Sony VPCSB (MBX-237) dead after bios flash
  • Francisco.s
    • 686
    • Spain
    #61
    Re: Sony VPCSB (MBX-237) dead after bios flash
    Originally posted by silvernadal
    Hello, my name is dani and also I have problems with this board. You speak of pu9 but I can not find it, I know it's the at5208-3.3ker, but I where they locate on the plate?
    Thank you very much
    Is probably, that this component had been removed, and manufacturer had substitute this circuit with another one. (it probably depends on the revision of motherboard)
    • orientalsniper
      • Apr 2013
      • 461
      Here's another reference thread that can help the rest of you.
      https://www.badcaps.net/forum/showthread.php?t=29549
      • silvernadal
        • Oct 2013
        • 14
        • España
        #63
        He encontrado estas medidas del sn608098 y deberian ser las buenas, los pines que no salen a tierra miden 0v. :
        pin 4- 3,29v
        pin 5- 3,29v
        pin 6- 19,4v
        pin 9- 0,4v
        pin 10- 0,4v
        pin 11- 0,06v
        pin 13- 0,05v
        pin 14- 2,07v
        pin 15- 0,36v
        pin 16- 0,4v
        pin 17- 0,19v
        pin 20- 0,03v
        pin 24- 1,82v
        pin 25- 0,57v
        pin 26- 2,08v
        pin 27- 2,08v
        pin 30- 0,5v.
        • Francisco.s
          • 686
          • Spain
          #64
          On pin 7 there must be +5VALW_LDO, as its name mention, ALW= always. (siempre)
          Regards.
          • silvernadal
            • Oct 2013
            • 14
            • España
            #65
            Hello.
            Thanks for the help.
            I can not have the 3.3v or 5v. Only I have 19v on pin 4 and 6 of sn0608098, which surprises me that the measure in dcbatout irfh3707 or in sir460dp is 0v, or the terminals that connect to docking db 0v too. This means that I have a short dcbatout or this later. I already change the capacitor from here that was in short.
            Excuse me for my english.
            Thank you very much.
            • silvernadal
              • Oct 2013
              • 14
              • España
              #66
              http://i42.tinypic.com/2nlg2vb.jpg
              Hello.
              I have made this scheme sn0608098 of pin 3, 19 and 7.
              You could say me if it´s okay?
              Thanks.
              • silvernadal
                • Oct 2013
                • 14
                • España
                #67
                Hello.
                I let this plate stop and now I've started again.
                I changed the mec1609, sir460 and a capacitor, they were wrong.
                I have already tensions VALW +3, +5 VALW, + EVCC, pwrsw # _db, pwrsw, system_vref3.
                In the power button I have 5v in mind 3v, is this normal?
                The plate still does not start, it does nothing, it could be that I have the wrong bios or will be another failure?
                Thanks, I hope not to be heavy.
                • robrock1
                  • Jul 2013
                  • 129
                  • Ghana
                  #68
                  If the bios is wrong its possible that voltages are not generated so the laptop is dead, if you had an osciloscope you could measure at the bios pin that data is flowing.
                  • dspok
                    • Jan 2014
                    • 553
                    • Nepal
                    #69
                    can you please attach bios file.
                    i badly need it.
                    thanks in advance.
                    • hifihifi
                      • May 2011
                      • 18
                      #70
                      Originally posted by Francisco.s
                      Try to reprogram this modded BIOS again.
                      There's no power-on secuence on the schematic, so it's difficult to follow voltages.
                      Can you share this BIOS file?
                      • orientalsniper
                        • Apr 2013
                        • 461
                        Sorry I don't, I didn't have a programmer before. What I did was to download the original BIOS from Sony using the model number (VPC**** or PCG****).
                        • orientalsniper
                          • Apr 2013
                          • 461
                          Try this maybe: http://translate.google.com/translat...121GL-%284M%29
                          • hifihifi
                            • May 2011
                            • 18
                            #73
                            it was not bios, it worked, and know it doesn't work anymore, bad contact in flex cable between mobo and powerboard?
                            • osama31
                              • Apr 2014
                              • 5
                              • syria
                              #74
                              I don't know, I can't see which connectors they are.
