Hello, i need help for unlocking this Thinkpad T495 SN; PF-1YX1VY try autopatch but it's stay black screen,
Lenovo Thinkpad T495 AMD bios password locked
Originally posted by lashamafia View PostHello, i need help for unlocking this Thinkpad T495 SN; PF-1YX1VY try autopatch but it's stay black screen,
try for test
at restart : enter Bios setup with F1 and need clear security chip
type password blank and load by default and save
restore original Bios after...Attached Files
Originally posted by lashamafia View PostHello, i need help for unlocking this Thinkpad T495 SN; PF-1YX1VY try autopatch but it's stay black screen,Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
It means you read bios chipset with errors, that's why Maxpower3's file didn't work, he's very good in modifying bios in a proper and working way. That's why is better to read Bios guides made by masters of this forum before doing modifications of the bios, they recommend to read bios chipset 2-3 times and compare results, if they are the same it means you got a proper bios dump.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
and if chipset is MX25L128 replace it with another one, i.e W25Q128, I had many troubles with this kind of chipset after erased 3 times.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
good news but be more explicit: is patched file working?----------------------------------------------------------------------------------------------------------------------------------------------------------------------
No both files not worked, only this patched file by DYCC worked,
https://www.badcaps.net/forum/troubl...-0#post1669010
I have a Thinkpad T495 (AMD Ryzen).
I tried to disable the BIOS supervisor password and Computrace, but I failed.
Can you please help me?
What I did so far:
I tried the autopatcher but wasn't able to succeed (black screen, beep sounds, fan spin, but no boot).
I flashed back the original BIOS: system works, but supervisor password is still active.
I attached the dump of the original BIOS (verified by reading it multiple times)
Model: 20NK (20NKS53V00)
Serial number: PF25PGKQ
BIOS version: R12ET62W1.32
It would be great if anyone could help me.
Thank you :-)
Thread merged.
Read the rules please, you must post under a related thread if it exists.
Thank you :-)📖⤵
Boot the machine
Press ENTER/F1/etc. to enter BIOS settings
Enter any character when asked for Supervisor Password
Press enter when it shows Hardware ID
Press space bar 2x when asked
Turn off machine
Restore original BIOS
Reset BIOS settings to factory default
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..
Originally posted by Echoo View PostHello!
I use Autopatcher to create the open bios, the machine starts, but only beeps. screen is black. I am rewriting the original bios, it works, but it has a password. What could be the problem?
Unfortunately, I can't do this, I don't have enough knowledge.
Originally posted by kuch3n View PostLenovo T495s 20QK
The first try didn't worked out and the bios beeped 5x times (wrong checksum). UEFITool revealed the wrong hash:
Code:FfsParser::checkProtectedRanges: Phoenix protected range [BB0000h:F30000h] hash mismatch, opened image may refuse to boot RelativeOffset: 00BB0000h Size: 380000h Hash: 894F0EC4AAE777028ADC60150B10ECE724FC165E6530129DD6B56E45623192E6
Donation incomming (:
[/CODE]
Originally posted by gsoft View PostHi I need to patch my Lenovo t495 to remove the supervisor password .
I cannot use the autopatcher because the t495 is not Intel but a Ryzen.
I make a dump of original firmware and now I ask your help to patch it.
Please can you help me?
board code: FA495 NM C131 REV. 1.0
You need at least the SVOD4 or the Vertyanov.
Originally posted by AccountSaver View Post
It doesn't work ,what you are asking
Is not possible to patch this bios?
I read other post where people figured out to patch but not with autopatcher. They ask and someone send the patched bios.... Can you help me please?
