Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
  • bajdik
    • Aug 2015
    • 68
    • Czech Republic
    I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
    Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
    I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
    Unfortunately, I don’t have access to the schematic.
    It seems to me that when I bend the board, something changes.
    Could this indicate a cold joint somewhere in the power supply area?
    Or perhaps an issue with the processor?
    Has anyone experienced a similar issue or has any idea what might be causing this?
    Thank you for any help or suggestions.
  • bajdik
    • Aug 2015
    • 68
    • Czech Republic
    New info:
    The issue is 100% mechanical.
    When I press the board underneath the RAM slot, the laptop works fine.
    As soon as I remove my hand, it shuts down.
    It looks like there’s a cold joint or cracked trace in that area.
    Any advice on what component might typically cause this on an Asus X553MA?
    Thanks in advance for any help!
    • mon2
      • 14732
      Really could be anything. Suggest to consider to flux and gently reflow this area you are flexing. Be cautious of the air pressure so parts do not go flying. Keep the temp low enough that plastic parts do not melt. Also, capacitors can explode under heat so need to be very careful. Where possible, use a normal soldering iron to resolder the joints but even this method will require great care to avoid solder shorts, etc.
      Could the issue be with the RAM socket and socket pins themselves? Inspect them first.
      • bajdik
        • Aug 2015
        • 68
        • Czech Republic
        ANX1121 near LVDS -cold joints .. It is weird, but it was the problem :-) Resolder and works perfect.
          ASUS X553MA-SX561B Notebook Specification for Upgrade or Repair
          This specification for the ASUS X553MA-SX561B Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X553MA-SX561B boardview and X553MA-SX561B schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
          09-06-2024, 06:20 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
          🛠 Original Issue
          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • ugamazing
          Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
          by ugamazing
          I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
          We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
          12-17-2024, 07:05 PM
        • shahnld
          Lenovo legion 5 pro startup issue
          by shahnld
          Good day Experts
          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
          08-24-2025, 12:31 PM
