Lenovo Thinkpad T495 AMD bios password locked
  • gsoft
    • Jul 2023
    • 38
    • Italy
    Please can you answer me? There is a way to patch the t495 bios? Thank you so much
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1226
      • France
      Originally posted by Maxpower3
      clear password and security,load by default. restart
      and restore original BIOS after
      otherwise password disappears forever​
      • gsoft
        • Jul 2023
        • 38
        • Italy
        Thank you for answer.
        Sorry but I need to understand before doing something wrong.
        I need to flash this firmware and the follow the same steps indicated in the autopatcher tutorial?
        Thanks again
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1226
          • France
          Thanks again
          flash this bios .
          Enter setup with f1
          clear password with two blank password and clear security chip
          save and exit
          after reload your original bios
          • gsoft
            • Jul 2023
            • 38
            • Italy
            flash this bios .
            Enter setup with f1
            save and exit
            Please can you explain "clear security chip"??
            Sorry but I never do it before.
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1226
              • France
              #26
              look
              • gsoft
                • Jul 2023
                • 38
                • Italy
                #27
                look
                Thanks really thanks.
                I will try and then update you
                • gsoft
                  • Jul 2023
                  • 38
                  • Italy
                  #28
                  Sorry I can't try it now because soic8 clip not want to fit on chip 😞 I ordered a new one hoping it fit better
                  • gsoft
                    • Jul 2023
                    • 38
                    • Italy
                    #29
                    Because with the clip I have problem ti CLAMP the IC, do you think this che be good for a winbond 25q128fw?
                    https://a.aliexpress.com/_EuNeV8J
                    • bnc_
                      • Jun 2024
                      • 5
                      • Hungary
                      #30
                      Hey,
                      It's my first time trying this.
                      I have recently got a T495 (S/N: PF-1ZY53R) with a locked BIOS. I managed to desolder the chip and read it, however I can't seem to get the patched one working with the autopatcher.
                      I would like to do it myself if possible, however I have zero experience. When I flash the patched version, the notebook plays the music and fan keeps going with black screen. It works when flashing the original dump but still has the password obviously.
                      Info: I have disconnected the internal display (it doesn't work) cable and I connected an external monitor by HDMI. The original BIOS shows up on the external screen.
                      Does anyone know what I'm doing wrong? I've attached both dump files.
                      Thank you in advance.
                      • bnc_
                        • Jun 2024
                        • 5
                        • Hungary
                        #31
                        Originally posted by bnc_
                        Hey,
                        Bumping, sadly couldn't get it to work yet.
                        • volinakis
                          • Jan 2021
                          • 2728
                          • N/A
                          #32
                          try and follow instructions from autopatcher.
                          [ HOW TO USE THE PATCH ]
                          STEP 1: Flash and replace current BIOS with the generated patch file
                          STEP 2: Boot the machine
                          STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                          STEP 4: Enter any character when asked for Supervisor Password
                          STEP 5: Press enter when it shows Hardware ID
                          STEP 6: Press space bar 2x when asked
                          STEP 7: Turn off machine
                          STEP 8: Restore original BIOS
                          STEP 9: Reset BIOS settings to factory default​
                          • bnc_
                            • Jun 2024
                            • 5
                            • Hungary
                            #33
                            Thanks, it seems I have killed the chip by desoldering and soldering it too many times as it's not even detected by the programmer now. I have ordered a few pieces of the same chip so I could check. I will update as soon as I get them.
                            • buglerbalint
                              • Aug 2021
                              • 13
                              • Austria
                              #34
                              Can confirm, it's WORKING! Thanks! 👌
                              • volinakis
                                • Jan 2021
                                • 2728
                                • N/A
                                #35
                                yep, happens to me too with MX (Macronix) chipsets. I advice you to use Winbond, more resilient to multiple desoldering.
                                • volinakis
                                  • Jan 2021
                                  • 2728
                                  • N/A
                                  #36
                                  good news, so you used patched file I built for bnc_ and worked for you, right?
                                  • bnc_
                                    • Jun 2024
                                    • 5
                                    • Hungary
                                    #37
                                    My new chip just arrived and I managed to get the laptop working with your patched file! Thank you!
                                    • volinakis
                                      • Jan 2021
                                      • 2728
                                      • N/A
                                      #38
                                      you are welcome
                                      • gsoft
                                        • Jul 2023
                                        • 38
                                        • Italy
                                        #39
                                        Please can you help me. I erase the chip, then flash the bin patched and now if I turn on the laptop I have a black screen, the fan start to run but then stops and nothing else...
                                        How can I get the laptop boot again?
                                        • volinakis
                                          • Jan 2021
                                          • 2728
                                          • N/A
                                          #40
                                          let me understand: you used a patched bios from another laptop and now if you write back original bios laptop has black screen? Post original bios backup and serial number, as in rules and explain what you did.
                                          • fulaphex
                                            Lenovo Thinkpad X13 Gen 3 AMD locked bios
                                            by fulaphex
                                            hello friends - I have purchased a used Thinkpad X13 Gen 3 AMD variant and only after making the purchase I realised that the BIOS is locked. I have spent a bit of time browsing the forum and from what I understand it's possible the modify the BIOS that is currently on the machine and remove the password from that BIOS. For dumping the BIOS from the laptop I have ordered this ch341a programmer. Below is a photo of the password prompt:
                                            I have taken the cover off the laptop and I found that "serial number" is "GM-0358MB" and "type number" is "21CN-S19U00"....
                                            07-09-2025, 07:04 PM
                                            Lenovo ThinkPad T495 Notebook T Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad T495 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T495 boardview and T495 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                            09-06-2024, 04:10 PM
                                            09-06-2024, 03:30 PM