                              Yes, if you saw a flash or a blink, probably you made a short-circuit and burnt the SN0608098RHBR. you should change it.
                              Pin 7 is located near PC205, the one in the green rectangle.
                              Always check voltages in components connected to pins, not in the pin, it is safe.
                              hi
                              How did you know the name of the item PC205, which is not located on the main board
                              THANKS
                              • Francisco.s
                                • 686
                                • Spain
                                #75
                                Originally posted by osama31
                                hi
                                THANKS
                                It is connected to pin 7 of PU121 (SN0608098RHBR) (page 62, MBX-237 Ver030)
                                • Learn2Day
                                  • Jun 2013
                                  • 254
                                  • Portugal
                                  #76
                                  I'm also trying to repair a Sony VPCSB in my own thread, and I noticed you people are also missing CNX-458 schematics.
                                  Big thanks to atsio, who shared this with me.
                                  Njoy!
                                  Galaxy S6 Edge x2 (Gold&White)
                                  Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
                                  Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
                                  Try Harder!
                                  • osama31
                                    • Apr 2014
                                    • 5
                                    • syria
                                    #77
                                    very thanks
                                    but i need to know the names of the items on the mother board or how did you know it .
                                    I am very sorry for my many questions
                                    • blessedsan
                                      • Apr 2014
                                      • china
                                      #78
                                      I get a sony MBX-237 motherboard from http://www.buymotherboard.net/sony-m...ard-p-957.html, but i don't know how to assemble it, anyone can help please. URGENT!!!!!!!!!
                                      • trebo
                                        • 514
                                        • Wales, UK
                                        #79
                                        watch this youtube video, http://www.youtube.com/watch?v=IHmxg7VIx3Y
                                        its not a easy one for a beginner, take extra care with ribbons, they are easily damaged, just go slowly, you will get there in the end
                                        another that may help, http://www.youtube.com/watch?v=HbxFq-m6t40
                                        and another, http://www.youtube.com/watch?v=mMfAzXeHaGU
                                        there is plenty more on there
                                        • orientalsniper
                                          • Apr 2013
                                          • 461
                                          Njoy!
                                          Thank you! I fixed mine thanks to your schematic, the power IC wasn't receiving any power in pin 6 (VIN) so I checked the power board and a fuse was open, I replaced it with a 0 ohm resistor and it works now.
                                          • Ihandyrepair
                                            4 red flash led 65X950G boot Sony and android logo but then black
                                            by Ihandyrepair
                                            HI guys
                                            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                            here is the issue
                                            I have Sony and android logo. but then 4 led red flash lights front of the tv
                                            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                            but then I get black screen and 4 red flash light at the front LED
                                            but I get 3 led flash on the LED driver board.
                                            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                            so I tried...
                                            07-11-2024, 01:45 AM
                                          • what_1282105
                                            Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                                            by what_1282105
                                            Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                                            02-14-2025, 07:27 PM
                                          • thstuff
                                            Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                            by thstuff
                                            A) TV initially dead
                                            B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                            C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                            D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                            E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                            12-26-2024, 09:10 PM
                                          • lap-top123
                                            Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
                                            by lap-top123
                                            HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
                                            Hp Elitebook 850 G8
                                            ProdID 52W98EC#ABD
                                            SN# 5CG1458XQ7
                                            Mac-address #1: 84:14:4D:2C:4B:5B
                                            UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
                                            Mainboard : 6050A3216701-MB-A01(A1)
                                            08-20-2025, 07:28 AM
                                          • bohaboha
                                            SONY KDL-46R473A ALMOST DEAD NO STB
                                            by bohaboha
                                            Hello to everyone in this wonderful forum.
                                            I have this SONY LCD TV KDL_46R473a
                                            PSU GL5 APS350 :1-888-122- 12
                                            MAINBOARD FY13_EU IP-012C101-4010
                                            black screen ,no STB no life almost death.
                                            on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
                                            Also 3,5,and 12v are on.
                                            nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
                                            don't know what to do next all suggestions and advice are very welcome​...
                                            04-24-2025, 04:40 PM
