NM-C741 Lenovo L15 Gen 1 Touchpad and Trackpoint don´t work
  • master3112
    • Mar 2024
    • 89
    • Slovakia
    I have a Lenovo L15 Gen 1. The touchpad and trackpoint on the device are not working. Not even in BIOS, so it's not a driver issue. The touchpad is enabled in BIOS. When I run Lenovo Diagnostics for Windows, the touchpad is not even recognized. I have already updated BIOS, without success. VCC is present on the touchpad connector.
    Does anyone have any ideas?
  • coasterghost
    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
    by coasterghost
    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
    System Hardware:
    Processor: AMD Ryzen 7 PRO 5850U
    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
    09-08-2025, 10:46 PM
  • Rhaverz
    My touchpad doesn't work, Asus laptop motherboard X455LJ REV 3.1
    by Rhaverz
    Good afternoon friends
    I have an Asus laptop motherboard X455LJ REV 3.1 that the touch pad does not work, I was trying to check if something was wrong at the drive level but I did all the necessary installations and the touchpad still does not work.
    I have a feeling that the error goes more to the board level because the touchpad is not recognized by the device manager and it is supposed that even if it does not work correctly it has to be detected.
    I even checked that the data bus made a connection between the touchpad and the motherboard and everything...
    03-30-2023, 03:56 PM
  • resistor83
    lenovo 330s-15ikb, led num lock key always on and numbers don't work
    by resistor83
    hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
    I tried updating the bios but the problem remains
    https://s...
    05-29-2025, 08:06 AM
  • claws77
    lenovo flex5-14itl05, touchpad water damage
    by claws77
    last night i dropped some liquid over my laptop touchpad, immediately stopped using and tried to dry it up.
    the touchpad misclicks, sometimes stops working altogether
    i have removed the touchpad assembly cleaned it with alcohol and brush and cotton buds.
    can i fully disassemble the touchpad assembly as i suspect some liquid is still lurking inside the trackpad.​...
    07-15-2024, 07:34 PM
  • dhs6512
    Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 not work with the battery
    by dhs6512
    Hello. Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 board
    Initially dead. Inspection: the board was not touched, on EC IT8227E-192 2101-CXA there is a mini-burnout.
    Replaced with the same one, flashed the EC with the official firmware (had to solder to the pins), left the main firmware (Gigadevice 25LB128DSIG) original.
    When connecting the charger, the device started, gave picture and works, checked all the functions - ok.
    Connected the original battery. Only on the battery the device starts for a second, lights up the keyboard backlight and turns off.
    When connecting...
    10-29-2024, 11:04 AM
