Macbook A1932 Intermittent Backlight Issue 820-01521
  • Instafixx
    • Jul 2022
    • 374
    • India
    Re: Macbook A1932 Intermittent Backlight Issue 820-01521
    Originally posted by mon2
    Are you able to probe the pads @ J6700 connector ?
    The J6700 connector also contains the signals of interest.
    I will check J6700 let you know.
    • sikocan
      • Oct 2019
      • 347
      Run a wire - jumper wire. Not any conductive wire. Proper jumper wire.
      • mon2
        • 14814
        Was about to suggest the same but believe the cap is 0201 - nasty boards and with high density. It will be tricky to do.
        • Instafixx
          • Jul 2022
          • 374
          • India
          A jumper wire from C6712 To ?
          • mon2
            • 14814
            To your meter (red probe) for measuring the voltage.
            • Instafixx
              • Jul 2022
              • 374
              • India
              #26
              Hi thanks for guiding, updating that when the problem occurs again.
              One more thing very quickly is that the trackpad isnt vibrating anymore, installed a new one to cross check - same issue. Visual inspection of cable and connector seems okay to me.
              • mon2
                • 14814
                Try a PRAM reset.
                Reference:
                https://discussions.apple.com/thread...2#250809547022
                • Instafixx
                  • Jul 2022
                  • 374
                  • India
                  #28
                  Did that! No Luck! I Think there might be some issue with the caps near the connector on the board. I ll perform and inspection and let you know. Currently its all plugged in with the jumper done and kept for the issue to re-occur so that we can check the voltage of IPD_LID_OPEN
                  • Instafixx
                    • Jul 2022
                    • 374
                    • India
                    #29
                    Hi, Didnt find any problem till now after doing the jumper wire. I think the problem is resolved for now but the trackpad isn't giving haptic feedback.
                    • mon2
                      • 14814
                      Check your software settings to confirm the haptic feedback is enabled.
                      • Instafixx
                        • Jul 2022
                        • 374
                        • India
                        #31
                        Checked the Pads of J6700 related to PPBUS_G3H_TPAD_FLT in resistance mode in Pads 41,39,37,42 and 40. The result is 0 ohms. I think this particular line is giving trouble. The cap C6700 seems ok.
                        Will check L6700 and updating.
                        • mon2
                          • 14814
                          Very interesting.
                          Check fuse @ F6700. Is it still conducting ?
                          What is the voltage on pin # 1 of this fuse ?
                          If required, remove F6700 and check if pin #1 is able to offer the required voltage.
                          • Instafixx
                            • Jul 2022
                            • 374
                            • India
                            #33
                            Very interesting.
                            you want the voltage with everything connected? its on the flip side hence will have to run a jumper wire.
                            • mon2
                              • 14814
                              Do check if this short condition disappears if you remove the trackpad cable.
                              This voltage leg is connected to PPBUS_G3H which is a key power rail to the entire logic board so it must be working if the unit is powering up ok.
                              Remove the fuse. Remove all power and check the resistance to ground of this fuse F6700, pin # 1.
                              What is the reading ?
                              • Instafixx
                                • Jul 2022
                                • 374
                                • India
                                #35
                                No Value in F6700 Pin 2 and Pin 1 450 ohms when checked in Resistance Mode.
                                Have not removed the Fuse yet. Just checking it.
                                • mon2
                                  • 14814
                                  What is the resistance to ground of this fuse, pin #2?
                                  Ok. Where is the short?
                                  Check both sides of the coil.
                                  • Instafixx
                                    • Jul 2022
                                    • 374
                                    • India
                                    #37
                                    Resistance Value in Pin #2 in 0 ohms.
                                    Replacing the Fuse. Updating in a bit.
                                    • Instafixx
                                      • Jul 2022
                                      • 374
                                      • India
                                      #38
                                      Have replaced the fuse, getting proper value also in the pads but the trackpad isnt giving haptic feedback.
                                      • mon2
                                        • 14814
                                        Can you share the meter setting?
                                        If you short your meter probes, do you see the same resistance readings?
                                        • Instafixx
                                          • Jul 2022
                                          • 374
                                          • India
                                          #40
                                          It's a digital meter, set to Diode Mode.
                                          Touching Red and Black together gives the buzzer sound as usual.
                                          • rounin
                                            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                            by rounin
                                            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck β€” hoping someone here can shed some light.
                                            πŸ›  Original Issue
                                            The machine initially wouldn't negotiate 20V over USB-C β€” stuck at 5V.
                                            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                            04-19-2025, 01:18 AM
                                          • bouch
                                            unlock macbook air A1932 2019
                                            by bouch
                                            hi
                                            i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                                            i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                                            i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                                            have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                                            I need help or information?
                                            Does anyone have the minat2 activator 1.4 software?
                                            Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                                            Thank yo...
                                            03-12-2025, 10:14 AM
                                          • pcbmaniac
                                            MacBook A1278 (3115) No PPBUS_G3H Issue
                                            by pcbmaniac
                                            Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                                            I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                                            1. U7000 Measurements:
                                              • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                                            2. Resistors:
                                              • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                                            Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                                            • If I also decide to replace the SMC, do I need to order it pre-programmed,
                                            12-02-2024, 04:12 PM
                                          • sofles
                                            Macbook a1707 2017 model 820-00928 GPU issue
                                            by sofles
                                            Hello there
                                            I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                            I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                            11-21-2024, 05:25 AM
                                          • bajdik
                                            Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
                                            by bajdik
                                            I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
                                            Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
                                            I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
                                            Unfortunately, I don’t have access to the schematic.
                                            It seems to me that when I bend the board, something changes.
                                            Could this...
                                            08-13-2025, 07:26 AM
