Getac S410 gen1 bios password removal
  • volinakis
    • Jan 2021
    • 2877
    • N/A
    Re: Getac S410 gen1 bios password removal
    Originally posted by RicoPL
    I did used that function but it didnt work for the second one. I had to find the right entry thru UEFI Tool to mark right chain as inactive. Not everything is as obvious as you might think. In every bios the place you have to replace is different. Here is the computer nr 3. as you see one chain is now inactive.
    sure ... Is veeery hard to copy hex and use Find function in HxD to find what flag you have to modify ... long hours, indeed ...
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1375
      • France
      After long hours I manage to remove the password.
      You need to change only one value depend on the bios.
      The real question is not where is 3C but why 3C
      you have to keep comparing to understand the comparison
      It is not so easy
      https://c9x.me/x86/html/file_module_x86_id_35.html
      • RicoPL
        • Sep 2023
        • 13
        • poland
        It is maybe easy for you but it is not the case for a newbie like me. I was mislead by HEX value: Firmware performance. I was thinking it has to be changed after that and it didnt work so I have to use hours to find out solution. When you know what to look for then it is easy.
        • RicoPL
          • Sep 2023
          • 13
          • poland
          It is not so easy
          That is correct. I appreciate the help. Thank You.
          • bykanovm
            • Aug 2022
            • 98
            • Украина
            Help me remove the Getag S410 password. I wanted to figure it out and unlock it myself, but all the above files for comparison were deleted.
            Serial number RHA03S2858
            • volinakis
              • Jan 2021
              • 2877
              • N/A
              #26
              try. Compare original against modified and you'll figure out.
              • bykanovm
                • Aug 2022
                • 98
                • Украина
                #27
                It seems I did this, but the password remained.
                Thanks, I'll try it now​
                Yes, I've already done this. The password remains. I compared your file with yours. They are identical.
                I flashed your file. The password remains the same.
                I have been looking into this issue for a long time. But I still can't understand why this method fails to remove the password.​
                • Burny
                  • Dec 2023
                  • 6
                  • Austria
                  #28
                  I forgot my Gedac S410 G1 password.
                  The SN is RI203S0689.
                  What I haven't really understood yet is how I can actually do anything to reset the password in this situation.
                  Can someone explain to me how the password reset process is carried out?
                  Which tool do I need for this?​
                  Chris
                • volinakis
                  • Jan 2021
                  • 2877
                  • N/A
                  #29
                  really? identical? what did you use to compare "your file with yours"? try again ...
                  • Burny
                    • Dec 2023
                    • 6
                    • Austria
                    #30
                    I can't find anything for the Getac notebook under this link https://www.badcaps.net/forum/troubl...t=phoenix+bios.​
                    • Burny
                      • Dec 2023
                      • 6
                      • Austria
                      #31
                      Where can I find the BIOS chip on the Getac S410 Motherboard?​
                      Chris​
                      • thaochua1982
                        • Feb 2021
                        • 25
                        • ho chi minh
                        #32
                        Getac s410 g1 password removing, need help
                        I need help removing password. Dump from 25q128fvsg (16MB?)
                        this machine use i5 6300 or i7 6500?
                        • Burny
                          • Dec 2023
                          • 6
                          • Austria
                          #33
                          My notebook is a Getac S410 Core i5 6300U 2,4GHz 16GB 1TB SSD BIOS
                          • volinakis
                            • Jan 2021
                            • 2877
                            • N/A
                            #34
                            Chris​
                            give more informations, serial, motherboard ID.
                            • Burny
                              • Dec 2023
                              • 6
                              • Austria
                              #35
                              Where can I find these definitions?
                              Model: S410G1 (52628768XXXX)
                              S/N: RI203S0689​
                              • thaochua1982
                                • Feb 2021
                                • 25
                                • ho chi minh
                                #36
                                can dump a file of bios rom?if can you have to dump a file and make to archive to post here.i will help you to remove password
                                • Burny
                                  • Dec 2023
                                  • 6
                                  • Austria
                                  #37
                                  How can I create a file from ROM?
                                • thaochua1982
                                  • Feb 2021
                                  • 25
                                  • ho chi minh
                                  #38
                                  need a box as XEltek or RT809F or TL866 and take out the bios ic to read
                                  • piszpunta
                                    • Jan 2019
                                    • 260
                                    • poland
                                    #39
                                    GETAC S410G1 (52628768XXXX)
                                    sn: RG639S0358
                                    I need a 16MB BIOS file because my IC has suffered physical damage and I don't have a backup.
                                    I have attached a 1MB file.
                                      • 22287
                                      sn: RG639S0358
                                      https://www.badcaps.net/forum/troubl...41#post3153841 .Use that,clean the ME firmware first.
                                      • AppleLover123
                                        Lenovo Yoga X380 22LH Supervisor Password removal
                                        by AppleLover123
                                        Hey guys,
                                        have a laptop here that has a supervisor Password (dump in Attachements).
                                        Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
                                        the laptop works but everytime it wants me to type a supervisor password i never set.
                                        I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
                                        Anyway i wanted to ask what of the two chips is the ec bios because on the left...
                                        04-17-2025, 03:42 PM
                                      • mferna14
                                        Password removal on MacBook Pro A2159
                                        by mferna14
                                        Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                                        05-13-2025, 04:16 PM
                                      • Badpatch02
                                        Thinkpad X380 Yoga supervisor password removal + Intel ME removal question
                                        by Badpatch02
                                        Hi all, I'm new here, a few words about myself: CS student, interested in hardware stuff too - tinkering my whole life but with practically no experience when it comes to firmware "hacking".
                                        So I have this X380 Yoga with a supervisor password in place and before doing anything stupid I figured I'd rather ask.
                                        I plan on using the tool from this thread: https://www.badcaps.net/forum/troubl...password-remov...
                                        11-30-2024, 05:22 AM
                                      • Johnny h
                                        Asus M7600R BIOS Password request/removal
                                        by Johnny h
                                        I'm hoping someone can assist me.
                                        I have an Asus Vivobook 16x Pro OLED laptop which has a BIOS password, and I can't seem to find it.
                                        It still boots into Windows (boots from whatever SSD is installed but not from USB).
                                        The model number is M7600R and serial number is N8N0CX03H71131C.
                                        I tried AMITSESetup Decryptor but the password I got doesn't make sense (it's got a line break and special characters).
                                        I also tried to use *************** MOD EDIT ,redacted************** and it also gave me the funny password of
                                        Code:
                                        tmNx\'=QJQ
                                        04-10-2024, 06:13 AM
                                      • bulletin
                                        GETAC S410 G4 Bios password
                                        by bulletin
                                        Hello Guys,
                                        I made a dump file from 25q80 winbond. Can someone help me to find the password or explain to me??
                                        01-05-2023, 01:49 PM
