Getac S410 gen1 bios password removal
Re: Getac S410 gen1 bios password removal
The real question is not where is 3C but why 3C
you have to keep comparing to understand the comparison
It is not so easy
https://c9x.me/x86/html/file_module_x86_id_35.htmlComment
It is maybe easy for you but it is not the case for a newbie like me. I was mislead by HEX value: Firmware performance. I was thinking it has to be changed after that and it didnt work so I have to use hours to find out solution. When you know what to look for then it is easy.Last edited by RicoPL; 11-08-2023, 02:08 PM.Comment
That is correct. I appreciate the help. Thank You.The real question is not where is 3C but why 3C
It is not so easy
Help me remove the Getag S410 password. I wanted to figure it out and unlock it myself, but all the above files for comparison were deleted.
Serial number RHA03S2858
Attached Filesif you find these attachements useful please consider making a small donation to the site
try. Compare original against modified and you'll figure out.Attached Filesif you find these attachements useful please consider making a small donation to the site
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
It seems I did this, but the password remained.
Thanks, I'll try it now
Yes, I've already done this. The password remains. I compared your file with yours. They are identical.
I flashed your file. The password remains the same.
I have been looking into this issue for a long time. But I still can't understand why this method fails to remove the password.Last edited by bykanovm; 11-26-2023, 07:04 AM.Comment
I forgot my Gedac S410 G1 password.
The SN is RI203S0689.
What I haven't really understood yet is how I can actually do anything to reset the password in this situation.
Can someone explain to me how the password reset process is carried out?
Which tool do I need for this?
ChrisComment
really? identical? what did you use to compare "your file with yours"? try again ...It seems I did this, but the password remained.
I have been looking into this issue for a long time. But I still can't understand why this method fails to remove the password.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
I can't find anything for the Getac notebook under this link https://www.badcaps.net/forum/troubl...t=phoenix+bios.Comment
You need a programmer to read the bios chip. Read BIOS guides, methods, resources and tools thread.
GETAC S410G1 (52628768XXXX)
sn: RG639S0358
I need a 16MB BIOS file because my IC has suffered physical damage and I don't have a backup.
I have attached a 1MB file.Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/forum/troubl...41#post3153841 .Use that,clean the ME firmware first.Comment
Hey guys,
have a laptop here that has a supervisor Password (dump in Attachements).
Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
the laptop works but everytime it wants me to type a supervisor password i never set.
I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
Anyway i wanted to ask what of the two chips is the ec bios because on the left...-
Channel: BIOS Requests ONLY!
by mferna14Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...05-13-2025, 04:16 PM
by Badpatch02Hi all, I'm new here, a few words about myself: CS student, interested in hardware stuff too - tinkering my whole life but with practically no experience when it comes to firmware "hacking".
So I have this X380 Yoga with a supervisor password in place and before doing anything stupid I figured I'd rather ask.
I plan on using the tool from this thread: https://www.badcaps.net/forum/troubl...password-remov...-
by Johnny hHello,
I'm hoping someone can assist me.
I have an Asus Vivobook 16x Pro OLED laptop which has a BIOS password, and I can't seem to find it.
It still boots into Windows (boots from whatever SSD is installed but not from USB).
The model number is M7600R and serial number is N8N0CX03H71131C.
I tried AMITSESetup Decryptor but the password I got doesn't make sense (it's got a line break and special characters).
I also tried to use *************** MOD EDIT ,redacted************** and it also gave me the funny password of
...Code:tmNx\'=QJQ
by bulletinHello Guys,
I made a dump file from 25q80 winbond. Can someone help me to find the password or explain to me??-
- Loading...
depend on the bios.
