Thinkpad T495 locked BIOS
  • kicker12
    • Jul 2022
    • 19
    • Italy
    Hey! I have a T495 with BIOS password... I tried the LPC bus shorting BUT I haven't been able to get it to work (tamper error, asking for password, various errors): I guess I have now tried thousand times...
    Hence... Here is its BIOS dump: anyone willing to check/help??? MANY THANKS!
    Model: Thinkpad T495
    Motherboard: NM-C131
    Serial Number: PF-1TG5RR
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1356
    • France
    try
    • kicker12
      • Jul 2022
      • 19
      • Italy
      Originally posted by Maxpower3
      try
      Thanks Maxpower3!
      Unfortunately that has not fixed the issue: password still there... :-(((
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1356
        • France
        Thanks Maxpower3!
        Weird
        Did you use the patched file?
        Did it work?
        what password logo
        • kicker12
          • Jul 2022
          • 19
          • Italy
          Weird
          Did it work?
          what password logo
          Yes, I have tried rhebpatched file... Same behaviour as before... I am starting to guess there are different issues on the motherboard...
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1356
            • France
            I don't understand anything! Did you do that??
            [ HOW TO USE THE PATCH ]
            STEP 1: Flash and replace current BIOS with the generated patch file
            STEP 2: Boot the machine
            STEP 3: Press ENTER/F1/etc. to enter BIOS settings
            STEP 4: Enter any character when asked for Supervisor Password
            STEP 5: Press enter when it shows Hardware ID
            STEP 6: Press space bar 2x when asked
            STEP 7: Turn off machine
            STEP 8: Restore original BIOS
            STEP 9: Reset BIOS settings to factory default
            [ NOTES ]
            When booting the patched BIOS you might have to:
            - Hold the anti-tamper switch down the whole time (use tape)
            - Remove the hard disk or replace it with a locked one​
            • kicker12
              • Jul 2022
              • 19
              • Italy
              [ NOTES ]
              Yes, patched BIOS flashed... Bottom tamper switch held down... I start the motherboard, Lenovo logo shows up... Then immediately says "bottom tamper error - press esc to continue", than ask for supervisor password.. Note: I am not pressing any key from the keyboard during power on phase, NO SSD connected.
              • kicker12
                • Jul 2022
                • 19
                • Italy
                Ok... Tried again... This time took my time and trued to do everything slowly... I guess I have made the same things/steps as first time but obviously NOT because this time it worked!!! Thanks a lot Maxpower3, I owe you 495 beers!!! 🍺
                • Reynaldo Usman
                  • Jan 2024
                  • 12
                  • Philippines
                  Pls. rebuild/unlock bios
                  Serial Number: PF-1wmxa6
                  history:
                  unit is a locked bios but now only produces chime sound on power on
                  • Markus1741
                    • Sep 2020
                    • 962
                    • N/A
                    history:
                    Hello try this new files .....
                    • Reynaldo Usman
                      • Jan 2024
                      • 12
                      • Philippines
                      TYSM It worked!!!
                      • robante15
                        • Nov 2020
                        • 64
                        • El Salvador
                        Hi, could you help me unlock this BIOS?
                        Model: Lenovo ThinkPad T495
                        Motherboard: FA495 NM-C131
                        Serial Number: PF-2AEY9K
                        I tried unlocking with Lenovo Autopatcher, but it only makes a sound when I press the power button; it doesn't display an image at any point.
                        • danito
                          • Jun 2016
                          • 1129
                          • Romania
                          here
                          • robante15
                            • Nov 2020
                            • 64
                            • El Salvador
                            Originally posted by danito
                            here
                            Ty it worked
                            • to5it0
                              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                              by to5it0
                              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                              I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                              This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                              I have opened the laptop and identified the main BIOS chip...
                              10-24-2025, 01:35 AM
                            • lucaszmn
                              by lucaszmn
                              Problem:
                              Initial Findings:
                              • I concluded that the
                              08-12-2025, 03:01 PM
                            • fulaphex
                              Lenovo Thinkpad X13 Gen 3 AMD locked bios
                              by fulaphex
                              hello friends - I have purchased a used Thinkpad X13 Gen 3 AMD variant and only after making the purchase I realised that the BIOS is locked. I have spent a bit of time browsing the forum and from what I understand it's possible the modify the BIOS that is currently on the machine and remove the password from that BIOS. For dumping the BIOS from the laptop I have ordered this ch341a programmer. Below is a photo of the password prompt:
                              I have taken the cover off the laptop and I found that "serial number" is "GM-0358MB" and "type number" is "21CN-S19U00"....
                              07-09-2025, 07:04 PM
                            • lashamafia
                              Lenovo Thinkpad T495 AMD bios password locked
                              by lashamafia
                              Hello, i need help for unlocking this Thinkpad T495 SN; PF-1YX1VY try autopatch but it's stay black screen,...
                              11-30-2023, 04:22 AM
                            • MaxonDomkrat
                              Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                              by MaxonDomkrat
                              Hi everyone.
                              I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                              07-30-2025, 01:27 PM
