HP EliteBook 640 G9 Bios password
  • babydoll8867
    • Nov 2014
    • 96
    • romania
    #421
    Originally posted by rex98
    i'm sorry it didn't work coz i haven't noticed its a two bios version for this model. its U75 and U86.
    the post number # 355 is U86
    this is the new one for U75
    HP EliteBook 640 14 inch G9 U75
    The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both.
    first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
    use BCU and put your original DMI.
    hi,
    do you have any idea why i can't download the files from your post#355 and #416? it says "invalid file specified".
    as the matter of fact i can't download anything, tried it, same error...
    thanks in advance!
    • Barboska
      • Sep 2021
      • 20
      • Ukraine
      #422
      Invalid File Specified
      Please reupload files
      • ravenmx
        • May 2018
        • 180
        • puebla
        #423
        please help to remove password
        hp elitebook 640 g9
        id 7c244uc#abm
        sn 5CD3029GQN
        POST 355 and 416 not working
        • AHSAN TARIQ
          • Jan 2025
          • 80
          • Pakistan
          #424
          post 355 and 416 i see this because forum are updated like database problem
          here i can remove the password ry and update me
          • hoaca388
            Badcaps
            • Jan 2022
            • 12424
            #425
            hp elitebook 640 g9
            id 7c244uc#abm
            sn 5CD3029GQN
            HP EliteBook 640 14 inch G9 Notebook PC
            CT Number_6MFDQ0DTZHFKYL
            Serial_5CD3029GQN
            Sku_7C244UC#ABM
            Build Id_22WWRTCT601#SABM#DABM
            Fearture byte_476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAdpdqfPgSguhKjhk8mEn7nVpDpFpVpqqjqz.5E
            ​https://www.badcaps.net/donate
            • babydoll8867
              • Nov 2014
              • 96
              • romania
              #426
              Hi, can you please help me unlock this 640 g9? sn4D0Z0AV
              thank you!
              • hoaca388
                Badcaps
                • Jan 2022
                • 12424
                #427
                thank you!
                Serial_5CD3221JW9
                Product_4D0Z0AV
                Build Id_22WWRTDZ601#SABE#DABE
                Fearture byte_476J6S6b7B7H7M7Q7W7m7saBaEapaqauawcAeMfPgSguhKjhk8mEmVn7nVpDpFpVpnpqprqjqz.dY
                CT Number_6MBME0KWYI3A4N
                • babydoll8867
                  • Nov 2014
                  • 96
                  • romania
                  #428
                  Serial_5CD3221JW9
                  Product_4D0Z0AV
                  thank you very much,it worked
                  • ravenmx
                    • May 2018
                    • 180
                    • puebla
                    #429
                    [QUOTE=hoaca388;n3663960]
                    Serial_5CD3029GQN
                    Sku_7C244UC#ABM
                    thanks but not working ... they have pass..... please check again. thanks you
                    • babydoll8867
                      • Nov 2014
                      • 96
                      • romania
                      #430
                      Serial_5CD3221JW9
                      Product_4D0Z0AV
                      For two days i am trying to get the notebook to work as it should. the password is gone for sure but i am getting constnt errors. it boots every other time. when it doesn't, it seems like it doesn't see the ssd. in device manager i had an I2C "cannot start" error, after that "intel smart sound technology OED" with "FW did not sent FW ready notification" and when i try to update the bios, it doesn't do it. the boot fails, restarts then enters windows. i even wrote the original bios file back but still same errors. what to do next please?
                      • ravenmx
                        • May 2018
                        • 180
                        • puebla
                        #431
                        i have the same problem, i use bios fix from hoaca388 but lose the ssd boot, anny solution?
                        • ravenmx
                          • May 2018
                          • 180
                          • puebla
                          #432
                          i restore the ec original... boot and restard ... same... problem, i restore main bios original and restard this works, finally update the bios from hp site and works , thanks you,
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12424
                            #433
                            Try clear ME .
                            • babydoll8867
                              • Nov 2014
                              • 96
                              • romania
                              #434
                              Try clear ME .
                              can you help me please with a clear ME for my original file? i found the repository for ME 16 but not for PMC, PCHC and PHY.... thank you!
                              • minhdigital
                                • Nov 2022
                                • 765
                                • Vietnam
                                #435
                                Send to you
                                • babydoll8867
                                  • Nov 2014
                                  • 96
                                  • romania
                                  #436
                                  Originally posted by minhdigital
                                  Send to you
                                  thank you very, very much, it solved all the problems!!!!
                                  • moldwarp
                                    • Jun 2025
                                    • Europe
                                    #437
                                    Please could someone send me the main + EC bins that rex98 uploaded for U75? The files in 412 do not work. Thank you!
                                    • lapfix
                                      • Mar 2020
                                      • 2765
                                      • my workshop
                                      #438
                                      Rex98 file
                                      • pongis
                                        • Aug 2017
                                        • 6
                                        • siauliai
                                        #439
                                        can unlock pass? 640-g9
                                        sn: 5cd410fcnr
                                        • tuyen821991
                                          • Oct 2024
                                          • 50
                                          • Viet Nam
                                          #440
                                          sn: 5cd410fcnr
                                          TRy
                                          Serial 5CD410FCNR
                                          Product 67W59AV
                                          CT Number PQNNL088JJ90ZJ
                                          Product name HP EliteBook 640 14 inch G9 Notebook PC
                                          BuildID 22WWRTDZ602#SABU#DABU
                                          Fearture byte 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbhcAfPgSguhKjhk8mEn7nVpDpFpTpnpqprqjqz.Nq
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • tlindi
                                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                            by tlindi
                                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                            >Read BIOS guides, methods, resources and tools
                                            Ack
                                            >Try the method at BIOS guides, methods, resources and tools before requesting help
                                            Ack
                                            >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                            python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                            01-30-2025, 04:26 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • Wutru
                                            HP Elitebook 820 G4 BIOS repair assistance required
                                            by Wutru
                                            Hi guys,
                                            If someone would be able to provide some expertise, I'd be very grateful.
                                            BIOS Corruption - Cause
                                            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                            09-06-2025, 10:32 AM
