acer vn7-791g - 14203-1m - wistron - touchpad dead
  • rediii
    h???, spurrrn
    • Mar 2018
    • 487
    • somewhere in europe
    hello guys,
    i have an acer vn7-791G machine here. the touchpad died (controller shorted out - synaptics). i ordered a new touchpad, which should work fine though. but the problem is, that this clickpad is working neither. i measured the voltages on the connector tp1 and found out that the ec_tpclk signal is missing (no 3.3 V here). i replaced the kbc but no luck... resistors are working fine. tp_in_r goes low when tp is connected an stays high if no touchpad is present. already tried different flex cable (but orignal one is working fine).
    3D3V_TP_S3: 3.3 v
    EC_TPDATA_R: 3.3 V
    EC_TPCLOCK_R: 0 V
    I2C lines are present with 3.3v
    tp_lid_close_: 3.3 v (when machine is running)
    measurements around the connector an i2c circuit for usb serial connection are not suspicious.
    i also cleared me with the newest firmware band tried different bios files...
    in windows the device manager isn't recognizing the touchpad at all...
    everything else looks fine, functional and without any problems. any suggestions here? thanks guys!
    tp circuit on page 62, kbc lines can be found on page 24
  • mon2
    • Dec 2019
    • 14140
    Re: acer vn7-791g - 14203-1m - wistron - touchpad dead
    To help with reviews, use the EXACT labels as shown in the schematic.
    EC_TPCLOCK_R
    is not present in the schematic.
    EC_TPCLK_R
    works.
    1) Remove the touchpad and check the I2C lines again - any difference on the EC_TPCLK_R voltage status ?
    What is the voltage of EC_TPCLK ?
    2) Keep the touchpad removed -> (with all power removed) -> what is the resistance to ground of:
    EC_TPCLK_R
    3) Confirm that the I2C pull-up resistor for the EC_TPCLK is present @ RN6201. Also, with power removed, confirm the resistance of RN6201 resistor network, specifically the pull-up leg (pins 2 & 3) for the I2C clock line.
    Personally do not have experience with the KBC but does it need to be programmed to function as needed ? Most of an internal 8051 that need firmware to function properly.
    • rediii
      h???, spurrrn
      • Mar 2018
      • 487
      EC_TPCLK_R
      works.
      EC_TPCLK_R
      sry for missspelling and thank you.
      there is no difference in the i2c lines, no matter if tp is present or not.
      resistors are present and have the right values
      resistance to ground for ec_tpclk_r is 0.L without tp, if the touchpad is connected it's first rising to over 1 Mohms, falling down to 230k slowy (same for ec_tpdata_r)
      voltage for ec_tpclock is low mV
      voltages for rn6201 are
      pin 1 and 2: 3.3v
      pin 3: low mv
      pin 4: 3.3 v
      kbc is not programmed
      all signals for the complete circuitry are present (no shorts etc.), but ps/2 clock signal from kbc won't go high.
      • mon2
        • Dec 2019
        • 14140
        Remove all power. Meter in DIODE mode.
        Red meter lead to ground.
        BLACK meter lead to rn6201, pin # 3 - what is the reading ?
        BLACK meter lead to rn6201, pin # 4 - what is the reading ?
        Would you know if this KBC requires programming ? If yes, this could be the fault.
        Soldering clean on the KBC ? All power & ground rails are present on the KBC ?
        If the KBC has a metal ground belly - it has been reflowed properly for a good connection ? I recall on XMOS devices - had many OEMs claiming their devices on custom boards would not function. 9/10 times, the issue was with the improper connection of the metal belly pad for the XMOS devices.
        • rediii
          h???, spurrrn
          • Mar 2018
          • 487
          there is no ec file available (or at least i didn't found one in different forums) and the old ec has had no firmware on it
          diode readings:
          pin #3: 0.610
          pin #4: 0.612
          i soldered so many kbcs, joints are looking good
          no metal ground belly
          maybe the chip is bad, but i doubt it.
          thank you very much so far, i'll need some sleep and report the results later
          one funny thing is: if i want to measure all_sys_pwrgd the device is shutting down (regardless of the smd component)... whatsoever
          • mon2
            • Dec 2019
            • 14140
            Based on the logic board name, this is officially the 'Poseidon Adventure' ? Sorry, could not hold back on that one. It is not everyday such a pun can be thrown out there.
            Perhaps the capacitive load of your meter lead causing this signal line to tank?
            Confirm, when you are fully rested, the pull-up resistor @ R3708. Remove all power and confirm that it is ~10k.
            Then with power, confirm that pin #1 (R3708) = ~3v3.
