolution
                  Model: HP EliteBook 840 14 inch G10 Notebook PC
                  S/N: 5CG3481C3F
                  ProdID: 6V5Y3AV
                  MB: 6050A3452701-MB-A01
                  Click image for larger version  Name:	BIOS_Recovery.jpg Views:	10 Size:	1.20 MB ID:	3653273
                  • rex98
                    • Feb 2023
                    • 1278
                    #149
                    S/N: 5CG3481C3F
                    ProdID: 6V5Y3AV
                    use my post # 120
                    https://www.badcaps.net/forum/troubl...29#post3584829
                      • Jun 2025
                      • 10
                      Hi rex98, yep attempted post # 120 twice before reaching out. Never got the opportunity to F10 to reset factory settings as the "BIOS Identity Recovered" occurred before that
                      • rex98
                        • Feb 2023
                        • 1278
                        #151
                        did you flash the both main and ec i provided in post # 120?
                          • Jun 2025
                          • 10
                          Yes, also re-read both main and EC to verify again against bins. I have tried another two times today with same result.
                          After the "Recovery" screen I also tried just reflashing the EC. Password still required for F10
                          • bbanana
                            Father Land
                            • Oct 2021
                            • 164
                            • Vietnam
                            #153
                            dont try anymore, replace super I/O with other which no password. what's your mainboard super I/O?
                              • Jun 2025
                              • 10
                              nuvoton NPCX9 series
                              • bbanana
                                Father Land
                                • Oct 2021
                                • 164
                                • Vietnam
                                #155
                                My HP mini done after replace I/O NPCD321HA0DX
                                  • Jun 2025
                                  • 10
                                  Managed to solve the issue. I modified your EC.bin provided in post # 120 and cleared NVRAM ActiveRegn.
                                  This time, instead of the EC recovery screen, it threw the "Entering MPM" and was able to F10.
                                  Password now gone. You are a legend rex98.
                                  Probably best to verify attached before use.
                                  • rex98
                                    • Feb 2023
                                    • 1278
                                    #157
                                    thank you Duckie-Electronics ​you give us a valuable info about this. i think this method would work in G11
                                      • Jun 2025
                                      • 10
                                      No worries, obviously had to add back standard DMI settings, plus MAC, plus Cirrus Discrete Amp Calibration Data. Best to take a full BCU config dump first to be safe.
                                      I'll repeat on another 840 G10 in the next few days.
                                      • lapfix
                                        • Mar 2020
                                        • 2720
                                        • my workshop
                                        #159
                                        Good news
                                        And the main , do you use the one from post 120 !
                                          • Jun 2025
                                          • 10
                                          Good news
                                          Oh yes, main from post # 120 and updated EC on post # 156. Flashed both.
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • dchandler@lifetimeservice
                                            BIOS unlock or decrypt password for Asus S533F serial L6N0CV190141266
                                            by dchandler@lifetimeservice
                                            Could someone help me out either decrypting the administrator password, or removing entirely? Password was forgotten by user.
                                            Current BIOS firmware version is X521FA-305
                                            Thank you!...
                                            07-02-2025, 11:32 AM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
