Asus ux482e bios?
  • volinakis
    • Jan 2021
    • 2875
    • N/A
    #41
    Originally posted by Yeti
    Ok, thanks for explaining that. I have posted my backup in comment #33.
    your bios backup has wrong length, probably you made it with AMIUCP, you have to read bios content with programmer. It has 10.485.760 bytes and should have 16.777.216 bytes.
    • Yeti
      • Oct 2022
      • 14
      I used AFUWINx64 to backup.
      • Yeti
        • Oct 2022
        • 14
        i got out the soldiering iron and hooked up the programmer and extracted a new backup. it is 16mb. i have attached it.
        • volinakis
          • Jan 2021
          • 2875
          • N/A
          #44
          try
          • Yeti
            • Oct 2022
            • 14
            try
            Thanks for that. When connecting the ch341A programmer and using Asprogrammer software I couldbt find the exact model of the chip (W25Q128JVPQ) It could detect the chip and I could read and write to it using the W25Q128FVxx. It did boot up and could briefly get into the bios before it stated to boot loop, getting shorter and shorter before restarting. Not sure if I've stuffed something trying to solder wires onto the pads .. any suggestions?
            • volinakis
              • Jan 2021
              • 2875
              • N/A
              #46
              write back original bios and if it behave in the same way it means your bios backup is corrupted (meaning you didn't read it properly) . With CH341A is recommended to read 3-4 times and compare results, when you have 2 identical backups it means that is ok.
              • Yeti
                • Oct 2022
                • 14
                Hi Volinakis,
                Thank you so much for you help. After much swearing and re flashing I finally got your modded one to work. I ended up using Neo programmer to flash it as it has the correct chip number supported. Cheers for your time and effort for helping me.
                Yeti.
                • b@w
                  • Mar 2020
                  • 33
                  • ind
                  #48
                  your bios backup shows another serial and ME is configured so I doubt that's your backup. Anyway, try this.
                  Thanks fou your help at all, but laptop can't turn on.
                  for
                  SMDFlea​
                  this the file JPG
                  Thanks All
                • rifmann
                  • Feb 2019
                  • 37
                  • europe
                  #49
                  i need help
                  bios repair for Asus UX482EA
                  no video no fan
                  thanks
                  • peste
                    • Dec 2016
                    • 13880
                    • ROMANIA
                    #50
                    Originally posted by rifmann
                    i need help
                    no video no fan
                    thanks
                    post the S/N, post the original content of the bios chip, the motherboard model, etc.
                    • trunguntilyou
                      • Aug 2022
                      • 367
                      • Vietnam
                      #51
                      UX482eg r2.0
                      sn: M1N0CV16U718033
                      When turning off the power with Win, the laptop turns on by itself. If I turn on the power in the bios and press the power button to turn it off, it won't turn on by itself. I've installed Win. I've removed all other peripherals. I've tried another bios but it's still the same (the removable wifi board has been removed). Someone please help me fix the auto-power-on command via bios. Thanks!
                      • Hamza1995
                        • Sep 2022
                        • 48
                        • Algérie
                        #52
                        can you reparer this file bios plz
                        ASUS UX482EGR R3.0
                        Model: UX482E
                        SN: MAN0CV04B687406
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12430
                          #53
                          ASUS UX482EGR R3.0
                          Model: UX482E
                          SN: MAN0CV04B687406
                          UX482EG
                          ​https://www.badcaps.net/donate
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12430
                            #54
                            Originally posted by trunguntilyou
                            UX482eg r2.0
                            sn: M1N0CV16U718033
                            UX482EA
                            • Hamza1995
                              • Sep 2022
                              • 48
                              • Algérie
                              #55
                              Originally posted by hoaca388
                              UX482EG
                              NO AFFICHAGE
                              • benten127
                                • Sep 2015
                                • 7
                                • france
                                #56
                                Hello, sorry to disturb, i have change the chipset/cpu on a ux482 motherboard, but since cpu change, no ssd is detected, can someone help me for repair the bios ? here is the serial number : M7N0CV14R820288 a picture of the qr code on the board and the bios from the board. thanks a lot in advance
                                • peste
                                  • Dec 2016
                                  • 13880
                                  • ROMANIA
                                  #57
                                  try post #54...
                                  • benten127
                                    • Sep 2015
                                    • 7
                                    • france
                                    #58
                                    is the serial number of the board not important ? I go try anyway thanks
                                    • m1ch43lzm
                                      • Mar 2019
                                      • 1095
                                      • Peru
                                      #59
                                      BIOS backup is bad, read BIOS chip again if you haven't flashed # 54, random flipped bits, maybe you used a clip to read BIOS? If using clip check for SPI clock setting in your programmer software and change it to a lower value like 4MHz or less
                                      Otherwise find dnd replace all instances of your serial number with hex editor on # 54
                                      • benten127
                                        • Sep 2015
                                        • 7
                                        • france
                                        #60
                                        thanks for your help, i have download the bios on # 54 and change sn with hex editor, but the computer loop power on and off, just the power led, no screen
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • lrouw84
                                          by lrouw84
                                          Hi there,
                                          01-28-2023, 01:31 PM