            The diode readings look ok - was expecting to see a different diode value for the non-functional I2C bus pin.
            • rediii
              h???, spurrrn
              • Mar 2018
              • 487
              hey, so the resistor measures 8.7k in line and 10k out of circuit. 3.3 v on pin#1 present.
              • rediii
                h???, spurrrn
                • Mar 2018
                • 487
                soldered another kbc, same problem. so i think it maybe has something to do with the pch...
                well well, if anyone has another idea i appreciate every little hint or help
                • mon2
                  • Dec 2019
                  • 14140
                  What are the full markings on the KBC ?
                  From the review yesterday, the I2C bus master is the KBC for the trackpad so would think the fault is linked to the KBC.
                  Are datasheets available for the KBC ? Suspecting (only a guess) that firmware is required to apply a fresh KBC onboard to allow for the I2C bus master to operate normally (in open drain mode).
                  Respectively, do you see any I2C bus activity on this non-working interface pin during power up on a scope ?
                  • rediii
                    h???, spurrrn
                    • Mar 2018
                    • 487
                    hey, i thought i2c bus is coming from the serial bus chip cy7c65211 to the clickpad and this serial bus controller will be fed by the pch via usb 2.0 interface? kbc is communicating with the touchpad via ps/2 lanes? i'll test with scope later this evening here in germany. i'm not home atm.
                    there is no firmware available for the kbc and if i try to write or read with i/o programmer kbc inserted in external board, it can't read the chip id (the programmer is working fine. is use it frequently). i tried 3 different kbcs and these do not seem to be programmable at all. but maybe you are right. on the other hand the firmware should be available online somewhere, but like is said, i can't find any rom out there. will report later then! thanks again
                    • rediii
                      h???, spurrrn
                      • Mar 2018
                      • 487
                      it's getting hilarious. while i was touching the ec_tpclck line with scope the singal recovered. all singals are up now, but tp won't work till now. i'll report later... this makes no sense at all, hahaha
                      • rediii
                        h???, spurrrn
                        • Mar 2018
                        • 487
                        well i'm going to replace the usb serial controller now... after that i'm out. have to order it sadly, thanks for your help mon2
                        • honigmann
                          Acer z5wah la-b161p - What causes dead touchpad?
                          by honigmann
                          I have two of these devices here. The first had been working without any issues and the second came with a dead touchpad. To figure out if there is a problem with the board or with the touchpad itself I cross swapped the keyboard/touchpad unit on both devices and none of the touchpads worked. Unfortunately, aber swapping back the keyboard/touchpad unit the touchpads on both devices failed (also tested with Ubuntu).
                          There are no fuses on the board and I could not see any damage under the microscope. I get the 3V_PTP on the U2507 (p28). How would you diagnosed this issue?...
                          02-23-2022, 10:18 AM
                        • sect-sin
                          HP 17-BY0132NF Touchpad dead
                          by sect-sin
                          I have a problem with a HP 17-BY0132NF Notebook (motherboard marking SNAPE-6050A2982701-MB-A01(A1)). After repair and subsequent Windows 10 install, the system was extremely slow. Nevertheless I managed to download all drivers from the HP support page (which correctly identiefed the notebook as 17-BY0132NF), and I also installed a BIOS update. The original BIOS revision was F9, and I updated it to F64, the most recent available version.
                          This fixed the speed issue immediately, but the Touchpad stopped working. I tried every possible software solution (tried...
                          11-11-2022, 06:26 PM
                        • darckreign1984
                          HP 1040 G3 water damage, keyboard and touchpad dead
                          by darckreign1984
                          If I press numlock on external keyboard, the led from internal keyboard light up for a short period of time.
                          any advice?
                          DA0Y0FMBAJ1 REV J
                          MODEL Y0F...
                          03-01-2024, 09:24 AM
                        • double_DD
                          How can I be sure that my EC chip is dead?
                          by double_DD
                          As the title suggests, how can I be sure that my EC chip is really dead?
                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                          03-12-2025, 07:47 AM
                        • Dannyx
                          Asus ROG gl752v dead touchpad
                          by Dannyx
                          Good day folks. Just thought I'd open up this discussion mostly out of curiosity to see if anyone else had this issue on Asus ROG laptops...or any other laptop for that matter.
                          The problem is the touchpad is completely dead and I'm suspecting it's a hardware failure: it's not showing up in Device Manager in any way, it doesn't work under Hirens and no amount of restarts and driver reinstalls got it going again. The touchpad has a 4 pin ribbon connector, so I think it's an I2C connection (SDA,SCL,GND,VCC). The ribbon cable looks fine (though this could be misleading and it could...
                          02-06-2020, 03:55 AM
