Macbook A1932 Intermittent Backlight Issue 820-01521
  • Instafixx
    • Jul 2022
    • 374
    • India
    Namaste,
    We have a Macbook Air A2337 that came in for repair , it was drawing 5v with 0.00 -0.01 amps. Went through a couple of guides and figured that it was a DFU issue. Revived the Macbook and it then worked like a charm for 15 days.
    Now it has developed a new problem i.e Intermittent Backlight Failure. Suddenly the Backlight fails and screen goes blank but the laptop is on (checked by playing Music - the laptop screen is blank but the music control respond). Once we close the lid and open it back again, the screen is back on as it was.
    The issue happens very randomly, no fixed pattern. Sometimes it will not happen the entire day but then sometimes it will happen every hour.
    Any help would be appreciated.
  • duwane
    • Mar 2022
    • 57
    • New Zealand
    Re: Macbook A2337 820-02016 Backlight Issue
    Hall sensor issue maybe? Check for corrosion and continuity around that area, and make sure the hall sensor is working as it should by bringing a magnet close to the sensor
    • Instafixx
      • Jul 2022
      • 374
      • India
      Hi, can you tell me exactly where to check on the board. There is no corrosion on the board .
      Also if you feel its a magnet issue then woudn't it go into a sleep mode and the music should stop?
      • duwane
        • Mar 2022
        • 57
        • New Zealand
        I don't know the layout of this specific model's board, but use a paperclip or other small metal object on the edges of the screen to find where the the magnet is located, then the hall sensor will be in the corresponding position on the logic board.
        That depends on how the seonsor fails.
        Are you sure its just a backlight issue? Have you confirmed you actually have image? Tried external monitor?
        • Instafixx
          • Jul 2022
          • 374
          • India
          Have No Image but the Laptop is on as the music on Youtube is playing even with the blank screen.
          • mon2
            • Dec 2019
            • 14666
            Locate RR203 and review the voltage of this signal, RR203 (pin # 2) IPD_LID_OPEN_1V8.
            What is the voltage with the LID OPEN ? with LID CLOSED ?
            I believe that the LID sensors are commonly in the trackpad.
            On the display, with extreme care, measure the voltages for the power rails used for the LCD & camera.
            Post each measurement.
            • Instafixx
              • Jul 2022
              • 374
              • India
              Hey Mon2,
              My apologies here, i quoted the wrong board number. the correct board number is A1932 i.e 820-01521. Please tell me where to check on this board.
              • Instafixx
                • Jul 2022
                • 374
                • India
                Namaste,
                We have a Macbook Air A1932 820-01521 that came in for repair , it was drawing 5v with 0.00 -0.01 amps. Went through a couple of guides and figured that it was a DFU issue. Revived the Macbook and it then worked like a charm for 15 days.
                • mon2
                  • Dec 2019
                  • 14666
                  Re: Macbook A1932 Intermittent Backlight Issue 820-01521
                  See attached.
                  Check your trackpad. Remove it for testing. See if that allows for your display to function.
                  Check the voltage of IPD_LID_OPEN.
                  • Instafixx
                    • Jul 2022
                    • 374
                    • India
                    Hey! Have disconnected the trackpad and kept under observation. Letting you know.
                    2 Quick observations :
                    1.If we just take out the motherboard and put it back it works okay for a few hours before developing the problem.9Happened twice)
                    2. Secondly when we re-assemble the device, it doesnt switch on automatically or by pressing the p[ower button, we have to first put it on charge and then press the power button to switch it on.
                    Just thought of sharing.
                    • Instafixx
                      • Jul 2022
                      • 374
                      • India
                      Update :
                      We disconnected trackpad and keyboard flex and used a Bluetooth Mouse and Keyboard and it worked well the entire day. Just to cross check i put the trackpad flex back on. It is working fine now since 1 hour but they trackpad isn't vibrating or making the clicking sound.
                      • ronaldopdias
                        • Jul 2015
                        • 93
                        • United Kingdon
                        For most/all (not sure exactly) USB-C Macs, once you disconnect the battery and flex cable for the battery, you will need to connect to a USB C charger for it to turn on again. Then it will function as normal and work on battery. so this part is normal
                        • Instafixx
                          • Jul 2022
                          • 374
                          • India
                          Originally posted by mon2
                          See attached.
                          After removing the trackpad it run well for 1 day and then again started giving problem. This is what happens everytime when we do something, remove a flex etc. it runs well for 1 day.
                          Voltage of IPD_LID_OPEN checked a C6712 Point 1 is 1.8v.
                          Please help further. Should we put in a replacement trackpad and check?
                          • mon2
                            • Dec 2019
                            • 14666
                            When the board stops working, what is the voltage of
                            IPD_LID_OPEN ?
                            • Instafixx
                              • Jul 2022
                              • 374
                              • India
                              IPD_LID_OPEN ?
                              What do you mean when the board stops workin ?
                              • sikocan
                                • Oct 2019
                                • 344
                                When the screen goes black - when your issue occurs. Check this voltage again.
                                • Instafixx
                                  • Jul 2022
                                  • 374
                                  • India
                                  I am in a split here. The Cap is on the flip side so to check voltage we have to take the board out . Once we open the board the issue is resolved for sometime.
                                  Alternatively if we keep the screen on the bunch and connect the Board externally then wont be able to connect other parts.
                                  • mon2
                                    • Dec 2019
                                    • 14666
                                    Check if this same signal is available on the logic board side that is visible so you can measure it.
                                    • Instafixx
                                      • Jul 2022
                                      • 374
                                      • India
                                      IPL_LID_OPEN isn't available on the visible side when everything is connected.
                                      • mon2
                                        • Dec 2019
                                        • 14666
                                        Are you able to probe the pads @ J6700 connector ?
                                        The J6700 connector also contains the signals of interest.
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck β€” hoping someone here can shed some light.
                                          πŸ›  Original Issue
                                          The machine initially wouldn't negotiate 20V over USB-C β€” stuck at 5V.
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • bouch
                                          unlock macbook air A1932 2019
                                          by bouch
                                          hi
                                          i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                                          i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                                          i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                                          have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                                          I need help or information?
                                          Does anyone have the minat2 activator 1.4 software?
                                          Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                                          Thank yo...
                                          03-12-2025, 10:14 AM
                                        • pcbmaniac
                                          MacBook A1278 (3115) No PPBUS_G3H Issue
                                          by pcbmaniac
                                          Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                                          I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                                          1. U7000 Measurements:
                                            • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                                          2. Resistors:
                                            • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                                          Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                                          • If I also decide to replace the SMC, do I need to order it pre-programmed,
                                          12-02-2024, 04:12 PM
                                        • sofles
                                          Macbook a1707 2017 model 820-00928 GPU issue
                                          by sofles
                                          Hello there
                                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                          11-21-2024, 05:25 AM
                                        • bajdik
                                          Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
                                          by bajdik
                                          I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
                                          Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
                                          I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
                                          Unfortunately, I don’t have access to the schematic.
                                          It seems to me that when I bend the board, something changes.
                                          Could this...
                                          08-13-2025, 07:26 AM
